Old 02-03-2021, 04:58 PM #1
94toy22re 94toy22re is offline
94toy22re is on a distinguished road
P0174 help
I have 2007 v8, hydro locked the motor last year, put in a used replacement and have about 10k on the new motor! Every 900 miles or so it is throwing a p0174 or Lean Bank 2 code! Replaced both down stream 02 sensors last week and now the code comes on within a few minutes of being cleared! MAF has been cleaned, the intake gasket was replaced when the motor was installed, and can’t find any loose vacuum lines!
So I’m down to a fuel issue or the air fuel sensors! I have the intake, fuel rail and injectors off my old motor and thinking about swapping the injectors out, before spending the $300 on air/fuel sensors!
Any other ideas?
94toy22re is offline   Reply With QuoteReply With Quote
Old 02-04-2021, 11:27 AM #2
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
Any other ideas?
Check for exhaust leaks. I had this same code in the past, it was because one of the flange gasket that mates the exhaust manifold to the y pipe was rotted away, allowing tons of air to escape. I discovered it by starting the car and just rolling underneath and placing my hands around everywhere there is an exhaust gasket, feeling for air that was escaping. Running lean = O2 sensors thought there was not enough oxygen because it was all escaping out of the exhaust leak. $5 gasket later, no more CEL.
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
code , fuel , motor , replaced , sensors
P0174 joeforman 4th Gen T4Rs 26 12-13-2019 01:49 PM
need some help: fault code P0174 Jan777 5th gen T4Rs 14 11-22-2019 08:48 AM
P0174 AND P0171 V8 4WD Limited BigMike18 4th Gen T4Rs 3 11-18-2019 11:45 AM
P0174 AND P0171 Same Time BigMike18 4th Gen T4Rs 17 11-13-2019 08:48 AM
need some help: fault code P0174 Jan777 4th Gen T4Rs 2 04-25-2019 03:51 PM
