Originally Posted by Ericcamaro
As said above. Just run it and check pan temp with your hand every couple minutes once it's borderline hot to the touch, like the plates at a Mexican restaurant, your good to go. Don't forget to cycle gears or your fluid level will come up short.
he did the correct toyota temp check & it worked the next day when trans was fully cooled.
as for the "hand on the pan" thing, probably not a very accurate way to check trans fluid, your hand is not calibrated to read the proper temp, could be off either way by 10-20* or more. the toyota temp procedure is super easy to do & avoids any guess work, or buy a $20 infrared temp gauge to verify the pan temp. & the pan temps vary depending on the location you are checking, best to use the procedure as its designed.
& cycling the gears doesnt affect the fluid level, its intended to let new fluid get into all the passages of the valve body.
