Old 02-19-2021, 07:57 PM #31
mphillips_90's Avatar
mphillips_90 mphillips_90 is offline
mphillips_90 is on a distinguished road
Originally Posted by aemravan View Post
Its been literally 5 weeks since I reached out to them wanting to spend my hard earned money and literally have yet to get a response. I am VERY glad I never placed the original parts order I was under the impression I needed..
Sent from my SM-G970U using Tapatalk
Right, I was about to drop money on one of their twin stick t cases cause I just wanted a quick swap before I realized that its really not much effort to gather everything yourself.
The stories on tacoma world right now is pretty sad. Some peoples build have been there since like 2019.
2010 Trail Edition - Work In Progress
2005 4.7 Limited Totaled
1997 SR5
mphillips_90 is offline   Reply With QuoteReply With Quote
Old 02-20-2021, 12:00 AM #32
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Originally Posted by mphillips_90 View Post
From one more member, thank you so much xtremewlr. I replaced my tcase with another electric one last year due to the actuator and now that actuator has frozen up too. I actually took a hammer to it and broke it apart because it got stuck halfway between 2 low and 2 high and I was dead in the water. Have had my fj case sitting around for about a week and waiting on my twin stick kit from low range but I might not even go that route now. I’ve been trying to get up with rst for the Upgraded spring kit and add wiring harness and have been stressed out from reading the thread on the Tacoma forum about his business going under as we speak.
You’ve lowered my blood pressure for sure.
Re: Upgrade spring kit.
So I just did some research on this and everything I'm seeing only points to the gear driven tcases from Toyota needing this upgraded spring kit. I haven't seen anything for the chain driven FJ tcase.
And I haven't felt like it's been needed with mine, at least not yet. I don't know of that same spring can be swapped into the FJ case or not or if it's actually even needed. Kinda like the twin stick. It's nice, it looks cool but I haven't felt like I really NEED to have a twin stick with the option of 2LO. I think I need a rear locker more than I need 2LO or a twin stick honestly.
And yeah, I have one sitting on the side lines too.
And side note - just over 8500 miles on my swap, with the stock, non-ADD front axle. Nothing has blown up yet. Everything works great still. Turned 300k miles on the 4Runner the other day as well.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 05-17-2021, 07:14 PM #33
Hatfield405 Hatfield405 is offline
Hatfield405 is on a distinguished road
@xtremewlr Thanks for all the info!! It's good someone is getting this out there.
Just picked up a new to me 4th gen this winter and have had nothing but problems with the 4x4 system (especially in cold weather). I've been looking at info on this swap off and on for some months now and like everyone one else found the info for RST. Glad I hadn't pulled the trigger on anything yet.
Can you tell me about running a manual FJ case. Can you switch from 2hi to 4hi while in gear/moving? Switching from 4hi to 4lo requires transmission to be in neutral? Why would I need a twin stick? I'm not sure of the advantages of 2lo? Like you said, a locker seems more important. Excuse the ignorance, never owned anything with a manual tcase, just electronic actuators.
Thanks again!
Hatfield405 is offline   Reply With QuoteReply With Quote
Old 05-17-2021, 09:23 PM #34
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Thanks again!
RST has gone out of business because the owner is shady as all hell and screwed people out of money. So you wouldn't be able to go that route anyhow.
My swap is coming up on 14,000 miles now, without any issues. Still works great.
The transfer case works just like it would have in the FJ. You can shift from 2WD to 4HI while moving. Safe max speed is something like 25mph I think.
You are correct, to shift from 4HI to 4LO, you need to come to a full stop and put the transmission into Neutral. Then you are able to shift into 4LO.
IMO, a twin stick is not needed with an automatic. They look cool and work great. But they are better suited and more beneficial in a manual vehicle. I decided not to go twin stick and have no regrets.
