02-12-2021, 09:08 PM
#16
Originally Posted by Burt
I had issue with '08 rear latch over 4 years ago, only in sub freezing temps.
Simply soaked latch down with WD40, no problems since.
i had to replace the rubber button cover 2 year ago. I hear excessive summer heat can ruin this button cover. Got replacement off Amazon for $12 and even came with small angled screw driver needed.
Used my rear hatch this morning cold when 9 degrees... no problems.
Hope this helps.
Thanks.
02-13-2021, 04:17 AM
#17
Originally Posted by Ralph Blake
Well it was 16 F today i had a ton of food stuff in the parking lot of my local Walmart, after fighting people through the store, as a BIG ice and snow storm on the way, then i am standing behing my "trusty" 4Runner, trying and trying to get the hatch open had to just jam everything into the backseat.
Many people were loading their autos and trucks, and looking this fool trying to open his rear hatch having to give up and jam everything into the back seat.
You bet i felt let down and really POed with Toyota poor design.
Why didn't you just roll down the back window?
07 SR5 4x4
02-13-2021, 08:36 AM
#18
Well, you know, cause; Toyota exploding rear window syndrome.
I just replaced my rear hatch switch and cover. On a 14 y\o vehicle things wear out. Big f-ing wah....
Only valid troll observation, would have been nice if Toyota had put release button in the glove box. But then neither the troll or I would find it because I'd wager both out glove box lights are out.
Wah /s
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
02-13-2021, 01:03 PM
#19
Real Name: Ken
Real Name: Ken
my 08 had a similar problem and if it wasn't closed properly in the winter the trunk would open when i hit the first bump on my driveway. A good cleaning and spray with CRC knock'er loose solved that.
2008 SE 265/70/17 BFG. SpiderTrax 1.25" Wheel Spacers - Sold
2018 Blizzard Pearl Limited - Stock
02-13-2021, 10:06 PM
#20
Wah /s
haha.
Also OP, reach out to t4r.org member here
@ nytosc
and ask him about the camping mod kit that he sells. That will fix you not having a button to open from inside the hatch. I can lock/unlock, roll down/up window and open hatch all from inside and without the key in ignition. Perfect for camping in your vehicle. I also have it on a key fob that he set me up with.
07 SR5 4x4
02-13-2021, 10:57 PM
#21
16 degrees, sounds comfy.
02-14-2021, 10:59 AM
#22
Was -6 yesterday in Chicago. 4runner started just fine.
Opened the hatch on Friday and no issues. Toyota makes a great product. Fix the button and move on.
Metramm
2006 4Runner Limited 4x4 v6
241,000 miles and counting!
02-14-2021, 07:33 PM
#23
Real Name: Danny
Real Name: Danny
haha.
@ nytosc
The OP doesn't want it to work. He's on a mission to find as much fault with Toyota as possible. It's like he's a secret agent for another make trying to sabotage Toyota.
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
02-14-2021, 08:26 PM
#24
I just traded in my 2006 that had 220K miles on it. I never had any issues with that latch. In fact, I think it is probably my favorite latch I've ever had. The absence of an internal latch made it much more difficult for anyone to escape, if they happened to break their bonds. Another positive.
If you do not appreciate these features, and from the majority of your posts it would appear you don't, then you should definitely sell.
Sent from my Pixel 3 using Tapatalk
02-14-2021, 08:55 PM
#25
Real Name: Skip
Real Name: Skip
While your post is informative, it's also a bit disturbing, are you a kidnapper or something, exactly who do you keep bound up in the back of your T4R?
2004 Limited V8
02-14-2021, 09:01 PM
#26
02-14-2021, 09:09 PM
#27
I think OP wants a manufacturer that has unlimited mile/unlimited yr bumper to bumper warranty and for the manufacture to replaced everything that fails until the end of time? I wonder if he’s even the original owner of his 4Runner?
02-14-2021, 09:21 PM
#28
Real Name: Skip
Real Name: Skip
He is the original owner and he says his 2008 has less than 9000 miles on it, so other than the age of his 4runner it's sorta still under warranty if Toyota only when by mileage!
2004 Limited V8
02-15-2021, 01:28 PM
#29
Real Name: Russell (OB #9908)
I bought my 2007 in 2014 and it was noted on the dealer paperwork that the rear latch cover had been replaced. It occasionally takes a couple of tries to get it to unlatch, and sometimes I have to hit the unlock button again even though it should be unlocked, and then it works. All in all, however, I never really thought twice about it being any kind a big deal.
02-15-2021, 03:28 PM
#30
you don't want it, I'll buy it
I had the same issue, entire hatch was covered in 1/2" ice last week. Took a key along the bottom and pulled the hatch open after breaking off all the ice around edges. Same problem with fuel door too. But if you really want to part ways with it, how much you want for it???
Eibach pro truck with WOR springs on 1st notch in front. 5100's in rear w/ FJ OEM takeoff coils. 255/70R18 on 18" Limited wheels. 1.5" spacers on rear(one trimmed a bit to correct lean). Gibson catback, 06+Headlamps, auxito 16K bulbs in high, low, and fogs!
