02-20-2023, 12:02 AM
#901
A little late to the party with the heater since it’s warming up .. but figured it could be a nice way to get out with the wife while temps are still low.
Decided not to hassle building my own to see if this is something that will work for my setup and the testing so far has been great. Not expecting it to last too long for just under $200 and if it does what I need it and fails at some point I’ll probably build my own into a more storable case with a nicer unit. So far the all in one setup has been pretty dang amazing.
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
02-22-2023, 11:16 PM
#902
I was sitting here a couple of days ago and something dawned on me .. my initial idea of “temporary” cheap lower control arms is slowly turning into a long term solution .. which means cheap ball joints .. that’s coupled with 35s made me think of suffering another suspension failure on the road.. yikes.
After doing a little searching I ordered a set of sankei 555 ball joints to throw in as an added peace of mind.. will try and tackle this in the next week or two.
02-23-2023, 02:17 PM
#903
+1 for the 555s ball joints. Been running them for a while with no issues. Also using their inner/outer tie rods.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
02-23-2023, 05:04 PM
#904
Well that was fast … and boy do these loom fantastic ! Gonna pick up the balljoint press from autozone for rent on the way to the office and hopefully get this knocked out this weekend !
02-24-2023, 07:20 PM
#905
Fingers crossed that I didn’t miss any bolts or torques.. lol
Piece of cake.. froze the new joints going in, heated the lowers and hammered out the old joints without an issue. Took a little figuring out with clearance without taking the front end apart but it’s on..
Didn’t want to over torque the castle but on the balljoint and from what I found it should be around 118 ft lbs or so.. felt fairly easy all the way through and decided not to keep cranking .. I’ll give it a few road miles and check to make sure it’s still on there lol.
Also did a 5 tire rotation all the way around while I was at it. Almost shit myself putting the spare back on myself .. it’s heavy, high up and have to line up my rear facing camera through one of the holes. Now to go drink beer.
03-06-2023, 10:50 AM
#906
Finally got out to enjoy some awesome camping. No wheeling but a good time nonetheless.
7 hour round trip and nothing has fallen off the rig.. so slowly building more confidence in it. (Knock on wood).
I didn’t need 4wd.. but was going to throw in it just bc we were on a dirt road and mound myself unable to do so in the first few quick attempts.. felt like quite a bind on the shifter so I didn’t continue to force it in fear of getting myself in a pickle almost 4 hours from home.
Need to test this out in the drive way, but I have a feeling the bind is coming from the front shaft being spin by the wheels (also seems related to my clunking issue I had earlier ). Really making me want to pick up a factory t case and do a factor my j pattern shifter on it sooner than later.. I’m still working on getting my hands on the original 4wd case to r&d a manual linkage for it which would be the absolute idea setup over the FJ case.
03-07-2023, 07:40 PM
#907
And my new home has arrived. Now just to source a Thule cargo carrier and my RTT is going for sale.
03-11-2023, 03:59 PM
#908
Even though I’m not camping this weekend in the amazing weather at least my other guilty pleasure is fully running. It’s a different joy from being lost in the woods for a weekend but one I couldn’t live without.
Just got my turbo housing machined by OCD works to resembles the old school HKS t51r KAI turbo spool sound and I’ll be lucky to get 5mpg now.. REALLY hard to stay out of boost.
03-20-2023, 04:11 PM
#909
this weekend I did something I didn't think was ever going to happen (so much so that I actually threw away my original part shortly after removing it )
I re-installed the front sway bar on the rig after finding a local toyota guy who was willing to give his away free of charge .
What a difference... I haven't used my rig for rock crawling in quite some time, and frankly, don't think I have the off-road bug nearly as bad as I thought I would when I started... I am perfectly happy getting out to camp (while having the possibility to reach places most other regular offroad vehicle can't, if the opportunity presented itself lol).
After the last drive up to the mountains with the rig fully loaded and my wife and dogs along for the ride I realized how idiotic it is for me to drive a 90% street drive, 10% off road driven (.5% of which MAY be rock crawling where I may benefit?) rig with no front sway bar. The difference is night and day, the handling is phenomenal, and from what I've see, I may have lost 2 inches in total articulation which I'll gladly give up for all the other Pro's of having a sway bar.
