Old 03-21-2017, 10:03 AM #1
xmytruck xmytruck is offline
xmytruck is an unknown quantity at this point
Brake System warning Light & VSC and ABS Light
Hello
Driving to work today and halfway to work the dash board lights up like a Christmas tree. The Brake system warning light, VSC, and ABS light are all on. Check the brake fluid and it is topped off and have not notice any leaks in the brake system. Just got the rear brakes done about 2000 miles ago, my truck a 2008 4runner sport with 129000 miles. Any ideas what could be going on?
Thx
xmytruck is offline   Reply With QuoteReply With Quote
Old 03-21-2017, 01:05 PM #2
Noticed the brake fluid was not all the way to max line so I topped of the brake fluid it did not solve the issue. So far ever 3000 miles this truck is costing me 400 bucks .
Old 03-21-2017, 01:07 PM #3
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
First thing to do is pull the codes and see what the vehicle thinks the problem is.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 03-21-2017, 01:26 PM #4
Will do. I am getting five chimes during start up not sure what that means. I will have to take a run down to autozone.
Old 03-24-2017, 02:51 PM #5
Heard from shop they stating they need to replace the rear speed sensor on the truck and estimating the work to $918 does that sound right?
Old 03-24-2017, 03:15 PM #6
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough
CookieRoe's Avatar
Real Name: Ed
Yikes.
A speed sensor, part# 89543-04020, price on partznet: $166.53. This particular one is for LEFT front or rear. I'm not sure how involved replacing a speed sensor is, so..........
Hope this helps.
Ed
CookieRoe is offline   Reply With QuoteReply With Quote
Old 03-24-2017, 03:43 PM #7
970mtnrunner 970mtnrunner is offline
970mtnrunner is on a distinguished road
Very rare for the actual sensor to go out, its just a magnet. More likely its the cable. I recently had to replace mine, it had basically rotted out where it turns upward from the rear differential. I got an oem cable from amazon for $110, part number is 89516-60090. Its very easy to replace, took me a whole 10 minutes tops. The sensor comes out with one small bolt. You dont need to remove the wheels or even jack the vehicle up to do it.
If it is a sensor, you can get a set of aftermarket ones that everyone seems to have no problems with for $25 for both on amazon.
And that price is absolutely insane. I just had my timing belt, water pump, and a new serp belt done for $900. You could replace both sensors and the cable for ~$135 on your own in a 1/2 hr.
970mtnrunner is offline   Reply With QuoteReply With Quote
Old 03-24-2017, 03:50 PM #8
I am going to call another place the price seems high to me. Any chance that when they replaced my rear brakes that caused the issue?
Old 03-24-2017, 03:54 PM #9
He said that the sensor is part that goes around the bearing. Does that sound right?
Old 03-24-2017, 03:55 PM #10
Yes its possible. The ABS cables are very easy to break internally, especially after they age and subjected to all the road crap. I managed to f-up both of my front cables when i did my front brakes from letting the suspension hang.
The part that goes around the bearing is just a metal ring with notches, usually known as a reluctor or tone ring... cant imagine how that could go bad, other than possibly coming loose and not rotating at the same speed of the axle.
I would have the cable checked for continuity first before anything else.
Old 03-24-2017, 07:45 PM #11
Trumpet Trumpet is offline
Trumpet will become famous soon enough Trumpet will become famous soon enough
it's possible for a ring to get gunked up with magnetic dust. A can of brake clean and a rag would be it. More likely the sensor cable was damaged when the brakes were done.
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
Trumpet is offline   Reply With QuoteReply With Quote
Old 03-24-2017, 09:36 PM #12
Gdmeadors Gdmeadors is offline
Real Name: Greg
Gdmeadors is on a distinguished road
Real Name: Greg
Try replacing the brake light switch on the brake pedal. That is what caused problems for me. A quick and cheap fix costing less than $15.
Gdmeadors is offline   Reply With QuoteReply With Quote
Old 03-25-2017, 12:10 PM #13
summit21 summit21 is offline
summit21 is on a distinguished road
I did the same a couple of years ago and no problems since. I also replaced the speed sensor prior to brake switch and lights still came on. Both the speed sensor and brake switch are very easy DIY's.
2018 TRD Pro, BFG TA KO2 265/70/17
summit21 is offline   Reply With QuoteReply With Quote
Old 03-25-2017, 05:44 PM #14
dgmorr dgmorr is offline
dgmorr is on a distinguished road
As an alternative, I purchased the china ones off ebay for about $20 for the pair, so far no issues.
2003 V6 Limited
dgmorr is offline   Reply With QuoteReply With Quote
Old 09-12-2022, 11:04 AM #15
Napalm's Avatar
Napalm Napalm is offline
Real Name: Nathan
Napalm will become famous soon enough Napalm will become famous soon enough
Napalm's Avatar
Real Name: Nathan
Giving this thread a nice bump!
This morning while driving to the shop to fix another issue, my T4R threw a Check engine light, traction light, and VSC light.
The shop read it, and told me it was a brake switch/ABS issue. Anyone have a similar issue and know the fix?
2007 SR5 V8
2017 Limited
Napalm is offline   Reply With QuoteReply With Quote
Brake Warning Light kkumnick54 3rd gen T4Rs 8 11-19-2018 03:51 PM
Is the erratic VSC Trac warning light associated with erratic Brake Light Switch jow 4th Gen T4Rs 0 07-16-2015 10:50 AM
Brake Warning Light Comes On Nate613 Problems & Warranty Issues 7 03-09-2011 01:37 AM
Warning Brake Light on mvinsable 3rd gen T4Rs 1 08-07-2010 12:17 PM
E-Brake warning light Armandi Maintenance/Detailing 3 01-10-2009 05:33 AM
