I have the Stop Tech slotted rotors front/rear with Posi-quiet pads and been real happy. A more aggressive pad for off and on road might be better though, I'm not off road at all.
My only offroading is low speed dirt road/rock crawling so from a brake pad perspective I was just looking at something to not be loud or overly dusty as it wears down. If I had to guess, I'm roughly 6300-6500lbs with all the stuff I have on it lol, so I need something that can put up with the heat stopping at highway speeds and not warp the rotor too quick.. I know factory rotors are hit and miss, but I decided to gamble on these and see where they get me. Drill and slotted rotors seem enticing.. but I just feel like i would pack them with dirt and ruin the pads really quick.
The brembo rotors I'm getting ready to take off seemed to do decent, but I don't have many miles on them and as of recent they have been making noise when coming to a stop (kind of as if they were overheated and the brakepad wasn't making even contact) even though I went through the 100% exact bedding procedure Brembo provided.
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
I’ve been looking at the amount of lift I’m sitting at up front for a while.. so finally decided to address what I was seeing. I adjusted the icon coil overs 2 full turns (so maybe a 1/2” difference in height or so ?) to lower the front end. This corrected a lot of the positive camber I was seeing sitting flat. I feel like this will also allow me to take full advantage of the up travel without Binding the spring and not reaching the bump stop since some of the preload is removed.
This also corrected the toe in I’m seeing when accelerating since it put me closer to the full bump vs full droop. Here is what is looks like with a bit of rake, but this is also fully unloaded with everything out of the rear.
Yes, isn't it amazing how one adjustment to front suspension can have such an effect on all the other settings?!
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Bought an Amazon bandclamp tool and got the worm clamp on the RCV axle replaced.. feels pretty solid.. so we’ll see how it holds up. Definitely a ton more clearance to the control arm.
I also have been experiencing some steering wheel related rattling / knocking / clunking , particularly off-road at low speeds on bumpy roads. After researching for two hours and seeing various solutions that apparently fixed similar issues decided to give it a go.
No bolts were loose, the intermediate shaft I joint is in perfect condition, it isn’t the extension puck, it isn’t the tilt ball.. after tearing everything apart I think the issue resides in the upper splined telescoping shaft.. you can definitely feel just a bit of back and forth sop in the splines.. yay.. at least I haven’t purchased any parts yet lol.
What I am attempting to do is give the outer shaft a bit of a squeeze to oval it just a touch and see if it’ll tighten up .. other than that I don’t see a way to fix the issue without buying a new splined shaft assembly (if it’s even available by itself lol)
So after doing a bit of searching buying a different shaft or assembly is out of question.. I can get a used one for $150 but what are the odds it has the same issue ? New the assembly is over $1000 so out of question. I am almost certain the outer shaft is aluminum so can’t weld it .. thought about drilling and roll pinning it but don’t feel like doing that. But what I did come across is something call loctite 660 joining compound for metal repair. It’s specific for jetways, loose splines, etc. have it on order with Amazon so we’ll see if it works. Not sure if I’ll be able to get it between the splines enough but for 20 bucks it’s worth a shot.. if this doesn’t work I may consider buying a spare assembly and see if I can drill and pin it , though I’m not sure it would fix the slop if I’m not careful with the hole.
You've replaced the LCA bushings recently haven't you? My 5th gen needs them and on slow bumpy roads it feels like it's in the steering wheel. No noise or vibrations on the hwy, just certain speeds on washboard type stuff.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
Yea the entire lca is new and it was making the same noises prior to the swap. I can physically feel this slop when turning the wheel as it gets exaggerated into the u joint. Removing the u joint and testing it separately shows 0 slop in it but the shaft still slops around so it has to be it.
The only other possible thing it could be is a tilt ball but it feels tight as hell and I don’t think I can add a shim and get it back in like some folks are doing.
If the loctite 660 compound doesn’t fix it I may just let it be.. not sure if the non telescoping section of shaft is an option for a swap or not , looks like 2004 sr5 models had the non telescoping variant so that may be an option.
