Originally Posted by bwingnutt
Is there a header that is legal in Cali? Need to change out cracked stock manifolds on my 07 v8. I am getting the P0430 code on bank 2. Can the stock manifold be repaired? Thanks to the forum for any help
It can be easily removed, tig welded, painted with 2000 degree paint, ground flat at a machine shop and reinstalled. You will most likely need a new manifold +cat if you are getting P0430. I manufacture cat-caps which solve the emissions issue for CA. PM for details.
