Old 02-08-2021, 10:07 AM #1
zach1288 zach1288 is offline
zach1288 is an unknown quantity at this point
Water in oil
Hello,
I have a 2007 v6 with 140k miles. I've owned the vehicle for about 4 years. This vehicle was owned by a family member from new before I bought it. It has been meticulously maintained from the beginning.
I recently had the oil changed by my mechanic. He said there was some water in the oil and to keep an eye on it and maybe change the PCV valve. I changed the PCV and the old one had some grime in it, but still rattled.
There is no white smoke, no check engine, runs fine, no oil mixed in coolant, coolant level is consistent.
I just checked the oil on the dip stick and there is no water or separation, it looks like pure clean oil.
Do you have any ideas?
Thank you,
Zach
zach1288 is offline   Reply With QuoteReply With Quote
Old 02-08-2021, 10:21 AM #2
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
Could've been sitting a while maybe? The head gasket issues were resolved in 2005, not to say there could potentially be a problem, not as common though. What does the coolant look like, level and condition?
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 02-08-2021, 10:22 AM #3
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
You'll want to ask your oil change guy what evidence of water he saw.
If you're in a region where temps are cold, some carmel-colored accumulation at the oil fill cap is normal.
The oil in the crank case should still be normal black when changed...if the oil is emulsified with water mixed in, you have a problem.
waypoint is offline   Reply With QuoteReply With Quote
Old 02-08-2021, 10:31 AM #4
Coolant level is normal and is bright pink, no trace of oil.
Old 02-08-2021, 10:32 AM #5
He said when he drained the oil he saw a little bit of water/milky substance.
Old 02-08-2021, 11:18 AM #6
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
BlackStone Labs has an oil analysis service that I like to use when I change my oil. They can tell you what is in your oil, like wear metals, fuel, coolant, detergents, etc. Since the oil is drained, it may be difficult to get a a sample from this past change.
Also the coolant will usually look nice on the top under the rad cap and in the expansion tank, so this isn't the best place to look for any intrusion. A shop recently put green coolant in my radiator with pink already in there. It was a total mess that I just fixed this weekend, but under rad cap was green, expansion tank pink, and out the drain it came out orange. Point being that a peek under the rad cap doesn't tell the whole story. Can try draining a little of the rad and see what that looks like.
y=mx+b is offline   Reply With QuoteReply With Quote
Old 02-12-2021, 12:38 AM #7
2UZ-BOIII 2UZ-BOIII is offline
2UZ-BOIII is on a distinguished road
+1 for getting an oil sample analyzed at Blackstone Labs.
In the meantime, you could check for exhaust gasses in the coolant system with a cheap test kit from almost any auto parts store.
As far as your "no white smoke" observation, you would be surprised how bad a head gasket can be without any visible smoke in the exhaust. I just went through the pain of diagnosing one in a 2UZ-FE in a Lexus LX470 (Another Misfire Thread - LX 470 | IH8MUD Forum) that was about as bad as it could be without any white smoke, although the misfire was very noticeable.
Since you weren't able to see the oil yourself and your mechanic didn't save any to sample, hopefully it was just a bad observation and everything is ok.
2UZ-BOIII is offline   Reply With QuoteReply With Quote
changed , coolant , oil , pcv , water
Leak from water inlet/water pump joint - V8 GLP 4th Gen T4Rs 5 01-12-2017 10:52 PM
Engine Whine After Water Water/Mud Exposure - Alternator??? Patton 3rd gen T4Rs 9 05-04-2016 10:42 PM
Salt water/fresh water fishing gear Robmills72 For Sale: Non-T4R Items 0 08-07-2013 12:08 PM
Will a tail pipe draw water if it is barely under water on a boat ramp? jow 4th Gen T4Rs 9 05-08-2013 12:53 PM
Help! New timing belt, water pump, and spark plugs = higher water temps??? vthokie 3rd gen T4Rs 15 05-16-2011 10:59 PM
