Old 08-01-2021, 09:02 PM #16
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
Tironeous (Build) Thread
5-months of waiting and my Bilsten 6112s have finally shipped! I can hardly believe it! I got a killer price so I had to hold out. That means this weekend I took the plunge and installed my rear suspension (5160 and Icon 2” coils). I figured it would be easier to split the entire project up into two weekends. I’ll install the 6112s and UCAs next weekend and just have a hilarious amount of rake until then.
I’ve never done this kind of work before, but this forum and YouTube provided plenty of confidence. Below are some pictures and measurements.
Stock Measurements (New)
- Front 20”
- Rear 22”
Stock Measurements (16-year old truck)
- Fornt 19”
- Rear 20.5”
Lifted Measurements
- Front - not installed
- Rear - 23”
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 08-04-2021, 01:49 PM #17
tuborg_15's Avatar
tuborg_15 tuborg_15 is offline
tuborg_15 is on a distinguished road
tuborg_15's Avatar
Hi,
Which harness you used for installing the Sony Head unit?
I installed Pioneer AVH-3300BT, with stock amp and sub, but getting some trouble with the sound. while playing a song it gets low , high, plays randomly through different speakers. I am not able to pin point what I am doing wrong..
Cheers
tuborg_15 is offline   Reply With QuoteReply With Quote
Old 08-05-2021, 04:50 PM #18
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
Originally Posted by tuborg_15 View Post
Hi,
Cheers
I’m not sure. I went to Crutchfield and got the harness they offered. I retained my steering wheel controls.
Old 08-07-2021, 03:12 PM #19
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
Really happy with how my lift turned out. Still need to get it aligned but hoping it settles a bit more. Sitting at just around 23” hub to fender at all 4 corners +/- 1/8”.
Front - Bilstein 6112 w/ 650lb coil
Rear - Bilstein 5160 and Icon 2” spring
Wheels - Early Trail Edition (+15 offset)
Tires - 265/65/17 (stock size)
Old 08-07-2021, 10:17 PM #20
montijo505's Avatar
montijo505's Avatar
Looking good!
Old 08-09-2021, 06:56 PM #21
mkrunnersd mkrunnersd is offline
mkrunnersd is on a distinguished road
Hi and nice lift with the 6112s with 650lbs. I have the lower rated springs so mine sits lower 22" and rub only in reverse with my 275/70/17 but my -10 offset doesn't help but looks good stancewise.
Simple questions. What clip do you have set on each side and how is ride?
Mike
mkrunnersd is offline   Reply With QuoteReply With Quote
Old 08-10-2021, 12:33 PM #22
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
Mike
I’ve got it on the second highest (5th) setting on both sides. I also have a 1/4” aluminum spacer on the driver side. There’s still 1/8” of difference between driver and passenger with a full tank of gas. You don’t notice it when looking at the truck.
I’m hoping these settle a bit. The front is currently 1/4” higher than the rear after the alignment. I’m going to drive it like this for 500miles or so before making any adjustments. I may need to move it down a notch (4th position) if it doesn’t level out.
The ride is great. Stiffer than what it was, but not harsh at all. Overall I’m pleased with the results.
Old 08-13-2021, 11:58 PM #23
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
After a few days and an alignment (which called for new inner and outer tie rods on both sides) I had a 1/2” of reverse rake! Definitely not digging the Carolina squat.
I took it apart using the no spring compressor method and lowered it two clips. It’s now sitting at clip 3 on both sides. The front is now 1/4”lower than the rear. To me, that’s perfect. I’ll upload a pic tomorrow. Lighting in my garage sucks.
Old 08-14-2021, 10:28 AM #24
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
Originally Posted by Tironeous View Post
My sub blew so I decided to replace that. It’s nothing too crazy, but fits the factory location and sounds much better. I’m still using the factory amp.
Shortly after the install I realized just how poor the 15 year old JBL speakers sounded compared to the new sub. I decided to replace the fronts with 6.5” Focal components and the rears with 6.5” 2 way speakers. These speakers are highly efficient so I wasn’t worried about the ohm rating being different than factory. Unfortunately, I didn’t take pictures.
