Old 02-25-2021, 12:19 PM #16
m85476585 m85476585 is offline
Real Name: Matt
m85476585 will become famous soon enough
Real Name: Matt
I'll echo the advice to remove the radiator. I didn't put a hole in mine, but leaning on it opened up a leak.
For the crank pulley, I wrapped the serpentine belt around the pulley so it jammed against itself, and looped the other end over a suspension mount. Basically a DIY strap wrench. I wouldn't recommend it, so if you can get a tool definitely do that.
Getting to the timing belt was the most time consuming part. After that, everything went back together quickly.
2007 V8 Limited 4WD
m85476585 is offline   Reply With QuoteReply With Quote
belt , i’m , job , timing , vehicle
3rd Gen Timing Marks for Timing Belt Replacement FTW1996 3rd gen T4Rs 4 10-01-2015 04:00 PM
Timing Belt Tensioner: Should I replace it when doing the timing belt change? Lugnutz 3rd gen T4Rs 14 05-12-2011 12:58 PM
Aisin timing belt kits vs. Dayco Timing Belt Kits drz Maintenance/Detailing 1 10-11-2010 06:42 PM
