Old 02-06-2021, 04:04 PM #1
jcampo788's Avatar
jcampo788 jcampo788 is offline
Real Name: Call me "Campo"
jcampo788 is on a distinguished road
jcampo788's Avatar
Well, this happened today...
2004 T4R, V6, 316K, just started doing this today. The issue had progressively gotten worse over the last week.
Got it started finally but had to pump the gas, which makes me think it’s a fuel issue?
https://www.youtube.com/watch?v=JaASPQ61CDI&feature=youtu.be
jcampo788 is offline   Reply With QuoteReply With Quote
Old 02-06-2021, 05:32 PM #2
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
How did it run after it finally started? Any error codes stored?
I've been posting my troubleshoot here, which involved ruling out the fuel pump. This $32 test kit worked well and is reasonable cost:
Amazon.com: BETOOLL Fuel Pressure Test Kit 0-100PSI with 9.49,7.89,6.30 Fuel Line Fittings: Automotive
No other tools required, be sure to:
1.) Remove the fuel pump relay and crank the engine to relieve fuel pressure. Easy pull from the under-hood electrical panel and clearly labeled under the lid.
2.) Clean the fuel line at both sides of the connector before disconnecting it to avoid dirt getting into the fuel system.
waypoint is offline   Reply With QuoteReply With Quote
Old 02-06-2021, 07:01 PM #3
jcampo788's Avatar
jcampo788's Avatar
No error codes. Runs great. EFI fuse?
Old 02-06-2021, 07:16 PM #4
waypoint's Avatar
waypoint's Avatar
There are three relays (EFI, CKT OPEN, FUEL PUMP) and the 20A EFI fuse involved in running the fuel pump on my 2007, likely yours is the same. See my thread on P0230 (and now P0335) for details on how I approached the troubleshoot, might help a bit.
Wouldn't hurt to do what I did, pull each one (gently, straight up from the socket so you don't deform the pins) and inspect the pins for corrosion or burn marks. Fuel pressure test will tell the story and that test kit I posted is cheap.
Old 02-07-2021, 11:07 AM #5
jcampo788's Avatar
jcampo788's Avatar
I am 90% sure it is a fuel issue...
Cold start this AM in 10 degree temps.
First start, no issue at all.
Turned it off...
Second start, she had a harder time starting but started after a few extra cranks.
Turned it off...
Third start, I got this (below video), and had to floor the gas to get her to start, but she started.
4Runner Starting Issue Video #2 - YouTube
Still no code lights...
Thoughts?
Old 02-07-2021, 01:49 PM #6
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
So not to discount or disagree with your hypothesis, but keep in mind that every time you start and stop the engine without letting it run a few minutes, you're taxing your battery and in the temps you report, it's probably not happy to begin with. Just my $.02, best of luck to you.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
gas , issue , makes , started , today
This happened today, I almost missed it. 2ndhandyotaman 3rd gen T4Rs 1 09-14-2019 10:39 AM
Something BAD happened today SSt4r 4th Gen T4Rs 9 11-21-2018 04:59 PM
Something weird happened today Utopia 4th Gen T4Rs 3 12-24-2016 01:18 AM
So this happened today... lewisp 3rd gen T4Rs 13 07-25-2014 04:44 PM
Miracle happened today 03_4x4Runner 4th Gen T4Rs 3 10-07-2013 02:19 PM
