01-27-2021, 01:32 AM
Engine ticking noise, driver side, rear
Was changing the coolant when I heard this ticking noise. Not sure if it was there before, just happened to notice it now since I had the hood open while the engine was running.
The ticking sound is coming from the back of the engine, driver side.
Video
Give it to me straight doc, how long do I've got?
2005 Limited V6 4WD
01-27-2021, 11:15 AM
Video
My 2008 V6 has always had a tick since I bought it with 35k miles on it. Always assumed it was just the norm for these engines and haven't thought twice about it in the last 100k miles.
That said, have you changed motor oil brand/viscosity lately? How many miles on your oil now? Could also be an exhaust manifold but that issue isn't nearly as prevalent as on the v8s.
01-27-2021, 03:13 PM
I've done regular maintenance and did change the oil brand but since 2 oil changes ago.
2005 Limited V6 4WD
01-27-2021, 05:04 PM
I too have the common driver side ticking, but it's not nearly as loud as yours. About a year ago, I met a dude who claimed to be a master mechanic at a Toyota dealer and I asked him about it. He said that it's unlikely to be a lifter, even though it sounds just like one. He told me that's it's almost always a noisy injector, but it's not a sign of impending injector failure.
The only way to test that theory is to plug in a sophisticated diagnostic tool that would allow me to deactivate individual fuel injectors. Do you have access to something like that?
01-27-2021, 06:13 PM
Real Name: Steven
Real Name: Steven
Possibly a cracked exaust manifold. It's a common problem on 4runners.
Mines been doing it on the passenger side for the past 60k+ miles but stays silent once the outside temps go below 60 degrees or so. I'm not going to bother replacing it until it starts throwing codes.
01-27-2021, 06:33 PM
Did you check your plugs yet?
2004 4runner, V8 sr5 white, trd taco springs and shock, daystar 1" leveler, 3" toytec hd rear springs, ome shocks, confer rack, led bar 40", hi-lift mount, 285/75r16 K02, 6spoke trail teams fj wheels, homemade adj track bar, custom zip tie off road modifyed bumpers, trd airfilter, scion radio, ipod interface, 300k miles, matching tan limited front seats
01-27-2021, 09:40 PM
Could be a plug backing out or arcing from a bad plug or coil
Sounds like an exhaust leak, and that is a sucky job to do. Had that on a nissan pathfinder and in the process of replacing the gasket, I snapped one of the studs. $900 later at the shop to drill it out. I hated that truck almost from the minute I bought it.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
01-28-2021, 02:42 AM
- I did replace my spark plugs a few months ago. I'll check and see if something happened with one of them.
- Would the exhaust manifold do a clicking sound? I'll check some videos online about exhaust manifolds and see if it is the culprit.
- I don't have access to one of those diagnostic tools
2005 Limited V6 4WD
01-28-2021, 03:06 AM
Looking at some videos it does sound like the exhaust manifold is cracked. Funny how I thought some mechanical part must be broken but seems like the internal clicking sound of the engine just comes out louder if the manifold has a crack in it.
2005 Limited V6 4WD
01-28-2021, 09:30 AM
Real Name: Newell
Real Name: Newell
Its your exhaust. Take it in to a muffler shop and have them diagnose it for free. When I bought my 08 V6 @98k the drivers side had already been replaced with a custom header. FF a couple years, one of the welds at the manifold cracked and produced the same sounds.. Replaced both sides with JBA shorties and haven't heard a peep since.
08 V6; Dobinsons IMS, Spidertrax, Prinsu, Revo 3s, AFE pro dry, Mishimoto catch, JBA shorties, Custom Y pipe, Borla pro XS, Hayden trans cooler, Ultragauge, Fumoto, +More..
01-28-2021, 05:29 PM
I agree with the exhaust leak theories. Does it quite/go away when the engine is fully warmed up?
2005 Limited 4X4 V8 36,000 original miles. 265/70/17 BFG KO2s, Front: Bilstein 5100s set to 3rd perch with stock springs. Rear: OME 895E springs and driver OME trim packer driver side with 5100 shocks. 2" overall lift.
01-28-2021, 05:40 PM
I was able to reduce the ticking coming from my v6 by following this - but it's still there.
V6 Tick Tic Tap Noise Reduced!
12-05-2023, 08:28 PM
Ticking noise
Hey, so I’m new to the 4runner community. Just wondering if the tick on startup and idle is normal. It accelerates with higher rpm. Is this something I should be worried about?
12-06-2023, 12:46 AM
First you need to make sure it's indeed from the exhaust. I have isolated the sound to be coming from the manifold area. For my V6, I can only hear it with windows down. If you can hear it even with all windows up, it might be an tiny exhaust leak. There's an interesting theory coming from a 120 Prado owner sharing the same V6 with us:
Welcome to Land Cruiser Owners On Line
Basically, the headers on our 1GR is a simple 90 degree bend out from the head, and it can cause exhaust pulses interfering with each other, hence making that noise that almost sounds like an exhaust leak.
02-03-2024, 03:59 PM
I have the same sound, looked been told it could be injectors, valves or timing chain. Any resolution to this? Toyota says valves should be checked and adjusted like every 60k miles but nobody really seems to do this service. Even calling Toyota dealerships and local shops they say it is not a common thing to do. Had a local mechanic listen to the engine for 30 seconds and he said it sounds normal, hard to really trust this though haha.
Here is a video of my 08 making a similar noise, much more pronounced on driver side.
Video Here:
2008 4runner 1GRFE ticking/knocking noise? - YouTube
What i think is odd with this is that it sounds normal when cold, but gets louder the longer it runs and warms up. Maybe this would prove the exhaust leak theory true?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
