Old 02-18-2021, 09:44 PM #1
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
6112 Lift Numbers
Hey guys. I’ve got a V8 with no extra weight. No skids. No bumpers. No roof rack. Looking at Bilstein 6112 with upgraded 650 lb springs. Looking to gain 2.0” - 2.5” up front. It looks like circlip location 4 is advertised at 2.26” lift, but that’s with the standard 600 lb spring.
Does anyone have this exact setup (V8, no weight, 6112 with 650 Springs)? If so, what setting did you use and how much lift did you gain?
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 02-19-2021, 03:53 PM #2
neoguri neoguri is offline
neoguri is on a distinguished road
Got 650lb coils recently and about 2 inch of lift on my v8. 4th ring.
2006 Limited V8 4x4. Shadow Mica. FN fx pro wheels. bfg ko2 265/70/17 load range C.
Full album
neoguri is offline   Reply With QuoteReply With Quote
Old 02-19-2021, 05:17 PM #3
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
That’s interesting because it shows 4th should be 2.26” with standard springs. Would day day you got over or under 2” of lift?
Old 02-21-2021, 01:18 PM #4
I got like barely over 2...1/8 maybe...
Full album
Old 02-22-2021, 01:09 AM #5
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
What springs are you running in the rear?
Old 02-22-2021, 03:41 AM #6
joshik joshik is offline
joshik will become famous soon enough
not sure if this is helpful but I installed this combo about 4 years ago.
I went with the coil that the 6112 comes with as I was not going to go with a winch or steel bumper. I maxed out the height on the coilover.
PRE LIFT # (center of wheel to fender)
Driver Front: 19
Driver Rear: 20 5/8
Passanger Front: 18 7/8
Passenger Rear: 20 5/8
POST LIFT:
Driver/Passenger Front: 23
Drive/Passenger Rear: 24
2003 4Runner Limited 4wd V8. JBA UCA, Dobinsons MRA Front Coilovers, Dobinsons MRA Long Travel rear. Cooper AT3 XLT 285/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
joshik is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 06:03 PM #7
dahveeed dahveeed is offline
dahveeed will become famous soon enough
Sorry I don't have numbers for you, but this is how mine came out.
I believe I went with the 5/3 setting. This kit is with the 650lbs front springs.
dahveeed is offline   Reply With QuoteReply With Quote
gain , iphone , lift , springs , weight
Bilstein 6112 Lift Heights Kamalani Mahie 5th gen T4Rs 25 04-12-2022 07:07 PM
600# lift springs for 6112 struts Badmeat 5th gen T4Rs 7 05-10-2018 07:12 AM
6112 circlip lift settings different on 2wd and 4wd 4runners?? SoFloT4Run 5th gen T4Rs 1 11-25-2017 11:40 PM
Alignment issues after Bilstein 6112 lift. Help! carrera0to60 5th gen T4Rs 27 08-07-2016 11:48 AM
