Old 08-01-2022, 01:39 PM #721
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is online now
Real Name: Brett
4RunnerAquasport is a splendid one to behold 4RunnerAquasport is a splendid one to behold 4RunnerAquasport is a splendid one to behold 4RunnerAquasport is a splendid one to behold 4RunnerAquasport is a splendid one to behold 4RunnerAquasport is a splendid one to behold 4RunnerAquasport is a splendid one to behold
Real Name: Brett
I was able to stretch the wires for the original cig port and just relocated a new one in there.
Too many electronics to charge these days to lose an outlet up front lol
aemravan's build thread - project TacoRunner-20220208_115838-jpg
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is online now   Reply With QuoteReply With Quote
Old 08-01-2022, 02:41 PM #722
aemravan aemravan is offline
aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future
I have a dual usb charger plug I wired in place of the original lighter in the center console so Iím covered there.
Ended up being able to relocate the 115v AC plug close by as well, my midland radio has lines running through the original location and I figured running it all the way to the back was not reasonable.. I want to be able to see my battery pack charging and unplug it while driving if needed. I was pleasantly surprised to see that I was getting the same near-100watt output in car as I was with my household outlet. This will charge up the battery packs as fast as itís possible to charge them.
Now all I have left to do is run my lines to the auxbeam fuse box..
2003 Limited V8 4runner - Tacoma Front End Swap - Icon 2.5 front coilovers - Dobinsons IMS59-50575 LT Shocks w/ C59-749V springs - Coastal Off-Road Bumpers - ARB Front/Rear Lockers - 4.56 Gears - RCV front axles - Twin-stick FJ T-case swap - LC200 Steering Rack Swap
aemravan is offline   Reply With QuoteReply With Quote
Old 08-01-2022, 02:47 PM #723
Real Name: Brett
Real Name: Brett
Is that a factory 115v AC inverter?
If it is I didnt know the 4th gens had that option.
Old 08-01-2022, 02:55 PM #724
It is. I have a button on the dash next to the factory diff lock button that says 115V AC/100w. The plug was originally located down in the glove box. Didn't realize this was not standard across all 4runners.
Old 08-01-2022, 05:46 PM #725
Real Name: Brett
Real Name: Brett
I have one in my 5th gen Limited, which has one in the console and in the pass side cargo area. It is the same circuit though.
Never knew they came in the 4th gen.
Old 08-02-2022, 06:07 AM #726
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of
Real Name: Skip
The 110V outlet came in the Limited trims in the 4th Gens.
2004 Limited V8
Old 08-02-2022, 07:57 AM #727
Well then.. I feel very fortunate to have picked up a wrecked limited model. Until now I always thought it was a neat thing to have but didn't really see a need for it.. boy was I wrong. Having a moving household outlet with you on the road is pretty damn sweet.
I received by BLUETTI battery pack yesterday, the 500 watt-hour one, charged it up and plugged my fridge in to run. Started the test at 3:40 pm yesterday with the fridge at room temperature and not precooled. Woke up this morning and it's still running. As of 8 a.m. right now it has been running for a bit over 16 hours (if my math is right ) and the battery indicator is still up at the 40-60% tab. So even worst case scenario I may have burned through 3/5th of the battery and still going strong. I don't see an issue with it hitting another 8 hours which is awesome. This should definitely give me enough off-road juice to run the fridge for the weekend if I have it powered off the rig while driving and am able to top off the battery packs a bit with the solar panels if needed.
Edit** the battery pack ended up running 24.5 hours before I turned it off. Probably still had more juice left in it but 24 hours is more than plenty for me.
Old 08-03-2022, 08:38 PM #728
thegame7 thegame7 is offline
thegame7 has a spectacular aura about thegame7 has a spectacular aura about thegame7 has a spectacular aura about
My Sport Edition has the same 110v outlet, rear seat entertainment and the JBL system. Old school cool Must've been a highly optioned out Sport
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers
thegame7 is offline   Reply With QuoteReply With Quote
Old 08-08-2022, 01:02 PM #729
No 4runner updates, but I did get my supra up and running and out of the garage with the latest build nearing completion. Excited to drive it again!
