Old 02-11-2021, 10:13 AM #1
jcampo788's Avatar
jcampo788 jcampo788 is offline
Real Name: Call me "Campo"
jcampo788 is on a distinguished road
jcampo788's Avatar
Driver’s side lean on “replaced” stock suspension/front end?
Recently had a bunch of suspension and front end work done. No special parts, just what my trusted shop recommended for replacement.
I’ve now noticed that with a full tank of gas the drivers side is .75-1” lower in the rear than the passenger side. The front is equal left and right. With an empty tank it’s way less noticeable. I know drivers side lean is common with aftermarket lift kits, but, should I be worried about .75”-1” of the classic “driver’s side lean” with a “reworked OEM” suspension?
I really don’t care about the looks of it...more worried about wear and tear on my beloved ride.
Thanks again, all!
jcampo788 is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 10:32 AM #2
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
Totally normal. Some never mess with it, others obsess over it. Won't hurt a thing
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 10:39 AM #3
Heffernan's Avatar
Heffernan Heffernan is offline
Heffernan will become famous soon enough
Heffernan's Avatar
Normal, unfortunately.
I plan on adding a Toytec 1/4" spacer on the front and one of those OME trim packers in the rear to help get the driver side a little more equal to the pass side.
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
Heffernan is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 11:13 AM #4
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
I cancelled my lean with spacers in the rear. I also have them up front but on both sides as I prefer symmetry in the ifs, so the lean is dealt with on the rear end.
Old 02-11-2021, 11:16 AM #5
jcampo788's Avatar
jcampo788's Avatar
Thank you so much, everyone. I was having a panic attack this AM (as I so often do over any little self-perceived issue with my beloved T4R).
Old 02-12-2021, 01:22 AM #6
702tripgen 702tripgen is offline
702tripgen is on a distinguished road
Order an ome trim packer for the driver rear, shouldn't take more than hour total to install and $20. Will bring it up about 1/2"
2005 Limited 4X4 V8 36,000 original miles. 265/70/17 BFG KO2s, Front: Bilstein 5100s set to 3rd perch with stock springs. Rear: OME 895E springs and driver OME trim packer driver side with 5100 shocks. 2" overall lift.
702tripgen is offline   Reply With QuoteReply With Quote
end , side , suspension , tank , worried
Driver Side Lean 4Runnin4Fun 5th gen T4Rs 19 01-29-2023 11:52 AM
Driver side lean octanejunkie 3rd gen T4Rs 25 11-15-2021 09:31 PM
Driver's Side Lean - Even After Suspension Overhaul dommmmyg 3rd gen T4Rs 8 01-05-2020 09:52 PM
Driver side lean? jmv7680 4th Gen T4Rs 13 07-31-2019 03:36 PM
driver side sag/lean jmeeller 3rd gen T4Rs 18 12-01-2014 11:36 AM
