Old 03-14-2021, 09:31 PM #46
ryanking61's Avatar
ryanking61 ryanking61 is offline
Real Name: Ryan
ryanking61 has a spectacular aura about ryanking61 has a spectacular aura about
ryanking61's Avatar
Real Name: Ryan
Interior Part 3: Shift Boot and Finishing Touches
The last thing I needed to do to completely finish up this swap is add a shift boot and a USB outlet since this swap removes the cigarette outlet.
I bought a generic dual-port USB outlet from Amazon, about $10.
For the shift boot, I used a generic shift boot from Autozone that is $10, similar to @xtremewlr (see post #33).
I cut holes in the shift boot and drilled holes into the center console trim all around the pocket where the shifter goes and attached the boot to the console trim using zip ties:
And installed:
That concludes the FJ transfer case swap! I'm sure I've left out details throughout so please ask questions in this thread or PM me so I can add more info to this thread for others to benefit from. Hopefully I'll be able to get out and wheel soon to test it all out. Until then, happy wheeling everyone!
ryanking61 is offline   Reply With QuoteReply With Quote
Old 03-15-2021, 08:11 PM #47
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
And installed:
That boot works pretty well, doesn't it? Nice work man, came out really good!
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 03-16-2021, 05:44 PM #48
mysticz's Avatar
mysticz mysticz is offline
mysticz has a spectacular aura about mysticz has a spectacular aura about
mysticz's Avatar
FJ Transfer Case Swap into a V6 4th Gen
And installed:
Nice job doing this swap.
Funny we all use similar shift boots.
Also consider adding the single stick version of this to seal the heat coming up the hole area. I added sound damping and the rubber shift boot to help with noise on mine.
2005 T4R Silver SR5 V6 4wd with Mods.
mysticz is offline   Reply With QuoteReply With Quote
Old 03-16-2021, 07:53 PM #49
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
I had bought a twin stick for the swap but haven't used it yet. I took the twin boot and cut it in half and sealed up the FJ stick with that.
Old 03-16-2021, 09:09 PM #50
mysticz's Avatar
mysticz's Avatar
Nice pretty much like mine except I added sound damping material aka dynamat around the entire bare floor to cut down on noise, the noise even with sheeting sealed still kind of loud alone.
Old 03-16-2021, 11:36 PM #51
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Yeah, I'll be doing that at some point. Probably when I get around to replacing the carpet. I'll also remake the cover plate for the hole that I cut into the trans tunnel since it's 2 pieces right now.
Old 03-17-2021, 11:33 AM #52
ryanking61's Avatar
Real Name: Ryan
ryanking61's Avatar
Real Name: Ryan
I probably should do some more to reduce noise coming through the floor but tbh, it seems about as quiet as it was before and I usually have my music cranked up loud anyways.
Old 06-21-2021, 09:48 AM #53
shallcallhimtim's Avatar
shallcallhimtim shallcallhimtim is offline
shallcallhimtim is on a distinguished road
For those interested in the ADD harness. 12th State Offroad has them in stock. ADD actuator wiring harness | 12th State Offroad
5100/885(front) Superflex(rear), 285/70/17 michelin LTX A/T 2, CB, HCF delete, blacked out emblems, CBI ditch lights, 4th gen CBI front and rear hybrid bumper, Custom built roof rack/40" bar
http://www.toyota-4runner.org/4th-ge...tim-build.html
shallcallhimtim is offline   Reply With QuoteReply With Quote
Old 06-22-2021, 09:09 AM #54
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
Nice work! If/when my T-case bites the dust, I’m going to do the same swap.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 12-26-2021, 07:13 PM #55
scrappyted83's Avatar
scrappyted83 scrappyted83 is offline
scrappyted83 is on a distinguished road
Did the swap a couple weeks ago. Really not hard at all and worth the time and money invested to do it. Lots of time saved thanks to Ryan documenting his swap.
Couple things I found:
1. I did the 1.5”bl because it was said that it might be required, I don’t think that was the case. It made it easier in some ways but makes it harder to get the shifter fitting correct because the farther the body is from the t-case the more room the shifter needs to clear stuff.
