Old 02-23-2021, 05:51 PM #1
Steamdonkey Steamdonkey is offline
Steamdonkey is on a distinguished road
Has anyone tried 5th or 6th gen OEM wheels/tires?
My '04 needs tires and someone nearby has a like-new set of 2021 take-offs for sale. The wheel offset looks to be 15mm different as the '21 wheel offset is ET15 vs. the '04 which is ET30. Is that enough to worry about?
The member formerly known as Iowa4Runner
(2004 Pacific Blue SR5 4WD V8)
Steamdonkey is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 06:07 PM #2
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Most people are able to run the 5th gen wheels with no problem. However, if its the tires too, they are slightly bigger than 4th gen stocks (265/70/17 vs 265/65/17).
There are some other threads on here you can search and read through about 265 70 17 on stocks.
Bottom line- you may be fine, may have minor rubbing with bigger tires. If you have a lift, will be fine no issues
Old 02-23-2021, 06:30 PM #3
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
Wheels will fit fine. If going up to 265/70/17 tires you might need to trim, but not likely.
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 06:38 PM #4
Piggity Piggity is offline
Piggity will become famous soon enough
There is no 6th gen out yet. The OEM wheel and tire size on the 5th gen will fit on the 4th gen easily.
Past: 06' Limited 4WD V6 Nautical Blue Metallic
265/65R18 Cooper A/TW tires with TT - 2018 Forest River 201BHXL
Present: 08' Tundra Limited
33" Duratrac, spacer Lift with TT - 2022 Keystone 252RD
Piggity is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 08:41 PM #5
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I have the 7 spoke 5th gen wheels (17x7.5) that are shown in my signature photo. I also have a set of 17x7 6 spoke 5th gen oem wheels.
33” tires, 3”F/2”R suspension lift, +1” body lift.
I did minimal fender trimming and moving the inner front wheel well liners, and no rubbing at all. I’m also running Spidertrax 1.25” wheel spacers.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 09:07 PM #6
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
I have my OG suspension with early 5th gen trail edition wheels (17x7.5 +15) and 265/70r17 falken wildpeaks. Rubbed just a tad bit on full lock turning, but that was fixed by stretching the fender liners
I've got some pics on both the wheels/tires and the fender liner stretch linked here
Fender liner stretch: y=mx+b's Build Thread
Wheels and tires: y=mx+b's Build Thread
Before and after stretch
y=mx+b is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 10:25 PM #7
Thanks for all the great responses guys. I found a set of take-offs from a 21' Tacoma TRD Offroad - 265/70R16, which is the exact tire size I have now. Even though I have 16" wheels, I'm still a little rattled by something I found online-
"TRD Pro wheels are available in 2 sizes: 16" diameter and 17" diameter. Both of these TRD Pro wheels are 7" wide. The 16" TRD Pro wheels are made specifically for Tacomas, and the 17" TRD Pro wheels are made specifically for 4Runners and FJ Cruisers"
The offset is ET13 (assuming I did my homework correctly) so it seems like they should work. Any obvious flaws in my logic?
Old 02-23-2021, 11:43 PM #8
kerplunk kerplunk is offline
kerplunk is on a distinguished road
I have the black TRD pro 17" rims on my '05. The offset is +4mm and allows my 33" tires to clear my JBA UCAs. They work really well and look nice too.
The stock brakes on the sr5 4th gens are small enough to allow the use of a 16" wheel. However, the sport edition and Limited brakes are larger and require 17s I believe.
Here's a FAQ I found on the TRD pro rims.
TRD Pro Wheels FAQs - All You Need To Know | Toyota Parts Center Blog
2005 sr5 v6 4x4
kerplunk is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 11:52 PM #9
Just to clarify, I believe that the distinction of the 16" rims being only for the Tacomas is due to the fact that all 5th gen 4runners require 17" rims, and they're not including us guys with the old sr5 4th gens. I would be really confident that those 16" TRD pros would be fine for you.
2005 sr5 v6 4x4
Old 02-24-2021, 01:09 PM #10
Thanks again for all the helpful feedback, this forum rocks!
Old 02-24-2021, 02:25 PM #11
ads2539's Avatar
ads2539's Avatar
My 4th gen Limited (bought used) came with 17” rims, but the smaller brakes so I can also use 16” rims. I have one set of 16” rims and tires (265/75r16), and they fit great. My rims are not OEM Toyota, but close. They are Prime wheels, and were a port installed option for the “Southeast Edition” or the “Texas Edition” 4Runner. I bought the wheels used.
The wheels in my signature photo are 17”.
Old 02-24-2021, 06:13 PM #12
The verdict is in... Perfect fit!
Has anyone tried 5th or 6th gen OEM wheels/tires?-wheels-jpg
Old 02-24-2021, 08:51 PM #13
Lookin' good!
...and thanks to Ads2539 for the correction about the limited brakes. Good to know.
2005 sr5 v6 4x4
Old 02-24-2021, 11:34 PM #14
ads2539's Avatar
ads2539's Avatar
Lookin' good!
I assume some Limiteds have the optional (?) bigger brakes. Mine just doesn’t.
et15 , et30 , offset , sale , wheel
FS:TOYO open county 295-70-R17 tires/Trail edition wheels w/general 265 tires 97supratt For Sale: Suspension/Wheels/Tires 17 01-07-2020 03:09 PM
Trade new 15ltd wheels and tires for set of Trd wheels and tires or nice 17"/18" afte rok medic Want to Buy/Trade 0 11-13-2015 10:12 AM
FS: (4)17" 5th gen stock wheels and tires (near new tires) SOCAL Gesekee19 For Sale: Suspension/Wheels/Tires 3 10-07-2013 11:43 PM
WTB or Trade: 5th gen SR5 wheels/tires for limited wheels/tires isuvbjordan Want to Buy/Trade 1 09-16-2011 02:58 PM
WTT: 18" 2008 Limited wheels with tires for 17" FJ wheels w/ tires T4R4TR Want to Buy/Trade 2 06-25-2011 04:35 PM