Old 05-18-2021, 11:45 PM #35
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
Originally Posted by 4RunnerAquasport View Post
I think the 5th gen case would be the same in all of their manually shifted part-time options. (Early Trail, TRD Offroad, TRD Pro) My 5th gen Limited AWD is a little different than my 03' V8 in that there is no separate switch in the dash for the center diff lock. The t-case may very well be the same as my 03' Full time awd, but with the center diff switch incorporated into the console dial. The base SR5 has the dial but is part time so I'm not sure how that one is set up, and if it would work in the 4th gen.
I wonder if the 5th gen actuators are prone to the same problems, I may have to buy another manual shift for my 5th gen, just in case lol.
That's a center diff switch? I looked at a 5th gen recently and originally thought that's what it was, but it seemed to only be a lock for the dial positions. I just sat in it, no driving, and didn't have time to look closely.
2008 SR5 4WD (@280k!!)
bob3dsf is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 05:10 AM #36
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is online now
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Yea, I probably could have made that a little more clear. Technically in the 5th gen Limited, there is no separate center diff switch like on the 4th gen dash. There is a single dial. It has you switch from 4hi unlocked (Full time AWD) to 4hi Locked or 4 Lo Locked with that dial. And yes you are correct that little button is just a lock for the dial positions.
So basically when you switch from the 4hi unlocked to 4hi Locked, it's doing the same thing as 4th gens diff switch on the dash. It's still electronic servos making the switch in the center diff. That's where I should have omitted the "incorporated" part of my statement.
The manual t-case does not have the electronic servos that go bad. But it stays in 2wd until you move the lever into 4hi, and then the front diff has a system that locks the hubs.
It can be a little confusing. There are threads in here that delve further into a better explanation. I came from the old school manual locking hubs and manual t-case shifters in my old pick ups, so I had to do a little reading myself when I first bought this 5th gen years ago. I may look into putting a manual t-case in my 5th gen Limited in the next year or so also.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is online now   Reply With QuoteReply With Quote
Old 05-20-2021, 03:00 PM #37
bob3dsf's Avatar
Real Name: Bob
bob3dsf's Avatar
Real Name: Bob
Ahhh, ok. I guess I was sitting in a limited. I didn't even look. That dial was the only one I saw.
Old 09-14-2021, 09:45 AM #38
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
Bringing back this glorious thread. Just ordered my T-case from a local yard that will be working on pulling it from the car between today/tomorrow. If all goes well i'll have a T-case in the garage ready for a swap by Thursday this week.
Taking a BIT of a gamble here but I am about 95% certain everything will work out. The T-case is coming out of a 2015 4runner with only 88k miles on it and they are only charging me $214 for the case and the guy is going to try and sneak the shifter into there for free, if not i'll be at $300 total which is still ridiculously low to me. I'll probably be able to offload my factory Tcase for that amount since its still perfectly fine with only 140k miles on it. I had no idea the 5th gen's had a manual shift option for a T-case.. but everywhere i have checked it is showing up as a replacement option for the FJ's, so it should work. Not sure if the shifter is the same or not, but since it has to be modified anyway I don't think it'll be an issue..
Pretty excited to get this done, hopefully by end of the month i'll be on a manual T-case.
aemravan is offline   Reply With QuoteReply With Quote
Old 08-22-2022, 01:20 AM #39
wtcnbrwndo4u wtcnbrwndo4u is offline
wtcnbrwndo4u is on a distinguished road
Bumping this thread back up from the dead to add a key install detail that may help others. I had my manual t-case installed this past week and it's great! However, I don't have a body lift installed.
Instead, what we did was use two 1" spacers and longer bolts on the rear two bolts holding the transmission shifter down. The front left bolt spot was cut off, so only three total bolts holding the shifter (no problems there). But this avoids a body lift, which I do not want to do at this juncture.
Naturally, this causes the shifter to push out of the shifter trim. The simple fix with that is to remove top two layers of the shifter, add a shifter boot, and cover it up. The dash shows you what gear you're in anyways. Note in my picture I ended up cutting around the shifter trim to try to make it fit, without realizing I could've taken off the top two layers of the shifter.
