Old 01-27-2021, 10:00 PM #1
gigajoe's Avatar
gigajoe gigajoe is offline
gigajoe is on a distinguished road
gigajoe's Avatar
Switch blank next to dimmer
All,
Does anyone know if the gray flat blank next to the interior dimmer to the left of the steering wheel is the same size as the other push button switches below it? Im thinking about moving my A-TRAC and Rear Diff lock from the center console. Its a Trail Edition and Id liked to have the center used for light switched exclusively.
thanks
gigajoe is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 11:12 PM #2
ThorRides's Avatar
ThorRides ThorRides is offline
Real Name: Todd
ThorRides is on a distinguished road
ThorRides's Avatar
Real Name: Todd
As long as it looks like it is the same size, they are. Just need to worry about extending the wiring.
'05 T4R Limited V8 with 4" lift
My Ride
ThorRides is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 11:39 PM #3
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
It is not the same cutout. The one next to the dimmer is wider and more square.
I was able to fit this toggle switch in there but that’s it. I need to round the corners a touch to get it flush but can’t really tell so I’ve been lazy about it.
Switch blank next to dimmer-88740e25-6334-447b-85c9-6275b5225625-jpeg
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 05:46 PM #4
gigajoe's Avatar
gigajoe's Avatar
Would that toggle switch fit in the other switch holes in the center dash or the row of switches below it?
Old 01-28-2021, 07:21 PM #5
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Just rubbing our faces in your atrac and rear differential buttons . . .
Old 01-28-2021, 07:55 PM #6
gigajoe's Avatar
gigajoe's Avatar
I plan to do it even HARDER if its possible to relocate both switches to the left of the steering column
Old 01-28-2021, 08:02 PM #7
JH225 JH225 is offline
JH225 is on a distinguished road
Left of the steering column those switches are all the same opening, but behind that opening the switch bodies are keyed. Anything can be done.... but this particular task isn’t 10 minute task.
JH225 is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 10:03 PM #8
Negative, it only fits the dimmer or blank next to it so I got creative. Quick and easy way is just pop your blanks off both and try to interchange.
If you run out of spots (like me lol) I’ve seen where someone relocated their dimmer behind the interior fuse door just sitting there inside. That would free up the other if needed but I didn’t like that route personally.
Switch blank next to dimmer-91dfa34d-3b72-473e-bcf3-bed00e843313-jpg
Old 02-01-2021, 04:44 AM #9
gigajoe's Avatar
gigajoe's Avatar
In case anyone else finds this, it does not fit at all.
2009 Trail Edition
4thgente on Instagram
Old 02-01-2021, 01:11 PM #10
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
The button on top next to the dimmer switch is not the same as the four below it. It has a square corners which is the same as the old toyota switches found in 88-94 toyotas. You can nab these switches from many different toyota models including some scions.
The bottom four and the ones in the center console all take the modern rounded switches. As mentioned above the holes are keyed but that can be easily taken care of with a file.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 02-01-2021, 02:32 PM #11
While I had my dash apart and buttons out I threw in my center console button for reference, even though we all know they won’t fit and vise a versa.
@randy88fj62 that is good to know the older toys fit the square holes, I didn’t know that. Thank you for sharing.
a-trac , blank , center , dimmer , switch
Dimmer Switch Broke Jones25261 3rd gen T4Rs 6 10-16-2020 03:10 PM
Does an 01 have a dimmer switch? xspsi6 3rd gen T4Rs 6 01-19-2015 07:18 PM
Dimmer Switch Help Generaljdog 3rd gen T4Rs 5 03-19-2013 01:26 PM
Dimmer Switch Queston cleger 4th Gen T4Rs 10 02-27-2013 10:08 AM
