Old 02-24-2021, 11:50 AM #1
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Blower Motor Tips and Hints (not the frozen TSB)
I have a 2008 V8 SE and the blower motor has intermittently gone out over the past few months. I read all the posts on here then went through the Factory Service Manual (FSM).
The FSM has you check the blue 5 pin Heater Relay in our Fuse Box under the hood. A quick check of that relay's operation and verifying the connectors it plugs into were good and I moved onto the fuses.
Next I checked these fuses:
-50 Amp large Heater Fuse
-7.5 Amp Heater No. 2 Fuse
*All items described above are shown on the inside cover of your fuse box.
Knowing all the fuses were good I took the passenger front seat kick panel off (just under the glove box). Phillips head screw driver takes off the one screw and the panel will gently pop off toward you.
Inside you can see the Blower Motor and the A/C Amp. I pulled the connector off the Blower Motor and turned on the system. My volt meter showed 12 Volts was getting to the Blower Motor. I tapped it with dead blow hammer and it came back on.
So moral of the story is tap on the blower motor under the glove box and you may eek out another year or two out of it. If mine continues to quit I'll replace it with a new one.
Blower Motor Toyota P/N 8713035171
In Summary:
Heater Relay
Heater Fuse
Heater No 2 Fuse
Blower Motor
then A/C Amp
All these steps are covered under the FSM in the Air Conditioning System Pages.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
blower , box , fuse , heater , motor
Frozen blower generalcorrosion 4th Gen T4Rs 4 02-08-2014 08:55 AM
Toytec ultimate 3" front adjustable lift, any tips, tricks or hints? Lignum 3rd gen T4Rs 25 11-15-2013 08:51 PM
Modding Tips, Tricks & Hints GrantK 5th gen T4Rs 39 12-18-2012 10:26 PM
Hints or tips are welcome. Head job. dustinthewind Classic T4Rs 2 04-02-2011 04:03 PM
Brakes- frozen, maintenance, tips DiskDoctr 4th Gen T4Rs 1 12-15-2010 06:55 PM
