Old 02-28-2021, 06:01 PM #1
Placemotorsports Placemotorsports is offline
Placemotorsports is on a distinguished road
Tacoma suspension question
Picked up front springs and shocks and rear shocks from a 2020 TRD off road Tacoma today. Ordered new top hats and the bushings for the rear. My question is will I need a spacer in the back to make it look right and how much lift will those springs give my '05 V8.
Sent from my SM-G991U using Tapatalk
Placemotorsports is offline   Reply With QuoteReply With Quote
Old 03-01-2021, 12:29 AM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
If your current suspension is otherwise stock, you should get about 1" of lift from the Tacoma stuff. If you have collapsed XREAS, like I did, it ended up being like 3" of lift on mine. You should not need a spacer of any sort.
Did you get the correct lower bushing for the Tacoma rear shocks to work on the 4Runner?
Energy Suspension 9.8108G 3/4" Hourglass Shock Eye Bushing - Amazon.com: Energy Suspension 9.8108G 3/4" Hourglass Shock Eye Bushing: Automotive
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 03-01-2021, 09:09 AM #3
Yes those are the ones that I got for the rears and I got KYB top pieces for the front struts off Amazon. So with the added lift in the front the rear will still look ok?
Old 03-01-2021, 11:47 AM #4
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Should be fine. I used new 2007 FJ coils in the rear of mine when I replaced the XREAS. Had a slight stick bug stance but still looked fine. Easy enough to add small spacers later if you need to.
Old 03-01-2021, 12:43 PM #5
Jpilot Jpilot is offline
Real Name: Joe
Jpilot will become famous soon enough Jpilot will become famous soon enough
Real Name: Joe
No top hat needed either. I did this mod to my ‘06. Tore out the XREAS, did the rear bushing and installed. About 2” of lift (my xreas was trashed) and looks great with 265/70r17 tires.
2015 T4R Trail Red, 3” lift, 285s, Niserack, HF rock sliders, BA bumper
2006 4runner sport, v6, Tacoma TRD springs front, airbags And 2” spacers in rear. 440k and still chuggin along.
1977 FJ40, V8, lifted, Warn 8274 winch etc.
2006 GX470, 285s, 2” lift, C4lo sliders
Jpilot is offline   Reply With QuoteReply With Quote
Old 03-01-2021, 03:04 PM #6
No top mount needed? When I got mine they were loose coils on the front struts
Old 03-01-2021, 03:15 PM #7
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Yes, you need the top hat if you are unable to use your old ones.
Old 03-01-2021, 06:06 PM #8
I just figured being original be best to replace them
Old 03-01-2021, 08:18 PM #9
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
I didn’t need to on my ‘07. But to your point, consider new rear springs if you’re replacing everything else. They’re not that expensive.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 03-01-2021, 08:19 PM #10
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Agreed. I got my FJ rear springs from RockAuto for like $70 shipped.
Old 03-02-2021, 02:27 AM #11
Real Name: Joe
Real Name: Joe
I guess it just depends on what your getting from the last owner. I got the entire front strut assembly. Bolted right in.
Old 03-02-2021, 08:41 AM #12
Previous owner reused the top hats so that's why I purchased new. Wish they would have been together to save me the spring compression but local deals are hard to find.
question , rear , shocks , springs , tacoma
Suspension Noob Question - Is This Tacoma TRD Setup a Direct Swap? Bluesky 07 4th Gen T4Rs 31 09-04-2020 12:50 PM
Tacoma suspension swap onto GX470 question yotaman81 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 08-15-2019 02:44 AM
Tacoma TRD Pro suspension Charlene 3rd gen T4Rs 4 02-23-2018 08:41 PM
Tacoma TRD Pro suspension on 4th gen? Falcon3 4th Gen T4Rs 2 02-17-2018 09:07 AM
TRD Tacoma suspension question, what do I need??? Yota_Noob 4th Gen T4Rs 11 07-17-2015 10:34 PM