I just spent another hour messing with this damn steering column in an attempt to use the vice to squeeze the outer shaft into an oval and take the slack out. I found that rotating the shaft slightly to a different set of splines helped a little too. I thought I had it nice and snug and re-assembled everythng into the rig to test. Found out right away that I missed with the splined shaft about 130 degrees and had to pull the steering wheel and reclock it lol.
Soon after I discovered that i literally made no difference in the slop.
At this point, as frustrating as it was to get it all apart and back together.. I have a feeling I'm just going to leave this damn thing alone and let it be. I don't think that the loctite 660 would really do anything and I will literally have to pull everything apart in order to attempt it before leaving it for 1-3 days to fully cure.. At least I have the peace of mind that there is nothing bolt related that is loose and coming apart, and didn't blow money on a new intermediate shaft to replace the u joint that ended up being 100% good.
damn it! I think i'm going to give this another shot... lol.
While doing some light reading on the loctite retaining compounds I believe I may have ordered the wrong one... the 660 compound is more of a paste and for larger gaps/keyways and I don't think I'll have much luck getting it between the splines of the shaft... but then i came across a forum where (though a different application) a guy had a similar issue with a minor spline wobble that he was looking to fix. It was suggested he use the loctite M680 compound instead of the 660 since it was a lot more fluid (kind of like their thread locker) and would fill smaller gaps up to .015" (which I think should be right in line with what I'm feeling on the splines) and has a better shear strength...
I have a tube ordered for Saturday delivery and will give this another shot.. One thing to keep in mind is that I'll have to set my telescoping feel adjust and leave it.. I'll no longer have this function if I want the compound to do it's job. It sounds promising from a few repairs I've seen retaining keyways that were wobbled way out.. so we'll see I guess.. Taking this all apart one more time shoulnd't be too be of a deal and I won't have to worry about clocking the splines since I'll just leave the U-joint lower portion attached and remove it off the upper shaft. This way as long as I don't turn it more than 90 degrees each way I should be able to line it right back up for a quick repair.
Only issue is letting it cure... I'll have to leave it untouched for at least 24 hours, probably the more the better. I'm just hoping that me messing with re-installing it doesn't impact how/if it cures. With the amount of spline contact it has I think I should be able to get quite a healthy amount of compound on there which is why it's making me think it may just work... I'll report back I guess.
I'm rooting for you man
I've been meaning to tackle that exact same noise for as long as I can remember but the whole idea of having to tear out the steering column doesn't amuse me at all, so far having the volume up has solve that issue for me
I changed the outer shaft that goes to the steering rack and I checked the intermediate shaft as I was putting the extension puck tighten everything and to be honest did not notice any improvements.
You probably seeing these already but in case you haven't. Most related vids I found.
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
Thanks! And yes, I've seen just about all the videos, relevant and not, that I could find. What I can tell you is that video #1 is definetely not the issue, nor do I think it really was for them... that tilt ball is spring loaded.. the gap is there for a reason. I have this gap, and it's by design. Maybe it increases some stiffness in the steering, but I just can't see that making any noise...
The second video is a complete waste of money and time to replace. His joint wasn't bad. It feels like it when you move the wheel around as the noise travels right into this joint. I literally have this intermediate shaft in my rockauto shopping cart I was going to buy and replace, and luckily I did more digging. All you have to do is take off that shaft just like he did, clamp it in a vice and check it out.. there was 0 noise. The fact that his rubber puck was moving around is literally the intent behind it. I saw a video where a guy replaced his puck with a solid machined steel disk. I'm sure this would also give more rigid feedback.. but you would probably feel a ton of feedback from the road... and ultimately it is not the cause of the noise/slop.
Many people have the noise/clunk issue due to loose bolts, I don't know how you get to that point.. lol , but again, that is super easy to check.. if you have a loose bolt, then ofcouse that is your issue. if all your bolts are tight, and you are on a 4th gen 4runner, I can say with almost 100% certainty that this splined shaft is the cause of any slop/clunk related issues.
