Old 02-02-2021, 11:38 PM #1
4RunnFunn 4RunnFunn is offline
4RunnFunn is on a distinguished road
2004 4R Brake Issue?
2004 4Runner.
I'm getting multiple dash lights and a piercing buzzer when I turn the key on. It will start and run. I drove it a couple of miles home (dash lights still on with the piercing sound). I thought it might be the battery. I disconnected the positive cable for a while and re-attached it. Same issues, but I noticed the brakes were really soft. It made me real nervous. I babied it back into the garage.
Any ideas? Thanks in advance.
Picture:
Video:
https://www.youtube.com/watch?v=8WKyEU_zcNM&feature=youtu.be
4RunnFunn is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 12:49 AM #2
Bernardchan96 Bernardchan96 is offline
Real Name: Bernard Chan
Bernardchan96 is on a distinguished road
Do you see any leaking fluid anywhere? when it buzzes theres an error with the braking system. Last time i had it beeping i was in a drivethru and my brake line blew and i had no brake pressure. Possibly could be your Brake booster or something ABS related, gonna have to get a scanner that can read ABS codes to tell
2005 4R LIMITED V8
FALKEN WILDPEAK AT3W&TRD RIMS
DOBINSONS SUSPENSION 2.5" F 2" R / JBA UCA / POLY PERFORMANCE TACO TAB/ 2ND GEN REAR LINKS
VOLANT CAI/ RA MOTORSPORTS SKID & DITCH LIGHT MOUNT
MAGNAFLOW MUFFLER
Bernardchan96 is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 02:46 PM #3
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
I would suggest not driving the vehicle in its current condition, and would recommend having it towed to your mechanic. The brake system may be on the verge of a very serious malfunction that may result in the loss of all braking power.
Some helpful info in these threads:
Help: VSC/TRAC/ABS/BRAKE lights on plus loud, continuous alarm?
WARNING! Brakes, ABS, loud annoying warning noise....
Brakes went out this morning! HELP!
2003 v8 4runner ABS Pump Problem! Any Solutions?
Brake Actuator failure
2003 v8 brake booster pump diy fix
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 05:13 PM #4
MikeinNH67's Avatar
MikeinNH67's Avatar
I had a blown line on the rear brakes of my 03, I don't recall any ear piercing alarms. Curious to know what you find though.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 02-03-2021, 05:26 PM #5
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
Do a search for master cylinder failure. That's the set of symptoms everyone who experienced it lists.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 06:04 PM #6
Thanks everyone. I'm still reading through all the linked threads, but it looks like very good information.
Old 02-05-2021, 05:35 PM #7
I read through all the attached threads and the many threads within them.
It didn't throw any codes.
I had no leaks.
The engine bay is very clean. The 4Runner has always been garaged.
I tested it by moving the ignition key to ON and listening for the motor to turn on. It didn't. I tested it a few times.
I hit the motor with a wrench a few times.
Tested it again and the motor did run.
I just ordered a remanufactured ABS Brake Booster Pump Motor.
Old 02-18-2021, 02:46 PM #8
I ordered my remanufactured ABS Brake Booster Pump Motor off ebay.
2003 2004 2005 TOYOTA 4RUNNER LEXUS GX470 ABS Brake booster Pump motor (REMAN)
It was $375 when I purchased it. You'll get $100 back for the core exchange. It comes with a 2 year warranty.
I bench tested the motor by itself when I received it. All good.
I removed the entire Hydraulic Brake Booster assembly using the numerous online videos, but this one helped the most especially since it was for a 2004 4Runner...
How to remove the HBB ABS unit from Toyota 4runner , Lexus lx450 lx470 gx470 etc
I kept the HBB unit upright during the removal, the motor replacement and the subsequent re-installation. I have no idea if this is important, but I wanted to make sure as little air as possible got into it or any of the brake lines.
This video was the most useful for replacing the motor on the HBB assembly.
HBB new motor install 4runner gx470 lx470 abs unit screeching screaming noise
It was a small PITA to do keeping the HBB assembly upright, but that's how I did it.
I then bench tested it by using the power connector on the bottom of the ABS Modulator. All good.
I re-installed the HBB assembly. I haven't bled anything yet. The piercing buzzer is gone and most of the dash warning lights went out. The only 2 lights still on are VSC TRAC and TRAC OFF. I'm gonna worry about them another day. The brakes are working just fine, not as tight as they can be, but well. I'll get them bled eventually.
Old 02-21-2021, 12:11 PM #9
ccoyle71 ccoyle71 is offline
ccoyle71 is on a distinguished road
Same thing happened to me - turned out it was the electric motor (part of the hydroboost system) that was failing. You WILL loose brakes after the system bleeds down. The audible buzzer gives you about 30 secs to get off the road and get stopped. I would definitely NOT recommend driving.
Like others have mentioned - I was able to find a refurb unit on ebay for $300 - which was way better than the stealership quote of $3600.
ccoyle71 is offline   Reply With QuoteReply With Quote
brakes , dash , lights , piercing , real
2004 4Runner V6 issue?? mac777daddy 4th Gen T4Rs 3 07-08-2019 04:04 PM
2004 4WD clunking issue Pintlar Tactical 4th Gen T4Rs 5 10-18-2018 11:43 PM
2004 V8 - Coolant issue??? Powder_Hound 4th Gen T4Rs 14 07-13-2016 06:06 PM
2004 V6 Acceleration issue Gus04Runner 4th Gen T4Rs 13 12-04-2014 10:42 PM
2004 odd starting issue mcdingler 4th Gen T4Rs 3 07-22-2013 01:09 PM
