I’ve been going nuts over this same problem with my daughter’s ‘03 Camry! I pulled the carpet and surrounding panels and found the rubber drain hose for the a/c and there was space around the grommet where it goes through the floor to drain (I could see the ground), so I used some clear silicone to seal that in hopes it was water splashing up from driving in the rain. No such luck! I’m going to have to tear it back apart again because the carpet is soaked again! She doesn’t even have a sunroof, so it must be related to the a/c.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
