Old 12-10-2017, 04:32 PM #1
52577 52577 is offline
52577 is on a distinguished road
Steering issue help
Hello everyone ... Okay I need your help.
First here are my specs:
2004 SR5 Base V8 RWD
34K original, 1 owner miles (I'm the 2nd owner) condition is like new.
Tires: 4 Michelin LTX MS2, P265/70 R 16 – majority of tread left.
The 4Runner was exhibiting a bit of wandering on the highway, slight groove and bump steering. Not bad as some of the threads I've read where it dangerously hops lanes when it hits a bump. Mine is slight. Also excessive lean in turns.
So... I figured it was the alignment as the pre-purchase inspection indicated front end needed aligned. I had it aligned at Toyota and handled slightly better but didn't completely fix it. My second guess, as well as other suggestions on here, it was most likely the nearly 15 year old shocks.
The replaced parts:
NEW Bilstein shocks
NEW rubber shock bushings
NEW top mounts
NEW rubber spring seats
NEW 2nd alignment
The tech said the original shocks were not leaking and showed no signs of failure.
With new Bilstien's and busihings handling has improved, and cornering is tighter. However the power steering seems a bit too easy at highways speeds and not as tight and precise as I'd hoped for. Hitting grooves in the road and it tends to sligtly steers into them, not over them, and I'm constantly correcting back and forth with the steering wheel. It's not as tight and confidence inspiring like other vehicles I've owned.
All the treads I read on the subject suggest:
- Ball joints
- Tie rod ends inner and outer
- Stabilizer bar bushings
- Wheel bearings
- Control arm bushings
- Steering wheel intermediate shaft
All of these are in good condition according to the Toyota pre-purchase inspection, as they should be with such extraordinarlly low miles, garage kept, and never abused or off-roaded. I'm assuming the Toyota tech did his due diligence and properly checked the steering components.
Is this just how the 4Runners handle by design? I've never owned one before so I don't know.
Could it be as simple as the tires? I see that Michelin has recalled some LTX MS2 tires, but my DOT codes are not part of that recall.
https://www.michelinman.com/US/en/he...tude-tour.html
Any suggestions are appreciated.
Thanks!
52577 is offline   Reply With QuoteReply With Quote
Old 12-10-2017, 04:45 PM #2
offshorebear's Avatar
offshorebear offshorebear is offline
offshorebear is on a distinguished road
I also have a 2004. I just replaced the original stabilizer bar bushings with the red poly ones. The originals look fine, but the new bushings greatly improved steering feel.
Do you get any clunk noise when running over small bumps?
offshorebear is offline   Reply With QuoteReply With Quote
Old 12-10-2017, 05:07 PM #3
... No clunks or rattles or squeeks when going over bumps.
Old 12-10-2017, 08:13 PM #4
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Front swaybar bushings and end links would be my next project. Tie rod ends, ball joints, and wheel bearings are easily diagnosed or ruled out on a lift or jacking up one wheel at a time and testing for play/runout/noise. Control arm bushings are more difficult to diagnose and rarely fail on these trucks at low mileage.
The swaybar can exert force in strange ways during cornering and bumps if the bushings and/or end links are worn or damaged. With excessive play, it becomes a spring with delayed force transfer between the deflecting wheel and it's opposite.
Moog makes nice replacement bushings and end links. Be sure you remove and install the parts with the vehicle level and both wheels at same height to avoid problems. Preferred method is with the suspension at normal height, e.g. ramps or jackstands if you're doing the project at home.
waypoint is offline   Reply With QuoteReply With Quote
Old 12-10-2017, 10:04 PM #5
Geologist's Avatar
Geologist Geologist is offline
Real Name: Alex
Geologist is on a distinguished road
Geologist's Avatar
Real Name: Alex
What would that indicate is wrong? I have it and it drives me crazy. Not running a sway bar though.
2003 4Runner SR5, V8, 4WD
A few mods...
@LostInTheWoodsT4r on IG
Wheeling Videos
Build Thread
Geologist is offline   Reply With QuoteReply With Quote
Old 12-11-2017, 12:38 AM #6
Can soft sidewall tires and/or failing rubber components cause steering problems, or tires to drift?
Old 12-11-2017, 07:27 AM #7
waypoint's Avatar
waypoint's Avatar
What are the date codes on your tires?
Old 12-11-2017, 08:21 AM #8
Trumpet Trumpet is offline
Trumpet will become famous soon enough Trumpet will become famous soon enough
Yes.
You could also try increasing you tire pressure a couple psi per , and see if that helps as well.
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
Trumpet is offline   Reply With QuoteReply With Quote
Old 12-11-2017, 10:19 AM #9
jonnys's Avatar
jonnys jonnys is offline
jonnys is on a distinguished road
jonnys's Avatar
I also encounter this strange issue, and no steering concerns were brought up (even after mentioning it) at my local shop.
On highway, if the road has slight grooves, the truck likes to 'jump' into the grooves which can sometimes be disconcerting. If the road is flat and new, this problem does not happen, which makes me believe this is simply how the steering is designed for these SUVs.
Granted, I need new tires, and would assume this would help with this issue, but as mentioned this does not occur on newer, flatter roads.
2006 SR5 stock
jonnys is offline   Reply With QuoteReply With Quote
Old 12-12-2017, 10:10 PM #10
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
2006 SR5 stock
how's your toe alignment?
Sent from my SM-G930T using Tapatalk
radlynx is offline   Reply With QuoteReply With Quote
Old 12-12-2017, 10:52 PM #11
Registered User
Registered User
2006 SR5 stock
Effects of Toe
Excessive toe increases tire scuffing and results in tire wear and drag on the vehicle. Excessive toe-in, or positive toe, increases scuffing on the outside of the tire.Excessive toe-out, or negative toe, increases scuffing on the inside of the tire, and in some cases can cause a darting or wandering problem.*Bias or bias-belted tires will commonly show a featheredge or saw-tooth toe wear pattern across the entire tire tread area. Any tire wear pattern caused by a toe condition can be further affected by an excess camber condition and may result in irregular wear patterns.
Old 12-13-2017, 02:46 PM #12
Ya know, that's a good question. Everywhere I searched online to explain how to read a tire's cryptic numbers I can't find that data on my these tire. Every other vehicle no problem. I believe they were purchased 3-4 years ago by the original owner.
Below are pictures of my tire's tread. They're in good condition visually.
https://www.dropbox.com/sh/3klyuq61t...9Cmy1bIga?dl=0
Old 12-13-2017, 06:27 PM #13
hoodoo hoodoo is offline
hoodoo is on a distinguished road
All tires have DOT codes.
https://en.wikipedia.org/wiki/Tire#Markings
hoodoo is offline   Reply With QuoteReply With Quote
Old 12-13-2017, 07:57 PM #14
Originally Posted by hoodoo View Post
Right. But mine do not have a date after the DOT. See pic
DOT M3JC KC9X
Steering issue help-img_20171213_154557-jpg
Old 12-13-2017, 08:27 PM #15
waypoint's Avatar
waypoint's Avatar
Check the other tires, or the opposite sidewall of the tire you photographed...you're looking for a 4-digit number, no letters.
Steering issues w/ UCA's TE! 5th gen T4Rs 4 08-04-2016 10:03 AM
New Steering Rack Issues Qlaloo 4th Gen T4Rs 5 06-22-2016 01:37 AM
Steering issues..... outkast14 4th Gen T4Rs 9 07-15-2015 10:36 AM
Question about steering issues goro 3rd gen T4Rs 1 09-13-2013 11:08 PM
Power steering issues fluffeh 3rd gen T4Rs 5 12-24-2012 12:07 PM