This has been proven on the older columns as well that didn't have a splined shaft but the square tube interface and it did the same exact thing.. wear itself out a bit and wobble back and forth just a touch. In those cases a simple tack weld like shown in the first video would do the trick. In this case.. I am almost certain the outer splined shaft is aluminum and I'm not sure what the splined shaft is made of so no welding.. drilling and pinning would be the only mechanical fixing I would think.
I half-contemplated buying a used Tilt Only rack as I've seen 2 or 3 threads with guys swapping over from a tilt only to a telescoping rack in the 4th gens.. so the reverse should also work obviously. I think the Tilt Only rack should be a lot easier to fix in place to keep from rattling if it is worn out since it would have a splined shaft to slide like mine does.
Anyhow.. What I can tell you is that pulling the rack really isnt THAT bad.. you just have to be mindful of all the spline alignment points before you take it off and apart. I failed to do so and had to reclock my steering wheel.. not a huge issue but still. There are literally 4 nuts that hold the entire rack in with a few plugs that come right off. When I pull it again I'm certain I can do it under 15 minutes with maybe 20-30 tops to re-install.
If this Loctite M680 compound doesn't do the trick I'll probably look into getting my hands on a Tilt Only rack setup and see what it will take to swap.. Kind of curious to know if I can just pull the internal shaft out and swap into my telescoping housing.. that would make it super easy. lol.
Out with the not-so-old-but-slightly-damaged-due-to-me-being-an-idiot rotor/pads and in with the new. Pretty proud of my job on this.. 1 hour in and out for both sides, which also included taking off the wheel spacers, cleaning up the threads on the studs, and chasing the threads on all the spacer nuts before re-installing. It's hot and miserable out so I try to not be out there longer than needed.
You can see some of the damage caused by the wheeling leaning into the wheel while snapping the caliper bolts. It honestly didn't feel bad, no new noises or vibration really, but I decided I was lucky enough already and not to take a chance. I went with 100% OEM toyota rotors and & pads so we'll see how they do.
I'll have to find a decent route to get the bedding out of the way.. but that may have to wait until later this evening. Excited to see how these perform compared to the Brembo pad/rotor setup I had which was cheaper than the OEM but felt to be good quality.
Oh yea.. I am also going up a spacer size for the rear wheels to see if it will resolve my rubbing issue on the TK1 racing sway bar without having to relocate the tabs for it. I looked at flipping it around but that would put the potential point of contact on the tip of the bolt which definitely would put a nice hole in the sidewall. At least right now it is rubbing a large smooth, rounded surface of the heim joint. When I get the rear spacers swapped out, Im going to swap the one that took a trip to the woods just to be on the safe side. Nothing should be wrong with it, and the studs shouldn't have been stressed anymore than they do with the wheel rolling as usual... but just for the last bit of added peace of mind..
I guess its safe to say you are a man on a mission my friend keep us posted.
LC Prado 150
4th Gen 4Runner
1GR-FE
Looks like the 4th time around pulling the column is a lot quicker lol. As expected I only took 10-15 mins to get the assembly out.
Here is my final attempt with the current assembly.. took some time cleaning up al the grease and marking the splines for quick alignment. Ended up using the 660 compound that is more like a paste on the lower section and the 680 compound higher up. I slid the shaft around a few times to get the fluid down and reassembled as quick as I could to let it sit and cure. Maybe I’m losing my mind .. but it felt kind of promising eve after a few minutes while I was working with it .. who knows.. maybe this will do the trick. I mean it holds messed up keyways in place which is a ton more load than I’ll see here. Only concern here is vibration that could maybe break it down quick.. time will tell. I’ll try and post the video of the slop.
And while I was at it I decided to address the rubbing issue on the lower shaft.
Not a crazy rub but definitely interference.. since the shaft sidewall is pretty thick I decided taking off a mm or two wouldn’t hurt anything. The ujoint also had plenty of beef to knockdown a bit.
Tomorrow I’ll try and see if I can get a Dremel in there to sand the reinforcement I welded in as well.. just to be on the safe side.
