Old 01-27-2021, 12:41 AM #1
Riseagainst Riseagainst is offline
Riseagainst is on a distinguished road
5th gen axle fit on a 4th gen?
Will a 5th gen axle fit on my 4th gen? I don't care about the performance upgrade and stuff. I just want to know if it's a direct component swap?
Details-
2006 v6 4runner with 180k miles. Rear end is shot. Shop is saying I pretty much need all the rear axle guts and seals. If they're new OEM cost is going to be more than my 4runner is worth. Finding a whole use axle with the shop to install is going to cost at minimum $3k. Which i can kinda confirm- on LKQ the whole rear end is just under $2k, so appox $1k in labor. I know that I can swap out a whole axle, but i'm not confident to swap out the guts myself.
So will a 5th gen axle fit on my 4th gen? I have a line on a local 5th gen that is being parted out with 59k miles for $400. There is someone else thats parting out a 4th gen but they haven't gotten back to me about it so i don't know if i can get it and at what cost.
2006 SR5 V6 4x4
17" FJ wheels, FJ springs, 1" daystar lift in the front
Las Vegas, NV
Riseagainst is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 07:58 AM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Yes the 8.2 from the 5th gen should bolt right in. I haven't done it myself but @Drift Monkey and @TheHennDoggg have both swapped in 5th gen axles with elocker. Look at both of their previous posts and especially TheHennDogggs build thread, I believe he got his rear end for $220 at an LKQ since pull your own rear axle is a flat rate.
y=mx+b is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 12:19 PM #3
Thats great to hear!
Any idea how idea how to find out if it is the 8.2? From what i read- pretty much all these 5th gen 4runners are 8.2 rear ends?
The donor 4runner is a 4x2[5th gen] and mine is a 4x4[4th gen]- any possible issues with gearing? I'm asking the guy for the VIN so hopefully i can confirm what gearing it has.
2006 SR5 V6 4x4
Las Vegas, NV
Old 01-27-2021, 01:05 PM #4
y=mx+b's Avatar
y=mx+b's Avatar
I believe all 5th gens are the 8.2. Should also be able to expand your search to FJs as well, they came with both the 8 and 8.2 depending on the year.
I don't think that gearing is an issue 4th to 5th gen, but not 100% sure on that. I think they all were 3.73 though. For FJ you will have to make sure it's also an automatic because the manuals had a bit lower gearing, 3.91 iirc
Old 01-27-2021, 01:18 PM #5
Thanks man, i really appreciate the time to help. I guess once i get the axle swapped over i'll post some pictures and what not.
2006 SR5 V6 4x4
Las Vegas, NV
Old 01-27-2021, 01:25 PM #6
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
If your doing the swap make sure the donor has an elocker. Low range offroad sells a full wiring harness for it. If your going to all the effort, get the most out of your upgrade.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 06:18 PM #7
y=mx+b's Avatar
y=mx+b's Avatar
I love pics! Good way to document for others looking to do the swap too!
Old 10-20-2021, 03:07 AM #8
BottomDwellingT4r's Avatar
BottomDwellingT4r BottomDwellingT4r is offline
Real Name: Anthony
BottomDwellingT4r is on a distinguished road
Real Name: Anthony
Did this ever get done? Looking at doing the same for a bit more strength and elocker. Mines a bit rusty on the axle but my frame is good. It’s weird.
BottomDwellingT4r is offline   Reply With QuoteReply With Quote
Old 02-15-2022, 10:06 PM #9
Real Name: Anthony
Real Name: Anthony
I don’t know about all ways but I ordered an axle from lkq. I asked for pictures of it which I was turned down for. Paid for the axle $2k. I borrowed a buddies trailer and drove 2 hours to pick it up, and no elocker. I stopped them before they loaded it and said nope, that’s why I wanted pictures. Then waited 3 days to find my money not back on my card. Sat on the phone arguing and on hold for 2 hours for them to finally refund my money. Overall not satisfied with lkq.
Old 02-16-2022, 09:28 AM #10
rdruss's Avatar
rdruss rdruss is online now
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Hey, @Riseagainst , where's your pictures? From over a year ago.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
rdruss is online now   Reply With QuoteReply With Quote
4th , 5th , axle , fit , gen
Rear Axle Seal: Axle Puller Tool Design nobb 3rd gen T4Rs 29 11-23-2019 07:39 AM
CV axle - rotation axis is different than axle shaft centerline? thezentree 3rd gen T4Rs 2 02-26-2018 05:25 PM
Q: Replace axle bearings&seals or find assembled axle? Mutant 3rd gen T4Rs 12 09-14-2017 10:35 AM
Rear axle/suspension problem-axle shifts when going on/off the gas Rusty Plum 3rd gen T4Rs 7 09-07-2014 09:46 PM
Solid Axle Swap vs regular axle w/ lift/suspension? priestsallore Classic T4Rs 9 04-28-2010 11:30 PM
