02-14-2017, 12:09 PM
Ebay's freedom offroad uca? Updated!
Just stumbled on these uca's from freedom off road while searching through ebay. Design looks the same as camburg ball joints uca but with a little difference with sensor wire bracket. I contacted freedom this morning to inquire about there ball joints and they to be proprietary. Uca's are priced around 290 and ball joints are 35. I might pull the trigger on these tonight. Look at this on eBay Front Upper Control Arms for 2-4" Lift For 2003-09 4Runner 2007-14 FJ FO-T702FU | eBay
Reason: Forgot link
02-14-2017, 01:25 PM
Never head of the brand but many of these companies share resources behind the scenes so your suspicion may be right.
I personally went with SPC and I'm very content with them.
2003 4Runner 4.0L 2WD - Fox 2.5 Coilvers, SPC Control Arms, Rear OME coils with Fox shocks, 17" Pro Comp Wheels on Pro Comp 285/70R17, N-Fab Steps, more to come!
02-14-2017, 01:27 PM
Real Name: Summit
Real Name: Summit
Im interested as well they look decent and have a lifetime warranty... Do it OP so we can see how good they are
02-14-2017, 01:38 PM
It's definitely going to happen. Also I ask where they where manufactured, he replied Taiwan. Not sure if that's better or worse than China
02-14-2017, 04:49 PM
They keep changing the product name
b/c they've been knocked off ebay a bunch of times. Camburg sued um as well. Heres a bunch of threads about those..
https://www.google.com/search?q=ebay...r+control+arms
02-14-2017, 05:55 PM
Taiwan is much better than china for manufacturing. AS an example a chinese motorcyle is total garbage, but some taiwanese manufacturers are decent.
02-14-2017, 06:27 PM
Not sure man for the longest I always thought taiwan was china. It may still maybe
2005 4Runner SR5 V8, HCF delete, Bilstien 5100's, FJ coils up front, Wheelers t12 in the rear, Freedom Offroad UCA's, SCS Ray 10's, LT265-75-16 Good Years Wranglers
02-14-2017, 07:36 PM
08' 4Runner SR5 4WD V6 Level 8 MK6 wheels//Kenwood DDX9903s//JL 10W3v3 on 500/1//LEDs//ICON Ext Coilovers FR//Metaltech LT Rear Springs w/ Dobinson LT Shocks//JBA UCAs//spidertrax//5th gen brakes in front//295/70/17 Cooper Maxx//SS brake lines// http://www.toyota-4runner.org/4th-ge...ld-thread.html
02-14-2017, 07:48 PM
You know they are crap when they have the sticker facing the wrong way... Just saying.
All the other aftermarket UCA manufacturers have lifetime structural warranties, I doubt these have a warranty for the bushings and ball joint. That would be a good question to ask before purchasing.
02-14-2017, 08:44 PM
Originally Posted by jfry008
Geez even cheaper...thanks, have you reviewed them?
02-14-2017, 08:54 PM
Are they caster correcting?
Sent from my SM-G920V using Tapatalk
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
02-14-2017, 10:04 PM
They are Camburg replicas. Yes, they're caster correcting. They come with Tacoma greasable balljoints. No problems with them so far.
02-15-2017, 10:31 AM
Thanks for the response. Do you happen to know how many degrees of caster correction by any chance? Not sure if you did a pre and a post installation alignment to find that info out but thought I'd ask anyway.
02-15-2017, 03:43 PM
They also make some cheap coilovers that i have been eyeing but am scared to pull the trigger
Sent from my SM-N910V using Tapatalk
02-15-2017, 05:54 PM
I'm not sure of the exact amount. You could message the seller perhaps.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
