Old 02-23-2021, 10:09 PM #1
dsanford dsanford is offline
dsanford will become famous soon enough
Strange Engine Noise
Fist noticed this noise 02/21/2021. The video below was filmed 02/23/2021. The sound seems to be coming from the right valve cover nearest to the radiator. I have not noticed the noise at cold start or during driving. To far away from driving position and to much other wind noise. I have only noticed it at idle after a drive. No DTC showing. I have not done any other testing or diag. This weekend I plan on removing the timing chain tensioner inspection plate, possibly a compression test, leak down test and putting a video scope down the spark plug holes to see if there is any piston slap on the cylinder walls. Also doing a oil change to inspect the oil and filter as well as sending a sample off to Blackstone for analysis. I do not believe it is piston slap because I do not notice any oil consumption or excessive smoke from the exhaust and stated as above I do not notice it at cold start.
The strange thing is I am still seeing good MPGs, I do not feel any stutter or rough idle. No milky look to the oil and no signs of oil in the coolant.
All that being said, I could really use more opinions on the matter. See video below. Thank you to anyone who chimes in.
https://www.youtube.com/watch?v=gT7BDdxD_kM&feature=youtu.be
2006 GGM Sport 4WD / Lots of maintenance from neglect (from previous owner) / Interior & Exterior LED swap / Sony XAV-AX1000, Kicker front door speakers, Kenwood tweeter replacement / Diode Dynamics SS3 Fogs
dsanford is offline   Reply With QuoteReply With Quote
noise , noticed , oil , slap” , video
Strange engine sound/noise Rob P. 3rd gen T4Rs 0 05-27-2016 02:32 PM
Strange harmonic noise coming from engine alex56 4th Gen T4Rs 13 12-16-2015 10:50 PM
Video: strange noise at V6 engine start - chain? banzaj 4th Gen T4Rs 9 04-15-2015 05:35 AM
Strange Noise - HELP scottblink23 4th Gen T4Rs 19 01-20-2015 07:59 AM
Strange engine noise under load - bad coil pack??? jksmyers 3rd gen T4Rs 2 07-16-2011 09:09 PM
