Old 02-11-2021, 02:59 PM #1
jcampo788's Avatar
jcampo788 jcampo788 is offline
Real Name: Call me "Campo"
jcampo788 is on a distinguished road
jcampo788's Avatar
Adding a USB outlet...which system to tap?
Adding a USB outlet to the center console of my 4Runner...need MORE POWER OUTLETS!
Should I tap into the existing 12V outlet's wiring system or the cigarette lighter wiring system?
USB outlet is the following:
Amazon.com: Quick Charge 3.0 USB Car Charger, BAODANTECH 12V/24V 36W Aluminum Waterproof Dual QC3.0 Fast Charge Socket Power Adapter Outlet with LED Voltmeter for Marine Boat Motorcycle RV Golf Cart (Blue): Electronics
Again, thank you EVERYONE for all the help with my T4R!
jcampo788 is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 03:10 PM #2
Syr4RinNC's Avatar
Syr4RinNC's Avatar
I did the cigarette lighter - no issues and easy to do
Old 02-11-2021, 03:15 PM #3
jcampo788's Avatar
jcampo788's Avatar
Awesome. Can I tap into those and still retain the functionality of the lighter (even though I am a non-smoker)?
Thank you for your help!
Old 02-11-2021, 03:59 PM #4
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
Another option is to use a fuse tap and ground out on a chassis bolt. There’s one under the lower driver side panel near where you’ll be tapping into a fuse.
10 Pack - EPAuto 12V Car Add-a-circuit Fuse TAP Adapter Mini ATM APM Blade Fuse Holder Amazon.com: 10 Pack - EPAuto 12V Car Add-a-circuit Fuse TAP Adapter Mini ATM APM Blade Fuse Holder: Automotive
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 05:07 PM #5
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
That is the easiest and most convenient. Yes you retain it as long as you don’t cut sever the connection to it.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 05:53 PM #6
gmhotch gmhotch is offline
gmhotch is on a distinguished road
Just order this and swap it out. SO much better and super easy to do.
Ashtray Kit OEM
Amazon.com: TOYOTA 74110-35010-B0 Ashtray (Kit), 1 Pack, Black: Automotive
2004 4Runner
gmhotch is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 11:13 PM #7
pauldub pauldub is offline
pauldub will become famous soon enough
I tapped into the lighter socket's wiring. Easiest way.
pauldub is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 11:36 PM #8
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Yea i just used tap splices/ scotch locks
https://www.youtube.com/watch?v=g9gja0-Popk
Old 02-12-2021, 12:57 AM #9
BagiMT's Avatar
BagiMT BagiMT is offline
BagiMT will become famous soon enough
BagiMT's Avatar
If you want to charge anything with the car off you need to do the 12V outlets mod (Toyota 4Runner Constant Full Time 12V Power Outlet Mod) or do a fuse tap to one of the spots that always have power. I did both (mod to have cigarette lighter sockets always on and fuse tap for USB charger), but fuse tap might be easier.
Black 2008 Sport V6 4WD | Toytec BOSS 3/2 | JBA UCA | BFG KO2 255/75/17 | Rocksteady Skids | White Knuckle Sliders | TJM Front Bumper | Superwinch
BagiMT is offline   Reply With QuoteReply With Quote
Old 02-12-2021, 01:30 AM #10
702tripgen 702tripgen is offline
702tripgen is on a distinguished road
As said, skotch lok off existing 12 volt outlet and be done. Super easy!
2005 Limited 4X4 V8 36,000 original miles. 265/70/17 BFG KO2s, Front: Bilstein 5100s set to 3rd perch with stock springs. Rear: OME 895E springs and driver OME trim packer driver side with 5100 shocks. 2" overall lift.
702tripgen is offline   Reply With QuoteReply With Quote
Old 02-12-2021, 05:59 PM #11
toyoman25's Avatar
toyoman25 toyoman25 is offline
toyoman25 is on a distinguished road
toyoman25's Avatar
Yes, How my setup is...have no no issues
Toyo is my Name and My Ride
toyoman25 is offline   Reply With QuoteReply With Quote
Old 02-12-2021, 09:35 PM #12
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
The factory wiring may not be able to handle that much current. If someone plugs into the lighter socket and the usb outlet you could burn the wire.
Use an add a circuit and run a dedicated wire to the usb outlet
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 01:30 AM #13
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Previous mentioned idea of add a fuse is great. I prefer fused / home run wiring. Easily reversible. Easy to trouble shoot.
I avoid half tap wiring. It can cause future headaches. Running new wire is not difficult.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 12:14 PM #14
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
There’s writeup with pics linked in my sig.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 01:10 PM #15
04rnr's Avatar
04rnr 04rnr is offline
04rnr is a jewel in the rough 04rnr is a jewel in the rough 04rnr is a jewel in the rough
04rnr's Avatar
Ashtray Kit OEM
Has anyone done this mod BUT replace this to with the cig lighter ? Quick Charge 3.0 Car Charger, CHGeek 12V/24V 36W Aluminum Waterproof Dual QC3.0 | eBay
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
04rnr is offline   Reply With QuoteReply With Quote
adding , outlet , outlets , system , usb
Adding USB outlet in glovebox N/A 5th gen T4Rs 15 09-26-2017 11:36 PM
Adding 12v Outlet CXS 4th Gen T4Rs 7 12-25-2015 10:25 AM
Adding 12V outlet to the back of a 97? Menace Kustoms 3rd gen T4Rs 5 08-06-2014 05:59 AM
Adding USB outlet in glovebox N/A 5th gen T4Rs 0 02-07-2014 10:51 AM
Adding Power Outlet (120v) Tigerrob20 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 03-11-2013 02:18 AM
