Old 04-10-2021, 07:12 PM #136
aemravan aemravan is online now
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
Originally Posted by BagiMT View Post
Looking great, planing on doing something similar. Where did you get it laser cut for that price? How did you make the mounting feet. Any more details on those?
I have a contact with a local metal vendor through work that does our laser cutting. The side pieces were like 70 bucks each the fairing was 115. I spent note on the cross rails.
The mounting brackets are pretty much identical to the sherpa roof rack. They are Z brackets that mount to the bottom of 2 rails. Don't have any closeups at the moment tlbut I'll snap some later.
Sent from my SM-G970U using Tapatalk
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is online now   Reply With QuoteReply With Quote
Old 04-10-2021, 07:14 PM #137
Stretched her legs a bit at uwharrie this morning to test the clearance and lockers. The TacoRunner did great. Love the setup with the lockers. Literally made it possible to walk right up just about anything I could clear.
Old 04-14-2021, 08:10 PM #138
Been a while since an update.
Haven't done too much, but after going to uwharrie last weekend I was able to test fit the tent for out big camping trip on the 23rd and see how the rack holds up. Fabricated some brackets to mount the CVT awning.
The rack has left a little more to be desired.. I'll probably rework it in the next off season. The mounting holes I came up with aren't 100% as I thought it would work out but everything is on and it's holding up so far.
I'll probably need to go from 1/4" hardware holding the side rails to the cross bars to 5/16 just to be on the safe side but for now it should do. Just waiting on the side molle panels to show up so I can complete the outside.
Oh yea.. also bought thr plans to build some pull out drawers in the rear and ordered all the material..so that should be a fun project next
Old 04-20-2021, 08:20 PM #139
Not many large update as of recent, just been getting everything together for a 2 night camping/offroading trip to uwharrie this coming weekend.
I did do a small finishing things in the last week though:
-reloctaed/mounted the winch control box to the radiator support
-FINALLY installed a window washer tank I bought on Amazon.
The control box couldn't sit on top of the winch without cutting thr grill out around it, so my brother suggested I take it off amd hard mount it else where, great idea.
The window washer tank was so long overdue and missed... 30 bucks and less than an hour later (1 rivet nut to mount the tank bracket and splicing 2 wires to the factory plug) I have working window washer sprayers ( front only. Didn't care for the rear since I can't see put of it with the tire and jack anyhow).
Old 04-20-2021, 10:55 PM #140
momo.75's Avatar
momo.75 momo.75 is offline
Registered User
Real Name: Morris
momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of
Registered User
momo.75's Avatar
Real Name: Morris
Which washer tank is that?
momo.75 Build ThreadClick to order T4R.ORG Decals • @urban_overland
momo.75 is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 07:29 AM #141
$21 bucks on amazon universal tank, see the pic.
Old 04-22-2021, 04:47 PM #142
In preparation for what looks like is going to be a VERY wet weekend camping trip I wemt through and mounted my axe and shovel on the tire swing out. I don't mind the look of them on the molle panels, but I don't have those yet, and here the little added weight is pretty low to the ground and is physically a lot more accessible.
Old 04-25-2021, 09:04 PM #143
Successful weekend at Uwharrie. I am super pleased with the build and how its performing.. but now onto trying to get a bit more flex with the new Icons that just showed up..
I have some rubbing coming from the front at times that I will try to get sorted out and then see about disconnecting the sway bar links to see how much more flex I can get out of this set up. Currently, as you can see from my 3-wheel action up the 2nd ledge of Daniel it isn't very much at all... I am hoping that the Icon's have a bit more down travel available front and rear and go from there. My brothers Rubicon on 37's walked right up that second ledge and barely even lifted a tire, I was 4 feet in the air at one point lol.
I also managed to destroy every single skid on my car.. luckily I have the front already on the way and the rest I will get on designing my own very shortly.
Old 04-26-2021, 08:53 AM #144
waught10 waught10 is offline
waught10 is on a distinguished road
I think a TRD PRO grill would make that front end look even more mean.
waught10 is offline   Reply With QuoteReply With Quote
Old 04-26-2021, 10:35 AM #145
I agree, just didn't feel like spending the extra money on one since the surround I bought already came with the insert, but I've been eying some on ebay for a while. Would be a very fast swap. If I do it, it will definitely be the one without the raptor-style lights though.
Old 04-26-2021, 04:06 PM #146
Trd Pro Grill Grille Fit For 2012 2013 2014 2015 Toyota Tacoma – VI Auto Parts
Cheapest that I have found. I will do the swap to mine eventually
Old 04-26-2021, 04:14 PM #147
I'll have to have you explain to my wife why I jus spent another $135 on this thing.... but its on order! Thanks for the link! lol
Old 04-26-2021, 04:36 PM #148
Feel free to blame me. We all need to pass the blame every once in awhile to keep the peace at home LOL!
Let me know how that one works out. ill pull the trigger once i get some color match paint in.
Old 04-27-2021, 12:03 PM #149
So in the disappointment of having to winch up the 2nd ledge of Daniel at URE this past weekend I have another set of parts coming to compliment my Icon shocks going on hopefully in the next 3-4 weeks...
I just put in an order for Front Range offroad rear link set with the pan-hard bar and ordered a set of extended rear brakelines from Apex Overland.
The plan is that the combination of the new parts will allow for significantly improve down-travel and overall articulation over the current setup. That, coupled with disconnected sway bars that I plan on running next time around should give me quite a bit more articulation than I have now, so we shall see! Now to figure out a time to use the work forklift in order to test the before and after....
Old 05-03-2021, 11:04 PM #150
Finally washed the car after the last outing off road. Definitely found some trail scars lol.
Used both sliders really good, both sides of the rear bumper (really happy I went the rattle can route on this one lol) , dented every skid, and found a bent lower rear link on the passenger side from an impact on a rock.
Already had some links on order from front range offroad but they are delayed... really toying with the idea of designing my own... did a quick material price out and looks like I can build a set for around 200 bucks cheaper than buying... if the parts are all in stock that's probably what I'll do.
The trd pro grill came in today as well (imitation of course lol) and I love the look. Also got another piece of overland gear.. my Amazon version of the trasharoo (which actually seemed to have some not-so-good reviews).
car , front , pretty , rear , time
Project Mayhem Build Thread MaYheM97 3rd gen T4Rs 17 11-27-2016 03:02 AM
Project 1Ton "build thread" Many Pic's! GonOvr Classic T4Rs 161 10-17-2016 01:11 AM
SOCO4RUNR's T4R Project Build Thread SOCO4RUNR 3rd gen T4Rs 5 09-26-2013 09:21 AM
Pitbull Rescuer's New Project/Build Thread PitbullRescuer 3rd gen T4Rs 93 09-16-2012 11:46 PM
