Old 02-11-2021, 03:20 AM #1
joshik joshik is offline
joshik will become famous soon enough
New OEM LCA Bushings - Post Install
I just went through a LCA bushing replacement. After my last ordeal with the Superpro LCA (if you've seen my previous thread) I decided to just go with new bushings in the OEM LCA. I was going to go with poly bushings but after reading about poly vs rubber/OEM, I decided OEM is the way to go. Not as harsh and less maintenance and possibility for noise.
I installed the LCA back in but have yet to lower the 4r back down. I'm waiting for a new tie rod bellows boot as I tore one while replacing the ITR. My old bushings were original... 270k miles on them! They were def worn and the LCA moved super easy when detached from the spindle.
Now, after I torqued the cam bolts to 100ftlbs I can't move the LCA at all! Like I mentioned, I have not yet lowered the 4r back down. Is this normal?
What part of the bushing does the movement? The side washer are attached to an inner tube and the rubber bushing spins around the center tube and between the outer washers?
Also, I noticed that there was a VERY slight gap between the bushing washer and the mount of the foward most mounts. After the tightening, its gone of course. Is this normal too?
2003 4Runner Limited 4wd V8. JBA UCA, Dobinsons MRA Front Coilovers, Dobinsons MRA Long Travel rear. Cooper AT3 XLT 285/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
joshik is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 01:08 PM #2
montijo505's Avatar
montijo505's Avatar
That’s why poly are better design, they have an inner sleeve and allow movement up and down. The rubber stock ones don’t allow much movement.
https://www.youtube.com/watch?v=xSu9ZR4byc4&feature=youtu.be
Old 02-11-2021, 01:24 PM #3
**update** i watched the video. So the OEM bushings are not meant to allow a wide range of motion of the LCA?
I hear various things about harshness the and then the propensity for poly bushings to squeak. There are no zerk fittings so not sure how those would get lubed. I'm a "low maintenance" kinda guy. That's why I went with a sealed balljoint design on the UCA vs uniball. I already hate lubing the driveshaft joints to clear the clunking.
Old 02-11-2021, 03:24 PM #4
Piggity Piggity is offline
Piggity will become famous soon enough
You need to jack the truck back and up loosen the LCA bolts. The stock OEM rubber bushings are designed to be tightened up to the factory torque specs "when the weight of the vehicle is on them".
Poly bushings are different and are able to torqued at ride height or up in the air - it doesn't matter like Monti said.
Past: 06' Limited 4WD V6 Nautical Blue Metallic
265/65R18 Cooper A/TW tires with TT - 2018 Forest River 201BHXL
Present: 08' Tundra Limited
33" Duratrac, spacer Lift with TT - 2022 Keystone 252RD
Piggity is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 03:32 PM #5
yep, did some more reading and i did just that just now. I loosened the bolts, lowered it then tightened them. Ill be going in for an alignment lil later today
learned something new today!
Old 02-11-2021, 03:59 PM #6
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
This is why I chose Super Pro bushings for my install, they allow up and down movement as you would expect and I believe their advertising in that they are superior to "poly".
The OEM, as you have discovered, allow movement only by "twisting" the rubber bushing, that is held in place by the design and torque specs, not ideal in my opinion for "proper" suspension movement.
Old 02-11-2021, 04:03 PM #7
agreed. I'll run these for now. Maybe, down the road, i'll change to superpro bushings :P
Old 02-11-2021, 06:19 PM #8
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
The main difference between poly and OEM style rubber bushings, like @montijo505 mentioned, is how they articlate. The poly bushings rotate about an inner shell, whereas OEM style rubber bushings rotate through internal torsion within the bushings.
You may have noticed the rubber bushings have a central rubber cylinder around the inner sleeve, with two rubber connection blocks to the outside rubber ring and bushing shell. Since the rubber isn't fixed all around, when your LCAs need to go up or down, those two rubber connections flex within the bushing. This is why, to @Piggity 's point, you want the vehicle on the ground when torquing the LCAs. You don't want the ride height position of the bushing to be already under internal torsion, since the suspension compresses as it supports the weight of the vehicle. Instead, torqueing with the vehicle supporting its own weight sets the bushing "home position" to ride height and not the jacked up height.
On the other hand, the poly bushings are able to rotate around this central sleeve/tube that is greased.
The inside of the Whiteline bushings are knurled to hold the grease along the inside, with a smooth section at the extremities of the hole to act like a seal. Don't mind the green grease, that I just used as lube when pressing the bushings in. The black greased goes around the tube and is retained by the internal knurles.
