Old 10-24-2023, 09:05 AM #976
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Originally Posted by aemravan View Post
On a related note.. not that I think these are the cause, but I seem to have lost the 4lo indicator light on the dash.. I don't know if its a coincidence of the replaced LED burning out (I just had it illuminating 2 days ago), or possibly me damaging the signal wire coming out of the tcase plug (I tugged on it a bit to zip tie it in place and keep it off of the driveshaft, but it was pretty damn snug).
I believe both of my indicators were working, so you already have a replacement when and if you might go back in there. The ones on my manual swap are still working fine.
Hopefully you're done messing with that thing for awhile lol.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 10-24-2023, 09:40 AM #977
aemravan aemravan is online now
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
yea, the indicator was perfectly fine, even with my half-tcase test lol. Not sure if this is good or bad.. but this morning it's back to 100% normal and functional on the 4lo indicator light. Made it to the office with no issues, still actuates into both 4lo and center diff lock, and thus far appears to be dry-ish at least.
Hopefully this is it for a little while
2003 Limited V8 4runner - Slowly turning back to stock (until the next crazy idea comes along )
aemravan is online now   Reply With QuoteReply With Quote
Old 10-24-2023, 10:16 AM #978
Real Name: Brett
Real Name: Brett
hmmm maybe just a ground issue with the wiring then?
Old 11-18-2023, 09:12 PM #979
Spent some time wrenching over the past week.
Glad to report the tcase is still bone dry, still got 4lo and diff lock , but 4 lo indicator is dead. The bulb isnít the issue. Might troubleshoot some more but as long as it works it doesnít bother me much.
I developed some horrendous body gaps in the front end that I finally tracked down to some collapsed body mount bushings. Threw in a replacement and reset some spacers to dial everything back in. Not factory spec, but itís nice.
The next up is tackling the stupid dim headlight output from these eBay lights. I thought about putting in a nice bulb , but decided instead of spending $100 on those , I would give the diode dynamics SS3 pods a try. Apparently these fog light pods are SAE spec with a nice vertical cut off , and Iím hoping will get me some awesome output to compensate for the headlights.
Old 11-20-2023, 09:29 AM #980
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
That bumper looks amazing matched to the color of the 4runner. i likey likey. wonder if anyone has painted the hybrid the same color. stuck between which of the two to make, they both look awesome on our trucks.
daprotege5 is offline   Reply With QuoteReply With Quote
Old 11-20-2023, 05:29 PM #981
Early Christmas for myself
Now to figure out if the lens can be rotated 90 degrees or if I need to dab up an L bracket for these
Old 11-20-2023, 08:45 PM #982
Hybrid bumpers look decent in black. Not sure how a hybrid would look color matched. But with a. Solid bumper like the costal I love the color match look. Eventually Iím going to hybrid front and rear in black to shed some pounds. Sheís a big girl as she sits now
Old 11-20-2023, 08:47 PM #983
Weíll , pods are on. Nothing a little dremel could fix to rotate the lens 90 degrees and mount the pod sideways.
Not AS bright as I expected for $299 but and awesome improvement for sure. Plus the added benefit of running these on the road and not blinding people because the vertical cut off is amazing.
Old 11-22-2023, 07:03 PM #984
After all that talk of not running led bulbs and not upgrading the headlight bulb in favor of powerful fog lights, I decided to give it a try anyway and am pleasantly surprised at the cutoff and spread with this amazon special.
Still need to road test them.. but the garage door test so far is promising lol
Old 01-02-2024, 09:25 AM #985
2023 is a wrap! Wasn't a super large modification year... actually, I think in 2023 I spent more time undoing some of the mods that I did the year prior lol
Onto 2024 and what ever possible mods that it may bring next!
Spent New Years down in Carolina beach and driving out on the sand a few times was the extent of my "offroading" to close out the season, but no complaints here. The rig is running pretty damn good. I am, however, finding that the softer Dobinson progressive springs i swapped in the rear to reduce some of the rake I ended up with after removing the RTT is borderline too soft..
Under even partial throttle, I'm squatting a good 3-4 inches, full throttle probably goes a solid 6" , to the point where my front wheel unload enough to literally squeal on dry pavement lol. I'm considering throwing the heavy springs back in.. but I don't want to raise the front and chew through CV axles and have no downtravel left.. so my recent (likely dumb) idea was "hey! what about a drop bracket setup??"
the procomp fj drop bracket kit is a 6" lift kit, retains factory-like geometry, and could probably run the current coilover in the lowest lift setting to match the rear .. maybe? I probably would have bit the bullet and ordered it already, but the biggest thing is the LC200 rack I'm running with the custom outer ends lol. I certainly don't want to have to convert the drop bracket knuckles to run the double shear 1" hardware like I did with mine....
Anyone want to buy an LC200 rack with custom outers and reinforced doubleshear steering factory spindles???
Old 01-03-2024, 11:18 AM #986
awhitney1 awhitney1 is offline
awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about
You still have the rear TK1 rear sway bar or have you removed it?
awhitney1 is offline   Reply With QuoteReply With Quote
Old 01-04-2024, 03:29 PM #987
I ended up removing the TK1 rear bar and selling it in favor of a slightly stiffer OEM type bar that I put back on with some extended links. I also ended up reinstalling the front sway bar as well.. got tired of swaying and surfing on the road since I very rarely go offroad where I need all the articulation
Old 01-11-2024, 04:08 PM #988
So for my next trick, I will make my LC200 rack swap project disappear! In my attempts to further undo some hard work I think I pretty much committed to going back to a factory rack since I don't foresee myself actively wheeling this rig outside of random overlanding trips.. The drivability aspect isn't an issue... I just feel like with the amount of street driving I do on a daily basis I should probably take benefit of slightly increased tire wear ..
Got one of the members picking this up in the March time frame along with my modified knuckles in return for his factory/gusseted spindles and throwing in a factory rack...
BUT, I have just about decided (and even almost placed the order lol) to go with some 37x12.5x17 tires with some new beadlock wheels in place of my current wheel/tire setup.. Keep seeing a local 5th gen on IG with a badass setup on 37's and finally confirmed that he's running factory LCA's, no long travel.. and basically a relocated body mount and a firewall tub. So.... that's my next endeavor come March probably..
Old 01-12-2024, 01:28 AM #989
God damnit Ö I done did it again .. came across something on Instagram , messaged a guy .. got the itch.. stayed up too late and made another god damn irresponsible purchase ..
If anyone is familiar with the Milkwagon 5th gen 4runner .. itís a local rig thatís on 37s that also sees some off-road action .. found out heís on factory length arms with basically I have done with the exception of a firewall tub Ö heís running 37s Ö.
Long story short , If anyone wants a set of 5 wheels with 35s theyíre going up for same and I have some sheet metal to source Ö
Old 01-12-2024, 06:15 AM #990
Real Name: Brett
Real Name: Brett
We should start a modified T4R owner support group......
car , front , pretty , rear , time
Project Mayhem Build Thread MaYheM97 3rd gen T4Rs 17 11-27-2016 03:02 AM
Project 1Ton "build thread" Many Pic's! GonOvr Classic T4Rs 161 10-17-2016 01:11 AM
SOCO4RUNR's T4R Project Build Thread SOCO4RUNR 3rd gen T4Rs 5 09-26-2013 09:21 AM
Pitbull Rescuer's New Project/Build Thread PitbullRescuer 3rd gen T4Rs 93 09-16-2012 11:46 PM
