Old 02-19-2021, 11:44 PM #16
aemravan aemravan is offline
aemravan is a splendid one to behold aemravan is a splendid one to behold aemravan is a splendid one to behold aemravan is a splendid one to behold aemravan is a splendid one to behold aemravan is a splendid one to behold aemravan is a splendid one to behold
Its not cookies im baking..
Sent from my SM-G970U using Tapatalk
aemravan is offline   Reply With QuoteReply With Quote
Old 02-20-2021, 12:06 AM #17
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a name known to all xtremewlr is a name known to all xtremewlr is a name known to all xtremewlr is a name known to all xtremewlr is a name known to all xtremewlr is a name known to all
xtremewlr's Avatar
Real Name: Todd
Originally Posted by aemravan View Post
Day 1 of diff and axle swap and welded total chaos gussets. Making progress. The front diff is already in the car and gussets are welded ready to be painted tonight.
The rcv axles are beefy next to thr factory ones..
Nice! Something I'd like to do eventually myself.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/70/17 Toyo ATIII on Sequoia rims, Sherpa rack, Coastal front bumper, custom rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 02-20-2021, 12:09 AM #18
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Definitely. Haven't decided between fox, king or radflow... but yes, for sure.
Might I suggest ADS? I know they don't list for the 4th gen 4R but the front suspension is the same as the 2nd/3rd gen Tacomas and they can do custom rear shocks without issue.
ADS have been shown to have slightly more travel than the others you listed. Up to an additional inch. They also happen to be local to me here in Tucson.
Arizona Desert Shocks - Shocks proven to perform and outlast the competition
Old 02-20-2021, 01:41 PM #19
Roody Roody is offline
Real Name: Ross
Roody is on a distinguished road
Real Name: Ross
Dude, this is absolutely killer. Bravo.
2005 4Runner Limited 4WD - 4.7L V8, 270k miles - 3rd gen Taco TRD Off Road suspension w/XREAS removed, 265/70/17 Terra Grappler G2s, Powerstop brakes, TYC headlights, USA Spec Bluetooth adaptor, Ultra-Power driveshaft, LED reverse lights, etc.
Love off-roading? Enjoy listening to podcasts? Consider yourself a four-wheeling enthusiast? So do we! Join in on the fun, and listen here:
The Off The Road Again Podcast
Roody is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 10:32 PM #20
Air locker diff install day 2..
My brother dropped by to do some truss gusset welds on his '17 rubicon while I was finishing up my car. My initial thought was that I'll wrap mine up quick and help him out. Boy was I wrong..
I spent 3 hours fighting what I originally thought was a fitment issue with the RCV axles and my factory bearings, etc.. I was developing a gap on the back side of the axle to the bearing bushing that I just couldn't figure out. Long story short...the rcv axles did not come with the factory-style dust cover on the axle.. hence the "gap" that I was seeing. Anyhow. I spent quite a bit of wasted time on stupid stuff, but after a while the front end went together (and I hope like hell I got everything fastened properly and it stays together lol).
The rear was a really quick process.. I'm not sure why a lot of places I saw suggested undoing the brake lines from the caliper.. but I had plenty of room to slide the axles out to remove the 3rd member. It took me longer to fill up the damn things than it did to swap in the rear diff... the pump broke and I was too beat and dirty to source another one. After a 12 hour day on day two, I finally had everything done and the airlines connected.
The air lockers tested out good and hold air and engage, can't wait to test them. But... I am currently on the very slow 500 mile break-in process and am roughly 200 miles in.
Saw some different information regarding the break-in process but decided to follow the one by ECGS since they are they ones carrying the warranty on the assembled members. The nitro gear process stated 50mph max (thus suggesting no highway use) 500 mile break in, the ECGS procedure does not limit MPH and states that after the 2-3 initial heat/cool cycles highway miles are OK as long as kept to no more than 50 miles trips between cool down and varying the speed every 5-10 minutes. It did not mention limit of MPH, but I leaned towards the safer side on the highway speeds and kept it between 55-65 mph in 10 minute segments.
I believe everything is OK.. only thing that caught my attention a bit of a decel gear noise (a faint whine) that would appear when slowing down off gas around 32-28 mph. Does not do it under throttle and does not seem to come/go at any other mph/rpm. I'm going to try and get the rest of the miles in over the next 4 days so I can do the oil change friday and have it ready for full use this weekend.
