Old 02-13-2021, 06:44 PM #1
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
Brake upgrade, good stopping power, not noisy. Powerstop Z36, Centric?
I have been reading quite a bit and want to upgrade my brakes on my 08 SR5.
My initial plan was to upgrade to Powerstop Z36 Truck and Tow brakes for front and rear for more stopping power due to bigger tires and much more weight on the vehicle than stock and still adding up fast. I plan on going with the following...
*Front- 5th Gen Rotors, Calipers, and pads
*Rear- 4th Gen Rotors, 5th Gen Calipers, and pads
Since the new thread was started here- Best bang for the buck rotors and pads?
I have been considering going with Centric premium rotors, Akebono Ultra premium ceramic pads, and Centric Posi quiet calipers both front (having trouble finding front rotors) and rear all 5th Gen except rear rotors will be 4th Gen.
Would the 2nd combo have just as good stopping power or close? I also considered going with the 2nd combo but maybe just getting Powerstop red calipers since I want them red anyways. I’ve heard mixed reviews on the Powerstop calipers about them getting stuck and curious what to do? I like how the Centric premium rotors are painted black on the hub and perforations since the OEM rust and look terrible with my wheels. I have seen the drilled slotted rotors rust and don’t want the Powerstop rotors rusting. I have also read that the Powerstop rotors are and can be noisy.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 02-16-2021, 10:28 AM #2
No responses yet, so I’ll reframe my questions and hope to gain some knowledge to help make my decisions.
For the Powerstop Z36 brake kits, what makes them have more stopping power? Is it the Pad/material type, calipers, rotors? All equally?
Wondering if I go with Centric rotors, Powerstop calipers and pads, will it have the same stopping power? What about Centric rotors, Akebono pads, Powerstop calipers?
Old 02-16-2021, 11:26 AM #3
Piggity Piggity is offline
Piggity will become famous soon enough
The Powerstop Z36 has better stopping power from the pad material. The pad size is the same. The rotors I believe are also cross drilled and slotted which helps with heat on long decents.
Past: 06' Limited 4WD V6 Nautical Blue Metallic
265/65R18 Cooper A/TW tires with TT - 2018 Forest River 201BHXL
Present: 08' Tundra Limited
33" Duratrac, spacer Lift with TT - 2022 Keystone 252RD
Piggity is offline   Reply With QuoteReply With Quote
Old 02-16-2021, 11:31 AM #4
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Just my two cents, but I've noticed zero issues with the Akebono/Centric combo that I'm running, even as the weight on my truck continues to balloon (steel bumper / armor / etc.) over the past year. Worth noting that I do have the larger 4th gen calipers.
I can't comment on the Powerstop setup but have heard good things.
ETA: I'd also replace the brake fluid as part of the service to give whatever calipers you go with the bet shot at a good long life.
eleven14 is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 08:47 AM #5
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
Get some Akebono or OEM pads and some cryo-treated rotors.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 09:02 PM #6
bradynasty bradynasty is offline
bradynasty is on a distinguished road
Ordered the Z36 kit last week for my 04 V8. Half arrived today. I've been experiencing a handful of symptoms that I'm diagnosing as at least one seized/poor caliper (dip in MPG, slight tilt to the steering wheel even after alignment, pulsation while stopping). Figured it was worth finding out how it performs for the price.
Remind me in like 2 weeks and I'll let you know my feedback!
bradynasty is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 10:33 PM #7
JBend JBend is offline
JBend will become famous soon enough
I've had the powerstop kit for about 3 months now and can't think of a single bad thing. I use the truck to tow my food trailer every now and again and no complaints. Stopping is great and I'd definitely recommend.
JBend is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 12:52 PM #8
JH225 JH225 is offline
JH225 is on a distinguished road
I didn’t use the Z36 kit because it wasn’t available when I needed it, but I have the Z25(22?) powerstop and it’s been great. No issues at all.
JH225 is offline   Reply With QuoteReply With Quote
Old 02-19-2021, 02:08 AM #9
Thank you for all the responses fellows. Sounds like the larger front 5th gen rotors themselves will increase stoping power and anything from there will help even more.
My dust shields are pretty corroded and in bad shape. If I replace them would I be advised to go with 5th gen shields since I’ll be getting bigger rotors? Would they fit on a 4th gen? Stick with 4th gen new shields and just bend them back, or get the 4th gen sport shields?
Old 02-19-2021, 10:12 AM #10
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
Larger rotors will not increase stopping power. Only larger calipers & performance pads will do that. There is also no consensus that 5th gen components perform any better or are any less failure prone. Performance differences are all minimal as there are no OTS larger calipers that are direct fit for our runners.
I would just go with the larger 4th gen sport options if available.
For the calipers, I would go with a cheaper box brand that carriers a lifetime replacement because they will inevitably fail eventually. Can paint/PC them red yourself if desired..
My last upgrade was with centric rears, OEM calipers were fine. Stop tech slotted cryo fronts and Akebono performance pads all around. Ended up replacing the front calipers with O'reilly since I didn't know my PS was stuck until I started. Used the lifetime replacement warranty a year later when one was sticking and they replaced both without question.
