Old 03-03-2021, 01:28 PM #16
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 will become famous soon enough randy88fj62 will become famous soon enough
Have you downloaded the manual?
Time to do the step by step tests in there.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 03-03-2021, 06:55 PM #17
chocker chocker is offline
chocker is on a distinguished road
I'm having a hard time to download the manual.
chocker is offline   Reply With QuoteReply With Quote
Old 03-03-2021, 10:48 PM #18
I found the manual and was able to download now. Unfortunately no time right now to test. I'll try to do it over the weekend weather permitting.
Old 03-08-2021, 04:56 PM #19
I finally had time to do some tests and the weather was cooperating. It was a practically balmy 30F degrees outside. I tested the Blue and Blue/Red wires on the harness going to the ECU. They each had a constant 12V which they are supposed to have. ECU-B fuse is good as well. The door latches correctly when closing (meaning the actuator pulls in the door). I did a direct test on the actuator harness (Blue/Black and Blue/Red wires) and was able to open the tailgate with a power source. I tested the switch by unplugging it at the switch and completing the circuit and nothing happened. I am going to try to get another ECU to at least test. It's weird that this is the only thing that is not working for the ECU. My defrost and rear window both work correctly.
Old 03-08-2021, 06:29 PM #20
Can anyone tell me what wires to connect on the switch connector inside the door but just below the tailgate garnish under the switch. I want to test from there as well. It is a 4 pin connector.
Old 03-09-2021, 03:32 PM #21
Well I checked all the wires to the switch and found one that was broken right where it went into the tailgate. It must have broken from being bent all these years. I cut out the bad part and added an extra piece of wire. Tested it and it all worked fine. I still needed the replacement actuator as the motor was burnt either way.
Old 03-09-2021, 07:48 PM #22
Syr4RinNC's Avatar
Syr4RinNC has a spectacular aura about Syr4RinNC has a spectacular aura about
Syr4RinNC's Avatar
Glad to hear you had a conclusion. Wiring stuff is a pain in the butt. I generally feel pretty frustrated after all the time spent on figuring things out and repairing them, but hopefully its an accomplishment and all behind you now
2008 SR5 4WD Black. Bilstein 5100, 5th gen coils/ rear springs. 265 70 17 AT for everyday use. Victory Sliders. headunit upgrade. Back up camera install. Expert at replacement rear hatches
Old 03-09-2021, 10:21 PM #23
Yeah, it was long and at one point I was thinking of just getting another ECU but then I went back for another crack at it. Very satisfying in the end. Thanks everyone for the input though. Much appreciated.
actuator , ecu , power , removed , tailgate
Opening rear tailgate 4gambler 5th gen T4Rs 30 10-16-2019 10:25 PM
Another 4th Gen 2005 4Runner Tailgate AND Rear Window not opening nimmo Problems & Warranty Issues 0 03-13-2017 08:01 AM
Tailgate Opening Pad Turning to Mush alaskaman 4th Gen T4Rs 7 07-14-2015 08:29 PM
rear door not opening? morbidsanity 3rd gen T4Rs 2 02-18-2013 10:15 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
