Old 02-21-2021, 10:51 PM #1
ieatfish's Avatar
ieatfish ieatfish is offline
ieatfish will become famous soon enough
ieatfish's Avatar
Wet Passenger Floor - any ideas?
I'm noticing that the passenger floor underneath the mat gets damp. I'm almost positive it is related to the AC being on since there hasn't been any rain or moisture otherwise. I tried running some string trimmer line up the drain tube under the right passenger fender but didn't get any drainage or feel like I hit anything besides the bends in the tube. I've never seen any liquid come through there either and last summer I used the AC a lot (AZ).
Any ideas how best to troubleshoot this?
2006 4Runner Sport Edition 4WD V6
Dobinsons 2.5"/1.5" - C59-302, GS59-221, C59-505, GS59-705 | General Grabber ATX 265/70R17 | TPMS Bypass Mod
Custom Storage Box/Sleeping Platform Build | Dedicated Transmission Cooler (Derale D13503) | Demello Offroad Sliders
ieatfish is offline   Reply With QuoteReply With Quote
Old 02-22-2021, 09:31 AM #2
Burt Burt is offline
Burt is on a distinguished road
Do you see a wet spot under engine area after running AC during humid days? You should.
I think the AC evap coil drain tube spills out of the firewall on passenger side of engine compartment. Check if that tube is clogged.
Careful to not damage evap coil.
Or maybe dis-connected under dash?
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
Burt is offline   Reply With QuoteReply With Quote
Old 02-22-2021, 11:34 AM #3
ieatfish's Avatar
ieatfish's Avatar
No puddle, though humid days are hard to come by here. However, I feel like I should have seen something by now. I did check the tube with the string trimmer line but didn't unclog anything.
Anyone know or have pictures of the connection point? Can I get there without pulling the dash?
Old 02-23-2021, 10:38 PM #4
kerplunk kerplunk is offline
kerplunk is on a distinguished road
I know that you mentioned that the problem most likely isn't rain, but when I bought my truck, it had a similar problem. I found that the cause was that the cowl at the base of the windshield wasn't fully seated. On the underside of the cowl is a lip that diverts water away from the opening for the HVAC, and if it's not in the right place, water will spill down the windshield, through the cabin air filter, the fan, and onto the floor.
The windshield had been replaced at some point, and the installer did a crap job, not trimming off the excess adhesive which in turn kept the cowl from engaging fully.
Hope this helps. At the very least it's something to consider.
Good luck.
kerplunk is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 04:52 PM #5
drallan drallan is offline
drallan is on a distinguished road
I'll try and look up what I used. But had a similar issue on the 04 V8 a few summers ago. After a long road trip found that the passenger floor was filled with water. Immediately panicked thinking it was heater core. No off color or smell and ultimately determined it was a clogged A/C condensation drain. There was an a/c condenser / coil cleaning kit that I got. It came with a long hose and spray can that you shove up the drain valve, and spray the cleaner up and it is supposed to clean off the coils and dissolve any blockages. I ran 1-2 cans of the stuff and followed directions on the packaging and my problem went away and hasn't returned since. Been a couple of years now.
Lubegard 96030 Kool-It Evaporator and Heater Foam Cleaner
drallan is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 08:49 PM #6
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
You should be able to carefully pull plastic trim panel off the side and see the tube on the passenger side. You can drop the tray (there's one philips head screw that holds it on and then just pop it off, you can let it hang; no need to bother unplugging the modules) under the glovebox if you are having trouble getting it out/back in.
But that will let you know if it's connected to the HVAC box, you can pull back the carpet a little after taking the tray under the glovebox out and see if there's any holes or such on it's way out of the body.
Wet Passenger Floor - any ideas?-20210308_164216-jpg
Wet Passenger Floor - any ideas?-20210308_164333-jpg
BlackWorksInc is offline   Reply With QuoteReply With Quote
floor , ideas , passenger , tube , wet
Leak on passenger front, any ideas? gmoney35c 5th gen T4Rs 9 10-10-2015 10:04 PM
Water build up in my passenger side floor and behind passenger seat a4runner97 3rd gen T4Rs 12 03-23-2013 01:48 PM
New Floor Ideas mshaner152 4th Gen T4Rs 4 02-29-2012 01:55 PM
Interior floor options / ideas, help vujo310 5th gen T4Rs 6 09-29-2011 08:08 PM
Passenger side rattling noise...ideas? hokieSR5 Problems & Warranty Issues 6 03-07-2011 11:55 PM