Old 08-09-2022, 05:40 PM #730
originalg00kster's Avatar
originalg00kster originalg00kster is offline
originalg00kster has a spectacular aura about originalg00kster has a spectacular aura about originalg00kster has a spectacular aura about
^^ OMG bro.....why were you even posting the 4runner this whole time?? haha I hope one day...I can build out my dream car. I would love a NSX.
07 SR5 4x4
originalg00kster is offline   Reply With QuoteReply With Quote
Old 08-10-2022, 02:26 PM #731
it is the 4runner forums after all ;)
But yea, I'm super grateful that I've been able to own and build my supra for the past 18 years. It's never done and forever evolving, granted a little less now that I have the 4runner to spend time and money on lol. The NSX platform is also awesome. Anything from the 90's Japanese sports car era has a special place in my heart.
Old 08-11-2022, 02:13 PM #732
back to the regular scheduled programming of 4runner content..
Finally made some time to run and grab some slide/tilt drawer supplies for the fridge. Looked at a few designs from some DIY videos and put together my own take from a few different ones I liked.
The platform is a 3/4" plywood sheet (holy hell did the prices go up on these! 2x4' sheet was $34 damn !!) that is screwed in between the 2 locking 30" slides I got from ebay.
I went with slides slightly longer than the fridge itself so it would give me some roof for straps and a little handle. The idea is to then weld 2 1' square tubes right to the bottom of the slides. The front tube will then get 2 gate hinges welded to it and ultimately bolted down to the top of the rear drawer system. The rear square tube will have a limit strap attached to it so that the fridge has something stopping it from fully pitching forward.
The fridge itself will be held down by a strap that loops under the 3/4" plywood and goes from handle to handle. Should be plenty strong enough to hold it in place, but I may also add a small lip to the front of the plywood to help distribute the weight when the assembly is tilted downward.
I also elected to get a 3/4" tube to weld between the 2 leading edges of the slide to give it a bit more reinforcement as well as provide a pull handle when the sliding latches are unlocked.
Taking this setup to weld up really quick this evening so we'll see how it comes out.. so far I'm in about $74 bucks and 30 minutes of work.
Old 08-11-2022, 09:00 PM #733
I guess weíll see how it holds up ..
Old 08-12-2022, 06:19 PM #734
Took some time during lunch to brake down the rear axles. Only took an hour to pull, but I know it will take at least 3 times longer to put together with those damn rear drum brakes lol.
What I found was very significant play when holding the Axle and wiggling the backing plate, I am assuming there should be 0 play with a good bearing. One side was worse than the other but both were pretty bad.
I imagine this is the cause of the noises Iím hearing. Going to take it over to my dads press tomorrow and see if I can get this swapped out. Iím a dummy though.. I didnít realize at all that I needed new wheel studs for the new axlesÖ could have ordered a decent replacement online but now Iíll be picking up a Dorman replacement set from Napa in the morning. Would have been nice to go with something like an arp stud that was extended but I canít wait.
Old 08-12-2022, 07:18 PM #735
Real Name: Brett
Real Name: Brett
Check the knurl diameter of the axle hub before you buy the studs. It may not match up with a dorman replacement stud. Had it happen w my front dorman hubs a couple years ago. PIA
car , front , pretty , rear , time
Project Mayhem Build Thread MaYheM97 3rd gen T4Rs 17 11-27-2016 03:02 AM
Project 1Ton "build thread" Many Pic's! GonOvr Classic T4Rs 161 10-17-2016 01:11 AM
SOCO4RUNR's T4R Project Build Thread SOCO4RUNR 3rd gen T4Rs 5 09-26-2013 09:21 AM
Pitbull Rescuer's New Project/Build Thread PitbullRescuer 3rd gen T4Rs 93 09-16-2012 11:46 PM
