Old 02-05-2024, 03:45 PM #16
4RuNnMyLife's Avatar
4RuNnMyLife 4RuNnMyLife is offline
4RuNnMyLife is on a distinguished road
It's possible...
FWIW; when i first got my 4Runner, there was an exhaust leak at the Manifold on the Passenger's side. This sounded more like a tap than a tick. It was audible with windows up, as well as down. The Gasket ended up being worn out to the point it was missing some Material (which was where air was escaping).
If that does end up being the issue, be sure to get some new Manifold Bolts too, as we had issues with ours and ended up having to replace those also.
Good Luck brother!
4RuNnMyLife is offline   Reply With QuoteReply With Quote
Old 02-06-2024, 08:33 PM #17
Moist's Avatar
Moist Moist is offline
Moist is on a distinguished road
Moist's Avatar
Pre-2005 2UZ-FE does it too. It sounds like fuel injector ticking. Mine makes the same noise and is loudest on the passenger side. The location is strange though. If it is injector tick it's not really cause for concern, mine have been doing it for years.
If not I'd guess it's exhaust manifold ticking. (Granted manifold tick after a while starts to sound like a tapping in the footwell under hot weather and prolonged strain on the engine)
Is it a top end or bottom end sound? What RPM is it loudest at? Lastly what temperature is it loudest at?
(Manifolds seem to get louder the higher the manifold temp. My ticking is loudest during the summer under heavy load.)
Moist is offline   Reply With QuoteReply With Quote
driver , engine , noise , side , ticking
Noise behind the rear wheel driver's side. calcrc 5th gen T4Rs 10 08-16-2020 05:24 PM
Driver side rear knock noise Jbatman 5th gen T4Rs 9 08-28-2018 11:57 PM
ticking noise from front drivers side of engine. MuddyButt 3rd gen T4Rs 5 01-22-2015 03:46 AM
This is "normal" right? ticking noise from driver's side blackmax 4th Gen T4Rs 2 03-07-2014 10:53 AM
Noise from rear driver side when braking?? ejalkh 5th gen T4Rs 19 09-24-2011 03:48 AM