Old 02-21-2021, 10:49 PM #21
The spindle gussets were as straight forward as it gets, and at like 60-70 bucks it was a no-brainer while doing the rcv axles and new wheel bearings.
with regards to ADS, looks like now they actually do have a 4th gen-dedicated product line so I will definitely take a look at them. From a glance, they are for sure not the cheaper option of the other sets but a good quality shock with more total travel would be well worth it.
Old 02-21-2021, 11:41 PM #22
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
I ran ADS on my 1999 Tacoma and probably will eventually on the 4Runner. Not saying the other choices are bad but I do like ADS stuff a little more.
Old 02-23-2021, 02:11 PM #23
drive4fun drive4fun is offline
drive4fun is on a distinguished road
Wow this looks sweet. Subed to see how this comes a long.
drive4fun is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 04:21 PM #24
awhitney1 awhitney1 is offline
awhitney1 will become famous soon enough awhitney1 will become famous soon enough
Nice build progress! Those RCV axles are BEEFY! I plan to get those whenever I get the Marlin Crawler kit.
Are you still using the stock 8" rear axle for the differential?
Do plan to stick with the 4.56 gearing if go to 37" tires?
awhitney1 is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 09:28 PM #25
Thanks! The rcv are definitely beefy.
I'm still on the stock rear axles other than 4.56 gears and air lockers. Haven't looked far enough to what the next step up would be for those yet... afraid I might like what I see lol.
As far as the gears and 37s.. I honestly don't know if I'm gonna go 37s any time soon.. its already way more car than I wheel. 95% pavement and some offroad.. if I went 37s with 4.56 gears it would be a similar step up asr the 33s and stock gears to 35s. And honestly with the v8 I haven't noticed much a difference
Old 02-23-2021, 09:34 PM #26
So all the parts except the fenders for the tacorunner project are here. I'm planning on painting the hood tomorrow while the weather is nice.
The grill and lights are looking mean ! I can't wait.
The gears are breaking in nicely, im hoping to be done with the 500 miles by end of tomorrow. Then a quick oil change and I should be good to go to try out the lockers. Cant wait.
After a slight hold up in customs, thr coastal offroad bumpers have also arrived so im anxious to get welding on the front bumper now too !
Stay tuned !
Old 02-24-2021, 09:49 AM #27
Since you spent to money to get RCV axles for the front, have you thought about getting beefier axles for the rear?
Old 02-24-2021, 10:07 AM #28
Tomm- Tomm- is offline
Tomm- is on a distinguished road
A fellow FRS owner! Thought I saw some valenti taillights in one of those pics...
2004 4Runner Sport V8
ARB - AUXBeam - Bilstein - Cali Raised - Camburg - CBI Offroad - Dobinsons - Factor 55 - Fat Bob's Garage - Maxtrax - Method Racing - OME - Prinsu Design Studios - Remark - Rotopax - Smittybilt - Traveler - Yokohama
2009 Ford F-150 Platinum
2013 Scion FR-S
Tomm- is offline   Reply With QuoteReply With Quote
Old 02-24-2021, 10:36 AM #29
Naturally, I imagine that i'll have to beef up the rears, yea. I haven't looked too far into what the options/cost would be.
This car currently is 95% daily pavement queen, with 3 off road trips. I plan to do much more with it this year off road wise, but still nothing too crazy so the stock rear axles should hold up for a bit.
ideally the plan would be to swap the rear axles when I am doing the FJ T-case. That way I can also get slightly beefier driveshafts made, and with the down time for the swap, I could pull the rear axles, get something beefier in there, while also doing the bearings/seals, etc. But this isn't something I plan on doing at least for a year, unless the electronic Tcase takes a dump on me before then... I'd much rather spend the money on some nicer 2.5 shocks prior to diving into more drivetrain upgrades.. but we'll see what happens.
Old 02-24-2021, 10:40 AM #30
Haha you sure did. Its my wife's car for the time being. Looking to get rid of it in the next few months and get something a bit bigger.
34k miles on it right now... may be the lowest mile '13 frs for sale haha
Here is what its looking like right now
car , front , pretty , rear , time
Project Mayhem Build Thread MaYheM97 3rd gen T4Rs 17 11-27-2016 03:02 AM
Project 1Ton "build thread" Many Pic's! GonOvr Classic T4Rs 161 10-17-2016 01:11 AM
SOCO4RUNR's T4R Project Build Thread SOCO4RUNR 3rd gen T4Rs 5 09-26-2013 09:21 AM
Pitbull Rescuer's New Project/Build Thread PitbullRescuer 3rd gen T4Rs 93 09-16-2012 11:46 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
