Old 02-06-2021, 04:12 PM #1
azgold azgold is offline
azgold is on a distinguished road
Brake Booster Accumulator Install Question.
2006 4runner @ 226K
Is there a procedure for installing a new Accumulator? Do you fill it with fluid or leave it dry, as it came from the dealer?
azgold is offline   Reply With QuoteReply With Quote
Old 02-07-2021, 07:39 AM #2
toyo's Avatar
toyo toyo is offline
Real Name: Steven
toyo will become famous soon enough
toyo's Avatar
Real Name: Steven
Install it dry. After the installation is complete perform the proper bleed procedure and then inspect for any leaks.
2008 4R LTD V8 4WD, ICON Stage 3, TRD Pro Wheels, GOBI Rack, TRS HID Swap along with too many other mods to list here!
toyo is offline   Reply With QuoteReply With Quote
Old 02-07-2021, 03:33 PM #3
P_nlsn's Avatar
P_nlsn P_nlsn is offline
Real Name: Parker
P_nlsn has a spectacular aura about P_nlsn has a spectacular aura about
P_nlsn's Avatar
Real Name: Parker
Originally Posted by azgold View Post
2006 4runner @ 226K
As @toyo said: install it "dry" (as it came from the dealer), then fill the reservoir and turn the key on so the pump runs while making sure the reservoir stays full
Here's this too, incase it helps: https://www.toyota-4runner.org/3560752-post10.html
4wd V6 '03 Sport w/ 340k miles (175k engine swapped @ 326k) // 3" Suspension Lift + 3" Body Lift on 35" K02's
@toto.runner // Build Thread // Engine Swap Write-Up
P_nlsn is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 09:22 PM #4
Thanks for your time guys ! I`ll give it a go
accumulator , brake , dry , fluid , leave
Tips on power brake booster install! 4Runner4TW 3rd gen T4Rs 28 05-12-2022 10:44 PM
Brake Booster/Accumulator Failing? nm_alien 4th Gen T4Rs 15 02-06-2022 07:01 PM
Brake Booster/Accumulator/Master Cylinder Assembly Replacement eng208 4th Gen T4Rs 32 07-25-2021 02:55 AM
Hydroboost Brake Booster Accumulator run/cycle history to failure JB. 4th Gen T4Rs 22 07-17-2018 05:23 PM
Brake Booster install Dathornt 3rd gen T4Rs 2 02-01-2013 02:41 PM
