Old 01-31-2021, 10:43 AM #1
jcampo788's Avatar
jcampo788 jcampo788 is offline
Real Name: Call me "Campo"
jcampo788 is on a distinguished road
jcampo788's Avatar
Update on my 04 TR4. Longevity mods?
316k...
04 V6 4wd
Got it from a friend, the only owner, for $2000.
Condition I would describe as very good mechanically and cosmetically. I always was googoo over their T4R and got lucky enough to be the first “I’ll take it”.
Interior was very clean. Just needs mats (went weather tech custom). I had it detailed and the detailer was in shock regarding the quality of its condition. Some pits in the paint, and small areas of rust around the gate. Having a body shop check it out on Monday.
I had a decent amount of mechanical work done, some necessary, others were “while you are at it” calls I made. Better to do it once and do it right. I did what I could, had a trusted friend do what I couldn’t. The forum community helped me IMMENSELY through this initial phase of getting it up to where I wanted it mechanically and cosmetically.
-differentials serviced
-cabin air filter
-oil change, filter, lube
-Alternator drive belt replaced
-ABS Speed sensor harness (R) replaced
-spark plugs replaced
-radiator (had a leak, replaced)
-both valve cover gaskets replaced (had leak by dipstick)
-control arms replaced
-alignment
-sway bar control links replaced
-new shocks and struts
-replaced the spare rim (cracked)
-a bunch of fun in the dashboard stuff
-Cooper at3 ltx 265 75 16 + spare
The frame is in amazing (Colorado) condition. No rust. The vehicle has now been looked over by two trusted service centers, and both said it is in very good condition for the miles.
So, selling my Outback and Suburban today. This will be my daily driver. With it being at 316k, with a goal of getting it to 500k around ten years from now, I want to ask the following...
What else can I do to keep my T4R in such good condition? I was thinking frame film, but, asides from the work I had done, is there anything else I am missing? Update on my 04 TR4.  Longevity mods?Update on my 04 TR4.  Longevity mods?
jcampo788 is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 10:44 AM #2
jcampo788's Avatar
jcampo788's Avatar
Old 01-31-2021, 12:00 PM #3
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Wow - a lot of work - great
I think at this point youre getting into the territory of prevention may be just as expensive as fixes. Unfortunately, you cant prevent everything, so i think you just hope for the best and any issues come up you deal with them as they come.
Hope youre enjoying it
Old 01-31-2021, 12:41 PM #4
0verland's Avatar
0verland 0verland is offline
0verland will become famous soon enough 0verland will become famous soon enough
0verland's Avatar
Welcome to the club. I am glad to see there are people still keeping these on the road with the mileage getting up there. All too often I see these being neglected by the standard owner. It looks like you have gone through it meticulously, the only thing I would suggest is making sure the timing belt and water pump have been done at the last interval necessary.
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
0verland is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 12:47 PM #5
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
So OP has a V6, which runs on a timing chain, should last the life of the engine, no belt to worry about other then the serpentine, and losing that won't necessarily grenade an engine...
At the stated mileage, I would be looking at the fuel delivery system, the injectors could be getting weak and clogged, as could the fuel pump. Have you serviced the transmission? The transfer case? The rear control arms( my bushings were going out at 190k). How is the starter? U-joints? Power steering and transmission hoses, radiator hoses, fan clutch...I would really focus on fluids and hoses, as clean full fluids keep components working. When I replaced my water pump at 200k, I did so because I wanted peace of mind, knowing I had never seen a water pump last that long back in the day. I was shocked at how decent the old pump still was, probably could've gone another 50-100k with just flushing the radiator. So, if you keep your fluids clean and full and your hoses are in good shape, you should be good for the most part
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 02:40 PM #6
Real Name: Skip
Real Name: Skip
Since it's a V6 which has a timing chain....many say the timing chain could need replacing at around 300,000 miles...so if the timing chain hasn't ever been replaced I would check it to see how stretched it is, to check it search the forum for "timing chain tensioner" and you should find a description of how to check it, but basically you remove the inspection cover and see how far the tensioner is extended, if it's extended too much it's time to do the timing chain replacement.
Also you may want to flush the brake and power steering fluids if that's not been done.
2004 Limited V8
Old 01-31-2021, 05:48 PM #7
0verland's Avatar
0verland's Avatar
Oh snap, You right! For some reason I was thinking it was a V8. In that case you won't have to both lol. As the others mentioned... fluids would be the only other thing I can think of. Then just replacing stuff as it wears out... axles, wheel hubs, etc. which depending on the last owners replacement of items I would say things will start to come up sooner than later.
Seems like you got everything pretty much covered and into for prob less than $4,000. Not too shabby.
2006 V8 Limited 4WD
Old 01-31-2021, 09:55 PM #8
jcampo788's Avatar
jcampo788's Avatar
Both have been done. Update on my 04 TR4.  Longevity mods?
I have to pay off the initial service and then my plan is water pump and timing chain (if needed).
Old 02-01-2021, 06:27 PM #9
MikeinNH67's Avatar
MikeinNH67's Avatar
Sounds like at this point you just need to keep everything lubed and exercised. Examples are: hatch latch, spare tire mechanism, 4x4 mechanicals and I would have the inside of the frame oiled. Something else to monitor is the rear brake lines, they only last so long in the rust belt. I replaced all of them on mine over a year ago.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
condition , control , good , replaced , trusted
Question on Longevity feddeytx 4th Gen T4Rs 20 07-19-2019 05:41 PM
A Different Type of Mod Thread: Longevity & Dependability Mods ThatSickRip 4th Gen T4Rs 18 01-26-2018 03:47 PM
Dear Mods: Could you please update the quick reply code? matroe11 Software Related Questions & Answers 15 01-01-2017 03:55 AM
Update on my 4Runner mods Gonzo113 3rd gen T4Rs 41 08-25-2011 08:48 PM
Update on my first Mods TRZ06 4th Gen T4Rs 18 02-22-2006 06:20 PM
