Old 01-25-2021, 03:05 AM #1
T4R916 T4R916 is offline
T4R916 is on a distinguished road
4Runner not tracking well
Does anyone 4th gen V8 not track well? Notice on regular roads my 4runner rides pretty stiff/harsh and i went snow wheeling today and it seems to slide all over the place. My buddy also have a 4th gen V8 and his rides a lot better than mine. My suspension setup is Icon coilovers with 700lb springs with JBA UCA in the front and bilstien 5100 and toytex superflex springs in the rear. I have a demello front bumper. Idk if i need to add more weight since i have a 700lb springs in the front? Also i notice when going over speed bump the rear end likes to kick out.
T4R916 is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 11:43 AM #2
crete01 crete01 is offline
crete01 is on a distinguished road
Check your panhard bar. As the rear end gets lifted/heavier springs (especially when you don't have weight in the back), the panhard bar becomes more angled. When you hit a bump at speed, the body kicks up, extended the springs, and the panhard (if not parallel) will cause the rear axle to shift left/right a bit. When the weight comes back down, the small shift in alignment front to back makes it feel like something kicked your ass to the left a bit.
Since I put a new rack and tent on my roof, this problem mostly went away. On trips the gear in the back also eliminated the problem. Was not a big enough problem for me to want to fix in the past, but a few companies sell brackets that can relocate the mounting position and help re-level the panhard if you feel that it's an issue.
crete01 is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 08:59 PM #3
gaber6 gaber6 is offline
gaber6 will become famous soon enough
Lifted without camber correcting upper arm seems like the issue as well. I have a v6 with a daystar kit and plan on removing it for the same wandering feel.
gaber6 is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 12:31 AM #4
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
There’s a few things you can do to help. Mine have been incremental and each has improved the ride.
-My first big improvement was when I replaced my rear sway bar end links with 2nd Gen Moog (1” longer) and red energy polyurethane bushings for the end links and sway bar bushings. I had probably a 20% improvement in stability on the Hwy.
-2nd was to upgrade the front sway bar bushings with polyurethane bushings as well. I saw very little improvement unfortunately but may have improved the squirellyness by maybe 5%.
-3rd welded on the pan hard bar extension to get the pan hard level again. This was about another 20% improvement once again.
-4th and 5th will be to replace my UCA’s with adjustable SPC to try and get my Caster to around 4.2* (I think that's what's recommended on here) and replace my LCA’s with new OEM (I am thinking right now). Was going to rebuild (still may) with white line poly bushings but don’t like the fact I can’t get OEM ball joints for the LCA’s to rebuild. Plus I want to say Id be around $185 plus ea. for parts when OEM are around $275-$300 ea. These last two are really supposed to help. It may be a month or 2 before I can get them in and on, then get it aligned. Really looking forward to getting the squirrelly gone at Hwy speeds over bumps. Gets a little too sketchy at times for me plus it likes to wander, especially in the wind.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
4runner , 700lb , front , rear , springs
DJI Mavic Active Tracking My 4Runner el_kab0ng Off Topic 30 05-30-2017 09:27 AM
Santa Tracking Friggin Idiot Off Topic 0 12-24-2015 01:18 AM
Tracking Down Old Vehicle Hepar Off Topic 13 07-31-2014 02:50 PM
4Runner tracking and pulling left...argh! Blanco 3rd gen T4Rs 7 01-04-2012 02:45 PM
tracking a new runner ERG2008 4th Gen T4Rs 3 03-10-2008 02:07 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