Brake upgrade, good stopping power, not noisy.  Powerstop Z36, Centric?-brake-parts-jpg
08 V6; Dobinsons IMS, Spidertrax, Prinsu, Revo 3s, AFE pro dry, Mishimoto catch, JBA shorties, Custom Y pipe, Borla pro XS, Hayden trans cooler, Ultragauge, Fumoto, +More..
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 02-19-2021, 12:43 PM #11
Flash Runner's Avatar
Flash Runner Flash Runner is offline
Real Name: Blake
Flash Runner is on a distinguished road
Real Name: Blake
Thank you for all the responses fellows. Sounds like the larger front 5th gen rotors themselves will increase stopping power and anything from there will help even more.
I wouldn't say the dust shields are worth replacing, unless you just want to spend the money, since you have to modify them to fit the bigger rotors anyway. I'd just cut it down and sand/paint if you feel the need to touch it up.
22 SR5 Prem 4X4- Magnetic Gray
07 V8 Limited 4X4 - Natural White (SOLD)--> "Moby Dick" Build Thread
Flash Runner is offline   Reply With QuoteReply With Quote
Old 02-19-2021, 06:28 PM #12
I had read to save your money for something else. They’re not just rusty, but rusted though in spots and not in the best shape. I’ll asses them again next time I have the wheels off.
@UrbanRunner651 I’m new to this, but curious why people upgrade to larger rotors if they don’t help? What’s the point in spending the extra money on 5th Gen rotors or why does the sport have a 338mm diameter larger rotor? Sorry if it’s a dumb question. Thank you for sharing your experiences. Good point about the lifetime warranty and buying on the calipers. The Powerstop calipers have a very short warranty (far from lifetime) and are a little pricey.
With your last upgrade was your stopping power any better or the same?
Old 02-20-2021, 01:22 PM #13
larger rotors do increase braking "performance", but by themselves they dont really increase stopping "power", aside from the fact that a larger rotor increases applied torque vs a smaller rotor since its further from the center of the wheel. but the difference in size between these 2 rotors is to small to make any real world difference in that regard.
the main benefit to larger rotors is the heat dissipation which means less brake fade when under hard stress like towing or long down hill driving such as down a big mountain or high speed braking etc. & less brake fade does mean more stopping power. so a larger rotor is better all around & when under hard barking conditions will mean better/more stopping force.
toyota on the sport models & other makers wouldnt offer larger rotors if there wasnt any benefit.
Old 02-24-2021, 01:49 PM #14
@cwilliams563 the larger rotors do help with brake fade and like what firebird says the larger diameter gives you more torque to slow the truck down faster. 4th gen Sport/Limited are the same diameter as 5th gen, but they're narrower by almost 4mm and the pistons in the calipers are smaller.
I forgot where I found this but it's relevant to this converstation:
4runner brake size
The 5th Gen calipers have shown less issues with seizing than the 4th gen calipers have. (my front left caliper seized which prompted this thread)
The 5th Gen front and rear caliper pistons are (2.5mm-3mm) larger than the 4th gens (not sure if this is compared to 13WH, 13WG or both)
The 5th Gen front rotors are 4mm thicker than the 4th Gen rotors. (this extra thickness helps with heat dissipation and warping)
The 5th Gen front rotors are the same diameter as the 4th Gen Sport (338mm or 13.307") (SR5 has 319.024mm or 12.56")
5th Gen Front Rotors:
Nominal Thickness: 31.8mm (1.25")
Minimum Thickness: 29mm (1.14")
4th Gen Front Rotors:
Nominal Rotor Thickness: 27.94mm (1.1")
Minimum Rotor Thickness: 25.908mm (1.02")
It is possible to use the larger (Sport) 4th Gen rotors with 5th Gen calipers...
The pistons in the calipers will over extend when the pads get warn down if you use the 4th Gen front rotors with the 5th Gen calipers.
It is highly recommended to upgrade the rotors too. It is even less recommended to use the SR5 rotors with the 5th Gen calipers
because of the smaller rotor diameter in addition to them being thinner.
5th Gen Rear Rotors:
Nominal Thickness: 18.034mm (0.71")
Minimum Thickness: 16.002mm (0.63")
Outside Diameter: 312.166mm (12.29")
4th Gen Rear Rotors:
Nominal Rotor Thickness: 18.034mm (0.71")
Minimum Rotor Thickness: 16.002mm (0.63")
Outside Diameter: 311.912mm (12.28")
5th , calipers , gen , powerstop , rotors
TBU Akebono vs. Wagner Thermoquiet - stopping power Arv 3rd gen T4Rs 16 05-17-2020 07:48 PM
Should parking brake provide any stopping power? 2UZ-FE 4th Gen T4Rs 2 11-06-2015 08:59 PM
is Tundra brake Upgrade = Sequoia brake Upgrade??? infamousRNR 3rd gen T4Rs 11 02-20-2014 05:22 AM
lost of stopping power after tire upgrade renep74 4th Gen T4Rs 20 01-21-2013 10:37 PM
