They can be a bear. You will need to soak the 6 studs and nuts also the 2 studs between the y pipe and the cat, and the 1 mounting bracket bolt holding the exhaust with penetrating lube for a couple days before you try and take it apart. Sometimes they come loose. Just go slow tighten and loosen the nuts until they break free.
2004 V6 4Runner=Dobinson's Front IMS59-50220 with OME 884 coils, Rear GS59-701 with OME 895 coils (these are awful stiff) will be changing to C59-675V, JBA upper control arms, custom extended rear sway bar links, Victory 4x4 roof rack, Tuff Stuff overland roof top tent, Falken wildpeak 285/70/17, Eagle alloy bullet hole wheels 9" wide -8 offset, BMC.