Next was the headunit. I wanted CarPlay and looked at a number of units. It seemed too costly to go for wireless CarPlay. My logic was if I’m using it for maps, I’d likely want my phone plugged in anyway to not drain the battery. Also, make sure you get a headunit with a capacitive touchscreen. This is the type of technology used for smartphone displays and not all headunits use this. I’ve always liked Sony products.
Lastly I added a new backup camera. The hardest part was snaking the wires through the tailgate. I eventually got this sorted and the quality it outstanding compared to the factory unit.
Nice install on the headunit. I went with a Pioneer unit with wireless CarPlay. I bought mine from Cruthfield too. I also bought a backup camera as well from them. In hindsight wireless CarPlay is nice but my phone is always plugged in and charging anyway so it's really not needed unless someone makes very short trips.
My unit came with both wireless and wired CaPlay plus Android auto. I ran the two USB connections (CarPlay and Android auto) into the glovebox and never use them since I always use wireless now.
A couple of questions...
1) Where did you run your wired connections to? Did you run them to those aftermarket plus on the center console?
2) I want to no longer use the cigarette lighter to charge my phone or my passengers phone and would like to use one of those USB adapters that fit the center console unused holes. There are so many on Amazon and its hard to tell any are good or how well they charge a newer phone.
Do you have a recommendation on which ones to use?
3) I am still using the stock speakers and have to admit it sounds pretty damn good for stock. I know you had a blown speaker but do you think that still wold be an improvement over the stock ones?
thanks!
zguy1 is offline   Reply With QuoteReply With Quote
Old 08-14-2021, 01:16 PM #25
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
The promised picture. Liking this look and the way it rides.
Old 08-14-2021, 01:30 PM #26
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
thanks!
I debated on wired vs wireless car play for a while. I pretty much only use the map for long trips where I'll have my phone plugged in anyway. Otherwise I just use bluetooth around town. Wired was the right choice and I saved some money. I'm sure you'll enjoy the Pioneer unit!
1. My radio had two wired connections for USB. USB 1 does CarPlay and USB 2 does other file types (FLAC audio, pictures for background, etc). I ran them to the center USBs that I added.
2. The USB adapters I used have 1 USB extension and 1 powered circuit. I connected the USBs on the back of the headheadunit to the USBs on the plugs. I used some electrical take to ensure good contact. For the charging outputs I ran the wires under my dash and used an add a circuit fuse tap. I grounded it on a screw in the footwell.
3. The sub was blown so it had to be done. After upgrading that I realized just how bad the rest of the speakers sound. Your truck is likely about 15 years old. Even cheap aftermarket speakers will sound night-and-day better.
Old 08-14-2021, 01:54 PM #27
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
Stock
Trail Wheels with 265/65/17 tires
Lifted
Bilstein 6112 with 650lb Spring. 3rd circlip both sides. 1/4” spacer on driver side
Total Chaos UCAs
Ground to fender gains:
Front: 4"
Rear: 2 1/4"
I suspect my front had sagged about an inch. Maybe more. Just look at it!
There's about 1/8" of driver side lean depending on how much gas I have. A 3/8" spacer (instead of the 1/4” installed) would be perfect.
Old 08-14-2021, 02:18 PM #28
zguy1's Avatar
zguy1's Avatar
Thanks for the link to the USB adapter. The Pioneer unit has been great so far but would like to run the wired CarPlay port to the center console in case I want to use that instead of going wireless. Plus it is a cleaner solution then leaving a long USB cable in the glovebox.
Was the supplied USB cable long enough to make it from the back of the radio to the center console where you installed the adapter or did you need to buy a different length cable?
Old 08-14-2021, 02:56 PM #29
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
It was long enough to reach the back of my unit. The unit itself has a 6” cable or so coming out of the back of it. I carefully tucked the wires up under the console and it all reached.
Old 08-14-2021, 03:11 PM #30
FLT4R78 FLT4R78 is offline
FLT4R78 is on a distinguished road
Great to see your progression with it! I just bought a 2003 and look forward to some subtle updates
FLT4R78 is offline   Reply With QuoteReply With Quote
140 , 868 , approved , build , thread
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