Energy Suspension bushings don't have as good of a "grease retention" system as the Whitelines, and this is why they (and other poly bushings) get a bad reputation for squeaking- poor lubrication. The squeaking is the unlubricated poly sliding across the metal. I have had no issues with the Whitelines squeaking, and they've been on for about 8k miles. Whitelines recommends regreasing every 15k and had even mentioned a zerk could be drilled if I wanted.
y=mx+b is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 10:52 PM #9
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
That’s good information to know after I just bought new OEM LCA’s haha. Didn’t read about any real good OEM alternatives for the Ball joints and the OEM’s weren’t that much more than rebuilding myself.
Unfortunately first I’ve heard of the articulation factor and the video Montijo posted explains it very well. Oh well, I’ll install my new OEM LCA’s, SPC UCA’s and consider maybe rebuilding mine that I remove with the Whiteline Poly bushings. Doing it for the “Floaty” feel I have. Guess it can’t be any worse than what I have now. More things to obsess about lol.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 02-19-2021, 02:27 AM #10
Yeh I learned a lot too.... the diff between the poly vs rubber. I did read someones post that had poly (cant remember which ones) bushings for a while and he was going back to rubber for various reasons.
So the 4r drives so nice now! New bushings, new ITRE and new OTRE make a world of a difference. The steering is so much tighter and just feels awesome on and off road.
I went out to Anza Borrego for the weekend and did a ton of wheeling around Anza and up Oriflame to Julian. The 4r wheeled great. Did i lose travel or is my travel restricted in my front end... maybe but I'll probably be OK with it for now.
Also.. my front end is taller now! It is noticeably taller which means the rubber bushings are loading up and holding up the front end a little bit. You can tell by looking at it but also I can tell by looking at my CV Axles. When I first lifted my 4r with the 6112s (maxed height) I thought, man what are all these guys talking about with the CV boots rubbing, extreme CV angles, diff drop, etc, because my Axles were not that angled. Now i know why. Do you think if I went poly my front end would be lower?
Old 02-24-2021, 01:41 PM #11
I'm not sure why the ride height is different. It's entirely possible that the bushing is holding it up more, hence the ride height is higher but I've never heard of that. I have more experience in lowered cars than 4x4's...lol
Old 02-24-2021, 01:58 PM #12
hm... actually come to think of it... maybe it doesn't make sense. If I tightened (and the alignment shop during alignment) the cam bolts when the car was on the ground, the weight of the car would have been fully supported by the coilovers. Then by tightening the cam bolts the bushings are set in place at the resting height of the car... then it goes up and down from there putting load in the bushings.
Old 02-26-2021, 08:06 PM #13
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
It could be slightly higher. When the truck is lifted in the air, it might take a minute (or longer) for the springs to settle back down, so maybe this is the case. I wouldn't be surprised if that's why sometimes when I park, my front end looks taller and sometimes it sits correctly. It might be how I tightened those bushings when I did the daystar lift.
gaber6 is offline   Reply With QuoteReply With Quote
Old 03-01-2021, 11:53 AM #14
Yeah this correct. I assumed the OP knew to move the car back and forth, drive it down the road, or just push the front up and down to get the suspension settled.
Anytime I adjust my coilovers on my IS300 I drive it down the road to settle the suspension, then I measure the ride height L to R.
Old 03-01-2021, 10:03 PM #15
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
I will point out that the "twisting" of the rubber bushing is a calculated factor in suspension and honestly bushing design in general. It's a sort of "pre-load" to help the suspension return to a neutral position (at least that's the story per text books and suspension dynamic papers). It's why almost all vehicles will tell you to torque most suspension components like that with the vehicle resting on the ground.
All that being said, I've been pretty happy with my poly-bushings in my LCAs, I haven't had any noise or issues; the only real thing I have noticed is that they don't move as freely as they did when I first installed them (i.e. when I am unbolting the LCA to clean my heims on my suspension lift they take more force to push them down than they used to but still negligible in the long run.) I honestly get more noise from the heims in my suspension than the poly bushings in the LCA, Sway Bar bushings and links.
BlackWorksInc is offline   Reply With QuoteReply With Quote
back , bushing , bushings , lca , oem
Cost effectiveness of LCA vs bushings if having a shop install Doc3g 3rd gen T4Rs 19 01-14-2021 01:16 AM
How many inches of jack stand lift do I need to install lift spacer/bushings? 4Runner4Runner4 4th Gen T4Rs 3 03-21-2020 07:37 PM
Lift install soon.. . what suspension components/ bushings should I replace? masphx 3rd gen T4Rs 15 09-27-2019 11:34 AM
Front suspension bushings install in 626 griplimited So Cal 1 08-05-2015 10:08 PM
Lift Install Issues... endlinks, bushings, corrosion trailrazer 4th Gen T4Rs 3 06-20-2012 10:54 AM
