Old 01-26-2021, 02:16 PM #1
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Desert Does It Seat Jackers
Can anyone comment on the Desert Does it Seat Jackers? Are they any better than just putting a stack of washers under the front bolts? Got someone selling one local and trying to decide if it's worth it.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 05:26 PM #2
pauldub pauldub is offline
pauldub will become famous soon enough
The front seat mounts don't sit flat on the floor so adding washers may not work if you add more than a couple.
pauldub is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 05:39 PM #3
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
Following. Have those on my short list of minor mods I’m considering. One of my only complaints about the 4Runner is the seating position. My legs fall asleep on long drives.
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 05:49 PM #4
I've already got washers on there (and working!). Trying to decide if this is worth the extra scratch.
Old 01-27-2021, 09:52 AM #5
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
There is a cheaper version advertised on eBay, looks like metal spacer with 3d printed outer for around 40 bucks. Seems to do the same thing for way less
2005-21 Toyota Tacoma 1" Front Seat Spacers / Seat Lift Kit / Riser | eBay
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 11:53 AM #6
curious what is the purpose or advantage of raising the seats up?
im not that tall at about 5'10" & think the head clearance in 4th gen 4runners is already pretty low, getting in & out i have to duck my head a bit.
Old 01-27-2021, 11:56 AM #7
Not sure if that will work in the 4runner. The Desert Seat Jacker is Angled, like the spot on the floor where the seat connects for the 4Runner. Not sure that is any better than a stack of washers.
Old 01-27-2021, 11:57 AM #8
These spacers only lift the front edge of the seat. Your butt stays about the same height. Gives you more leg support if you're long legged (like me).
Old 01-27-2021, 07:48 PM #9
0verland's Avatar
0verland 0verland is offline
0verland will become famous soon enough 0verland will become famous soon enough
0verland's Avatar
I can speak to this a bit. I have had mine installed for about two months now and will say it's definitely a significant difference in ride comfort and feel. The seating position I keep mine in is with the backside of the seat bottoming out in adjustment and the front up about halfway. The steering wheel sits a bit more into my lap based on where I like it positioned, aligning with the view of the gauges but still feels comfortable. At 6'1, the view through the window puts me looking directly out at about 1" below the AS1 line is on the windshield.
The passenger seat is completely transformed too allow more of a cradling angle to hold the passenger that than the bench eat feeling of an old truck, since that seat does not have much adjustment.
Overall I think they are worth the price of admission, making the seating position feel like your sitting up higher like in a truck but also allowing more lumbar support under your legs, feeling more holding and sporty. I wasn't sure I was going to like them or if they justified the cost, which is why it took me awhile to pull the trigger on them but I am glad I did.
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
0verland is offline   Reply With QuoteReply With Quote
bolts , desert , jackers , seat , selling
Anyone running seat jackers ? TRUSTYAXE 5th gen T4Rs 67 01-18-2024 11:29 AM
Desert Dune vs. Desert Dune Metallic Ron Burgandy 3rd gen T4Rs 2 11-10-2020 11:51 PM
desert fun! 04desertrunner 3rd gen T4Rs 2 10-22-2012 05:24 PM
Hi- Jackers or Firestone air bags Poll willyt4r Classic T4Rs 2 06-15-2012 03:20 AM
