Old 03-01-2021, 08:16 PM #1
BigMike18 BigMike18 is offline
Real Name: Mikey Barger
BigMike18 is on a distinguished road
Acceleration Issue V8
When I accelerate after a stop sign or red light there is this hesitation in my 05 4runner that feels like the car is almost charging up and then boosts forward. It not an instantaneous forward motion it kinda lacks "power" I guess and I have the Kit for the SAIS failure, but I'm not sure if those block off plates got installed(the previous owner installed them). I just replaced the tailpipe and one of the rear cats.
Added, my buddy's car does the same thing he has a very beaten up grand Cherokee and he has it way worse than me its horrendous on there, feels like a manual. But he hasn't replaced any exhaust parts. My thought here is its a clogged rear left cat? or something to do with the SAIS plates, but if anyone is inclined in this area I would greatly appreciate it, thanks.
BigMike18 is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 07:58 PM #2
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
I kinda doubt it's a clogged cat. The symptom would be different. I'd look more at the mass air flow meter or fuel system. First thing I'd do is clean the MAF and see if it helps.
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 08:34 PM #3
lord rigatoni lord rigatoni is offline
lord rigatoni is on a distinguished road
i agree with importman, try cleaning the MAF sensor. a dirty MAF sensor can jack up your air/fuel mixture and cause hesitation, misfire, rough idle, basically not what you want. if that doesn’t solve the hesitation issue, i would pull the injectors and clean them out since they get dirty over time and start having a weaker or more inaccurate spray. good luck!
2000 SR5 2WD auto - soon to be 4WD manual
lord rigatoni is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 05:40 PM #4
I’ve checked the fuel pressure and it was perfect around 42 and I just got a new Toyota oem Maf so I know it’s not those two. I’ve got new spark plugs, intake manifold gasket and no vacuum leak.
Old 03-18-2021, 06:54 PM #5
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
Possible seized brake caliper?
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 07:03 PM #6
Nah this is definitely a combustion or engine issue the way it feels in the Petal. And I’ve done my brakes and looked at them even replaced one beforehand.
ADDITION- forgot to include when I start the car no matter the temp or time since last start the rpms are high and continue to stay high every time I’m in park around 1500-2000 fan speed goes nuts
Old 03-18-2021, 07:14 PM #7
TheV6ThatCould TheV6ThatCould is offline
TheV6ThatCould is on a distinguished road
Common things being common with the 4th Gen, it might worth greasing all the zerks on the driveshaft. Sounds suspiciously like driveshaft clunk.
TheV6ThatCould is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 08:50 PM #8
triethylborane triethylborane is offline
triethylborane will become famous soon enough
Have you used a reader to see if there are any pending codes?
Checked fuel trims? Even with a new MAF, there is a slim chance it is faulty and the ECU is defaulting to base maps. I dont know about how Toyota programmed the ECU, but if you pull the MAF, the default map will usually run rich trims.
Smoke test for vacuum system issue?
This sounds like a misfire in some respects. Though, my guess is you know what that feels like behind the wheel. It would also likely be tripping the CEL.
Could be a coolant temp sensor given the high idle . . .
Bottom line is you need to get the sensor data from the ECU.
triethylborane is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 10:00 PM #9
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
Check for proper VVT solenoid operation and clogged screens.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 03-19-2021, 08:17 AM #10
Duckman1 Duckman1 is offline
Duckman1 is on a distinguished road
My 08 V8 was hesitating too. I cleaned the throttle body and MAF and it fixed mine.
Duckman1 is offline   Reply With QuoteReply With Quote
Old 03-19-2021, 10:57 AM #11
sundance21 sundance21 is offline
sundance21 is on a distinguished road
Yep. My bet is the throttle body. They get dirty rather quickly and they are so easy to clean. Just pull the hose off and spray a little. Wipe if you have to. Make sure to use the right cleaner made for throttle bodies ... do not use carb cleaner. You issue is coming off idle, which is directly related to the throttle body passages.
sundance21 is offline   Reply With QuoteReply With Quote
Old 05-02-2023, 08:40 PM #12
noahmas noahmas is offline
noahmas is on a distinguished road
did you ever resolve this issue?
noahmas is offline   Reply With QuoteReply With Quote
Old 05-04-2023, 12:09 AM #13
I believe I just replaced the fuel injector grommets (causing unwanted air to go into system), and started waiting until rpms drop below 1000 on start ups EVERY single time I drive it. I believe it helps get rid of the jolt, but it does not completely go away just is not as significant.
car , feels , plates , rear , sais
2nd Gen Acceleration Issue MisterNickG Classic T4Rs 16 11-23-2018 12:22 PM
Acceleration Issue Insanityman358 4th Gen T4Rs 14 05-15-2018 03:57 PM
Weird random acceleration issue jiggajatt 4th Gen T4Rs 4 06-28-2017 03:26 AM
Strange throttle tip-in acceleration issue - can't diagnose fullboogie 4th Gen T4Rs 11 09-08-2015 12:13 AM
2004 V6 Acceleration issue Gus04Runner 4th Gen T4Rs 13 12-04-2014 10:42 PM