I have also, once again, confirmed that anyone who tells you that driving on the street with no sway bars makes no difference at all are lying either to you, themselves, or both. lol
03-20-2023, 04:52 PM
#910
I used to run no sway bars and it was sketchy driving on the backroads or making any sudden maneuvers. Then I installed my PCK and it was way better. Then I put my rear sway bar back on. Then after awhile I put my front back on. I did the whole cycle lol.
I watched this on youtube who did a articulation test using all the different options and he ended up going with a thicker rear sway bar and no front. That gave him the best articulation for his setup.
https://www.youtube.com/watch?v=gcgK...r%27sAdventure
really good information from this video. Ive been looking at doing a thicker rear sway bar from either Addco or Superpro
03-20-2023, 05:26 PM
#911
Real Name: Brett
Real Name: Brett
It takes a lot of getting used to driving a bowl of soup. My 5th gen handles like a rally car compared to the 4th gen with the old standard length suspension and no ASB.
Entry, Apex, and Exits on corners had to be approached completely different. Quick hwy moves had to be done very cautiously, with a certain amount of sphincter pucker up.
Now that I have the bypasses in the front, revalved the rear shocks, and added the Anti Rock, the 4th gen does a whole lot better.
But, on a road like Tail of the Dragon? Gimme that 5th gen ASB everytime.
1988 DLX 22RE AUTO BLACK- "Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
03-20-2023, 09:49 PM
#912
Hmm didn't know thicker rear sway bars were an option. I wonder if thinner fronts are also an option? I currently have just the front in and it's pretty stiff still. Though I think my shock valving and E range tires contribute more to the harshness.
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers, DT short headers
03-22-2023, 07:20 AM
#913
Yup, that’s the video that got me thinking about throwing sway bars on the begin with lol. After going long travel in the rear and removing both sway bars I expected my articulation going up a ramp at work to be much improved .. I quickly found that as I started driving up it with one front wheel, the weight just fell over backwards and I was getting next to no compression on the front wheel , which obviously makes sense but the video helped reassure that
03-22-2023, 07:23 AM
#914
Tk1 racing is what I run in the rear. It’s a lot of custom work to have had it fitted but it’s pretty much the same idea as the Anti Rock bars jeep guys run.
Thinner front bar was my first question as well .. seems like if we could go down in stiffness about 30% or so it would give the best combination of articulation while also not falling over in turns
04-22-2023, 02:59 PM
#915
Since the building stopped so has the posting .. what a shame ! Been trying to enjoy the rig recently more than just working on it. Decided against wheeling much .. I guess that was a temporary bug .. the camping and overlanding has been alive and well though .. perfected the pack out set up over the last couple of trips and so far everything has been pretty sweet.
I have considered a different rig to build for camping trips but ultimately decided I would end up with another money dump that wouldn’t be far off of this one, and it’s just not feasible to sell this for the amount of time and effort I have into making this as unique as it is, so unless something drastic changes I decided I’m keeping it long term.
With that said .. after using the rig I have decided on the list of most wasteful and regretted modifications I’ve done.. this isn’t the same for everyone , for my purposes I have found the below to be a complete waste of time, money and arguably ultimate reduction in the original Toyota reliability ..
-RCV axles: absolute biggest waste of money for a non dedicated crawler.. street reliability has been absolute shit, and for the money the return in investment for replacing blown axles is years and years down the road. Not to mention.. running RCV axles moved my fuse point further into the front diff.. which caused housing to explode when I hit a boulder with some wheel speed.
-front locker: waste of money and needs to be used with great caution.. maybe there are applications for it, but for me, the misuse left me with a blow out intermediate shaft. I wish I just stuck with a rear locker.
-lc200 rack: save your time and money and either keep the factory rack with replacement tie rods (that can be done in no time on the trail) or go the machined tundra rack. Ultimately the amount of customization and non factory parts have probably left me with a potential to be stuck on a trail of anything we’re to go wrong. Not to mention now my tie rod is a hiem joint which is exposed and not likely to last very long on a street drive rig.. the messed up geometry is another downside.
-FJ t case- though not a bad mod , I am considering going either to a j pattern shifter or back to the factory center case with a diff that is manually actuated .. I’m getting weird engagement noises even in 2wd and I suspect that it has something to do with the twin stick conversion.
I am also heavily considering pulling the TK1 racing bar. In favor of an extended tank since I don’t need to have the full rear down travel for regular trips that don’t involve rock crawling ..