2003 4Runner Limited 4x4 V8, Volant CAI w/ LC100 snorkel, modified C4Fab hybrid bumper with wings, Superwinch Tiger 9500, RSG Angled Sliders, 5100s/885/RCC2.0, TRD Wheels, Duratrac 285s, 1.25" Spacers, RIGd Ultraswing
wtcnbrwndo4u is offline   Reply With QuoteReply With Quote
Old 08-08-2023, 06:46 PM #40
Tonguss Tonguss is offline
Tonguss is on a distinguished road
Originally Posted by xtremewlr View Post
Happy to help, man!
Believe me, I went through all the same shit you have when I first started considering the swap. Figured instead of sending people over to dig through my build thread, I'd just compile the pertinent information here and make it easier for others to find.
Sorry for resurrecting an old post but was the new drive shaft custom made? Or was it a different drive shaft from a different toyota thats'll work. thank you
Tonguss is offline   Reply With QuoteReply With Quote
Old 08-08-2023, 08:58 PM #41
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Front and rear driveshafts are both custom made to fit the new length. There are no other driveshafts you can swap in unfortunately.
Old 08-09-2023, 08:55 AM #42
thegame7 thegame7 is offline
thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice
I wonder what the deal is with GX470 transfer cases. I believe they have a shifter like FJ Cruisers but I am very curious if they are AWD as well. My main concern with getting rid of the stock V8 t-case is losing the AWD feature which is nice for going up to the snow.
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers, DT short headers
thegame7 is offline   Reply With QuoteReply With Quote
Old 08-09-2023, 10:08 AM #43
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
AWD is nice but with a manual shifted tcase, you still have 4HI, which is essentially like AWD. You just can't leave it engaged in dry conditions like AWD, it can cause the transfer case to bind up.
Old 08-09-2023, 10:10 AM #44
Yep exactly. Which is why I'm wondering about the GX470 t-case since it has a manual shifter I think for 4hi/4lo not 2wd/4wd hi-lo like the FJC t-case. Might be a good option for those that want a manual shifter but keep AWD.
Old 08-09-2023, 10:30 PM #45
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Little update to my tcase swap for anyone thinking about doing this.
I have 46k miles on the swap now and have only had 3 issues.
First was breaking the welds on my shifter and having to re-weld it. Not a big deal and my fault for not making it beefier.
Second was I had to replace the input shaft seal on the transfer case as it started leaking. This was on a used tcase with over 130k miles on it when I installed it, plus the additional 40k-odd miles I put on it before replacing the seal. Not caused by overpressure or some other bullshit that has been reported before. No leaks since, pretty straight forward repair. Drop the tcase, pry the old seal out and install the new one and then reinstall the tcase.
Last was the disintegrated OEM plastic shifter bushing. Common problem on these tcases and other Toyota manual shifters, most notably the 1st gen Tacomas. Marlin Crawler sells new Delrin (or something similar) bushings that drop right into the shifter housing. You need their BLUE bushing for the FJ tcase. Replaced that when I replaced the input shaft seal. Link to the seats -> Heavy Duty Seats | Marlin Crawler, Inc.
So far, it's a 100% reliable swap. I can literally go months without worrying wether the tcase will go into 4WD when the time comes. It's a non-issue. Stock front axle is fine and so is the tcase.
Do the swap, you won't regret it.
add , diff , front , swap , t-case
v8 transfer case swap to 6cyl transfer case? V8RUNN 4th Gen T4Rs 23 09-11-2020 01:40 AM
T-case swap in my '00 SR5 fasterdammit 3rd gen T4Rs 4 06-08-2013 02:59 PM
Transfer Case Swap? kylebacc 4th Gen T4Rs 2 02-27-2013 04:33 PM
FJ t case swap 4WD 4RNR 4th Gen T4Rs 2 09-23-2012 04:31 PM
T-Case Swap captwalker87 Classic T4Rs 3 02-22-2006 05:01 PM
