02-11-2021, 10:13 AM
Real Name: Call me "Campo"
Driver’s side lean on “replaced” stock suspension/front end?
Recently had a bunch of suspension and front end work done. No special parts, just what my trusted shop recommended for replacement.
I’ve now noticed that with a full tank of gas the drivers side is .75-1” lower in the rear than the passenger side. The front is equal left and right. With an empty tank it’s way less noticeable. I know drivers side lean is common with aftermarket lift kits, but, should I be worried about .75”-1” of the classic “driver’s side lean” with a “reworked OEM” suspension?
I really don’t care about the looks of it...more worried about wear and tear on my beloved ride.
Thanks again, all!
02-11-2021, 10:32 AM
Real Name: Elliott
Real Name: Elliott
Totally normal. Some never mess with it, others obsess over it. Won't hurt a thing
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
02-11-2021, 10:39 AM
Normal, unfortunately.
I plan on adding a Toytec 1/4" spacer on the front and one of those OME trim packers in the rear to help get the driver side a little more equal to the pass side.
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
02-11-2021, 11:13 AM
Real Name: Elliott
Real Name: Elliott
I cancelled my lean with spacers in the rear. I also have them up front but on both sides as I prefer symmetry in the ifs, so the lean is dealt with on the rear end.
02-11-2021, 11:16 AM
Thank you so much, everyone. I was having a panic attack this AM (as I so often do over any little self-perceived issue with my beloved T4R).
02-12-2021, 01:22 AM
Order an ome trim packer for the driver rear, shouldn't take more than hour total to install and $20. Will bring it up about 1/2"
2005 Limited 4X4 V8 36,000 original miles. 265/70/17 BFG KO2s, Front: Bilstein 5100s set to 3rd perch with stock springs. Rear: OME 895E springs and driver OME trim packer driver side with 5100 shocks. 2" overall lift.