2. To make the shifter fabrication easier take the shifter apart and spin it 180deg and reassemble. You’ll know that I’m talking about once you’ve seen it.
3. Here is a pic of my floor cut which was just enough room.
scrappyted83 is offline   Reply With QuoteReply With Quote
Old 02-01-2022, 12:09 AM #56
gotdurt's Avatar
gotdurt gotdurt is offline
gotdurt is on a distinguished road
gotdurt's Avatar
I'm considering buying an '03 V6 (4spd), and a little concerned about sticking actuators in these. It works for now, but being a Texas truck, chances are I was the first to engage 4WD in a decade+ (as would just about any 4th gen from here)... so I'm doing a little pre-planning.
From the looks of this thread, should I hold out for a V8? I hate to let this one go, the price is right...
Also, is it possible that OP's conversion could have have been done without a body lift?
What year/engine is yours?
2000 SR5
Photography
Youtube
gotdurt is offline   Reply With QuoteReply With Quote
Old 02-01-2022, 06:29 AM #57
Flesh Eater Flesh Eater is offline
Flesh Eater will become famous soon enough
Does the FJ case at least offer lower gearing?
2008 SR5 4Runner V6 4WD
Flesh Eater is offline   Reply With QuoteReply With Quote
Old 02-02-2022, 12:19 AM #58
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
No. It offers manual 4wd shift, eliminating the electronic actuator and all it's potential problems.
2008 SR5 4WD (@280k!!)
bob3dsf is offline   Reply With QuoteReply With Quote
Old 12-19-2022, 10:04 PM #59
So after my last long trip out west I started having problems with 4 lo out there.
I hunted down an FJ case locally. I saw the thread on how to delete the ADD up front. Also going to do a twin stick for 2lo, which would be really nice when dry and running mountain passes.
I’ll eventually be adding ARB’s front and rear. So I’m not too worried about the ADD stuff.
Any good YouTube videos on rebuilding one of these FJ cases? I’d like to put in new bearings and seals.
Old 12-20-2022, 12:08 PM #60
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
have you already sourced the twin sticks? My suggestion, keep it simple and forego that mod and just keep the j-pattern shifter. I swapped over to the twin-stick mod in mine (primarily because the junkyard elected NOT to include the factory shifter and I couldn't find anything cheaper than $600 for a replacement) and can tell you I have used 2lo LITERALLY 2 times: one was to make sure it works after I swapped it in, and the second on a trail before quickly realizing that 4hi was significantly better than 2lo. I just haven't found the need or application for 2lo. Especially if you haven't/arent planning to upgrade the rear axle..
it is significantly easier to package and seal the single shifter vs the twin sticks. I also found that when I'm in 2Hi and try to accelerate from a dead stop with heavy throttle, my t-case wants to "pop" into 4hi and clunks as the synchro slips and tries to engage. I'm not 100% certain if this is a result of modifying the case to accept the twin sticks or not, but I can eliminate the sound by holding the 2hi/4hi stick selector forward under heavy acceleration.
As far as seals and bearings.. there's really nothing much to these cases and you have access to everything once you crack it open.. just be mindful of the synchronizer hub/springs when you take it apart.. they'll shoot out and you'll never find them again. I have personally yet to hear anyone having to replace bearings on a t-case so you may be overthinking that.. the seals are like any other seal when it comes to replacing. I elected to not change anything on my junkyard t-case that has god knows how many miles and it has 0 issues for the past year of use.
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
4th , case , gen , swap , transfer
07 transfer case/transmission swap deputydan 4th Gen T4Rs 10 12-06-2020 04:19 PM
v8 transfer case swap to 6cyl transfer case? V8RUNN 4th Gen T4Rs 23 09-11-2020 01:40 AM
FJ transfer case swap UnJeep 4th Gen T4Rs 4 06-14-2017 08:17 AM
GX470 transfer case swap? razzman1 4th Gen T4Rs 1 09-08-2015 04:21 PM
Transfer Case Swap? kylebacc 4th Gen T4Rs 2 02-27-2013 04:33 PM
