02-06-2021, 01:22 PM
#16
now we just need to get this into Sticky section
02-06-2021, 09:08 PM
#17
Originally Posted by aemravan
You have no idea how invaluable this information in a single thread is man.. Between the pictures and your detailed explanation it is literally what I have spent the last couple of months off and on combing through in multiple threads.
I owe you a beer.
Amen!
02-06-2021, 09:09 PM
#18
Originally Posted by xtremewlr
Happy to help, man!
Believe me, I went through all the same shit you have when I first started considering the swap. Figured instead of sending people over to dig through my build thread, I'd just compile the pertinent information here and make it easier for others to find.
I cannot thank you enough for writing this all up in 1 place. This is invaluable! So much awesome, thank you again!
02-06-2021, 10:37 PM
#19
Real Name: Brett
Real Name: Brett
@ xtremewlr
between you and
@ y=mx+b
, you guys are taking over the 4th gen section. I am seriously going to have to consider this swap.
Nice work and Thank You!
1988 DLX 22RE AUTO BLACK- "Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
02-07-2021, 01:02 PM
#20
is it easier to do the FJ swap into a 2WD 4runner? I love my 4runner but it's RWD and it's obviously a bit limited for capability and I've thought of perhaps tackling this project with the help of friends.
02-07-2021, 01:07 PM
#21
Real Name: Todd
Real Name: Todd
Probably not easier since there would be a lot more work involved.
You'd need to swap the transmission as well since I'm fairly sure the 2wd trans can't be changed to work with a tcase. It's not a simple tail housing swap.
You also need to install a front differential and associated parts for the front axle driveline stuff.
The FJ tcase does make it easier in that you don't have to deal with any electronics at least.
I'm gathering parts to do a 4wd conversion on my daughter's 2013 Tacoma prerunner so have done some research on this.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
02-07-2021, 02:04 PM
#22
guess I'll sell it then
02-12-2021, 11:46 AM
#23
Real Name: Brett
Real Name: Brett
Not ready to do the swap, but went ahead and picked one up while prices are reasonable.
@ xtremewlr
not as clean as yours because of the rust factor here in Fla, but 2012 4Runner-130k miles $205 + $50 core. Didn't have the shift knob but I can probably find one of those cheap enough.
02-12-2021, 11:51 AM
#24
Real Name: Todd
Real Name: Todd
@ Extreme
wlr not as clean as yours because of the rust factor here in Fla, but 2012 4Runner-130k miles $205 + $50 core. Didn't have the shift knob but I can probably find one of those cheap enough.
Very nice! Mine was a 2011FJ case with the same mileage. No core on mine but I paid the same overall price, $250.
You bring up a good note too. 5th gen 4Runner tcase with manual shift is an option for this swap. Same as the FJ case. I don't know enough about the 5th gen 4runner to know what, if any, tcase options there are.
02-12-2021, 12:37 PM
#25
I am keeping an eye out , and will probably do the same and pick up a local T-case very soon.
I currently have some very good looking options for sub $200 within a 1 hour driving radius with no core charge and both between 100-120k miles.
02-12-2021, 01:43 PM
#26
Real Name: Brett
Real Name: Brett
I think the 5th gen case would be the same in all of their manually shifted part-time options. (Early Trail, TRD Offroad, TRD Pro) My 5th gen Limited AWD is a little different than my 03' V8 in that there is no separate switch in the dash for the center diff lock. The t-case may very well be the same as my 03' Full time awd, but with the center diff switch incorporated into the console dial. The base SR5 has the dial but is part time so I'm not sure how that one is set up, and if it would work in the 4th gen.
I wonder if the 5th gen actuators are prone to the same problems, I may have to buy another manual shift for my 5th gen, just in case lol.
02-12-2021, 05:23 PM
#27
Awesome modification, I'm super jealous.
02-18-2021, 11:56 PM
#28
The FJ tcase has an internal oil pump that is driven by the chain in 2wd and 4wd. Having the front driveshaft turning in 2wd will do nothing to the tcase, will not cause frothing of the oil or build up pressure or do anything else bad that some people might think or claim. They are full of shit. I say this from personal experience with my 4runner. I daily drive it since it's currently my only vehicle.
From one more member, thank you so much xtremewlr. I replaced my tcase with another electric one last year due to the actuator and now that actuator has frozen up too. I actually took a hammer to it and broke it apart because it got stuck halfway between 2 low and 2 high and I was dead in the water. Have had my fj case sitting around for about a week and waiting on my twin stick kit from low range but I might not even go that route now. I’ve been trying to get up with rst for the Upgraded spring kit and add wiring harness and have been stressed out from reading the thread on the Tacoma forum about his business going under as we speak.
You’ve lowered my blood pressure for sure.
2010 Trail Edition - Work In Progress
2005 4.7 Limited Totaled
1997 SR5
02-19-2021, 12:04 AM
#29
Real Name: Todd
Real Name: Todd
Yeah, my only advice regarding RST.
AVOID AT ALL COST!!
02-19-2021, 07:31 PM
#30
AVOID AT ALL COST!!
Its been literally 5 weeks since I reached out to them wanting to spend my hard earned money and literally have yet to get a response. I am VERY glad I never placed the original parts order I was under the impression I needed..
Sent from my SM-G970U using Tapatalk
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
