Hi,
I have searched the forum and found some threads on removing of the transfer case on the 2003 V8 4WD without removing the transmission (my TC actuator needs to be replaced). Specifically, I followed this thread :
Fixing the transfer case shift motor leak from within.. - Toyota 4Runner Forum - Largest 4Runner Forum
I tried to get at the 12mm bolt on the very top of the transmission case on the passenger side but I had no luck, I used extensions, wobble sockets and tried to get in with a wrench but I had no luck. I could not even land the socket on the bolt. It is a very tight area with little swing room. After trying for 2 hours I gave up, very frustrated. I looked at the manual and I can now understand why the manual says to remove the transfer case with the transmission, but I am working by myself and think it may be too big of a job to remove the transmission and transfer case as a unit. Does anyone have any ideas/tricks on how to best get at the bolts on the top of the transmission case?
thanks
