Old 03-02-2021, 12:19 AM #1
Iron Chef Iron Chef is offline
Iron Chef is on a distinguished road
2005 Sport v8: Spare tire dilemma (vs larger 33" mud tires)
So I recently bought what appears to be my dream 4runner (2005 v8), with a sweet yotamafia lift kit (4") and aftermarket rims + larger mud tires that was put on just recently by the previous owner:
However, it still just has the OEM spare tire, which raises a few concerns. It'd be nice to have a matching 5th rim + tire but that would mean
  • Those cost $$ out of pocket.
  • I'd need a tire carrier (and those are $$$$). Cuz no way such a tire would fit underneath in the stock spare location, right?
  • Changing this on the road or trail in an emergency is going to suck - the rim+tire combo is 100lbs!
  • It'd take a hell of a freak incident to put a hole into those beefy mud tires. So the chances of it getting a flat is pretty tiny - do I want a full-sized spare just to deal with such a rare event?
I talked to a tech from a tire shop (America's Tire), and he says in a pinch I can just mount the OEM spare, just don't plan on continuing my off-roading trip if I was on one. My initial reaction is if I can get away with using the OEM spare in a pinch, that would be great! Even if it means I'd need to cut an adventure short.
But would that cause any issues (stress/damage to components) if I'm forced to drive long distance on one mismatched OEM spare? Theoretically it's open front & rear diffs so it should be fine for the smaller tire to be rotating slightly faster than the other tire, right?
Appreciate any insights!
2005 Sport V8 4x4
Iron Chef is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 01:59 AM #2
benztech82's Avatar
benztech82 benztech82 is offline
benztech82 will become famous soon enough
benztech82's Avatar
I have 255-80-17 spare which is = 33" in diameter. Fits tight but inflated.
Sent from my Redmi 4 using Tapatalk
benztech82 is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 11:41 AM #3
ATOWN4R ATOWN4R is offline
ATOWN4R is on a distinguished road
Another option would be to keep a matching spare, semi deflated, and have onboard air. At least this way you have the correct size. Also, consider that these M/T’s are usually Kevlar or 10 ply. The chances of you popping one, or getting a flat, are slim.
ATOWN4R is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 02:07 PM #4
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
+1. I also run 255-80-17s and have a matching spare.
Buy a cheap one as insurance and it should tuck away no problem.
As long as the diameters are roughly similar, you shouldn’t have any issues.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 02:53 PM #5
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
See if you can find a used tire in similar size (255/80/17 or 285/70/17). Don’t worry about brand or if it’s all terrain or mud terrain. Partially deflate it (if you have a compressor to fill it back up later), use a ratchet strap, and see if it fits. The V8 tow hitch assembly eats up more room the the V6.
Also, make sure it actually works as a spare and doesn’t rub your UCAs, fender, etc... This is especially important if you’re using the factory spare rim since it will have a different offset and backspacing than the Method.
Also buy a tire plug kit and keep it somewhere in the truck. Might be a lot easier to just to plug a tire and get home than deal with changing the spare on the side of the road or trail.
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 05:51 PM #6
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
My solution: get tires that don't go flat and have true beadlock rims. I have never had a spare tire, nor have I ever had a flat. I run tires that are so thick that they cannot be punctured (they also weigh 110lbs each). If something happened where I got a flat...like someone shot my tire with a .50cal or a railgun...Not sure what could easily puncture a 1 inch thick sidewall... In any case, I can unbolt the tire, patch it from the inside, reinflate with my onboard air and keep going.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 08:33 PM #7
Wild Thing's Avatar
Wild Thing Wild Thing is offline
Real Name: Doc
Wild Thing has a spectacular aura about Wild Thing has a spectacular aura about
Wild Thing's Avatar
Real Name: Doc
Thanks for that, Benz. That's the tire that'll be on my five new TRD 7" wide rims. Thought I might have to deflate some. Glad I won't!
Stock 2008 Driftwood V8 4WD Limited with X-REAS, est. late 2020. Build page to come...
Wild Thing is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 08:39 PM #8
It is 6-ply! (from Amazon discription) I take it that's still pretty tough?
2005 Sport V8 4x4
Old 03-02-2021, 08:44 PM #9
Thanks for the input everyone! It looks like I should be alright with the OEM spare then - since no one outright says that's a horrible idea.
There might be other solutions in-between the OEM spare and going all the way (tire carrier, 5th matching rim + tires), but the OEM solution seems the most hassle free as a hedge against a freak event that has a slim chance of happening.
2005 Sport V8 4x4
Old 03-02-2021, 09:24 PM #10
Great idea! Added to my list
2005 Sport V8 4x4
Old 03-03-2021, 02:34 AM #11
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Put the spare in the back?
I run my 35" spare in the back like an old Jeep... because I still haven't gotten around to building a spare tire carrier or buying a rear swing out.
35" Just barely rolls in the back straight up and down and barely clears the door when closed, if you're just running 33" tires it should be much easier to fit in the back.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 03-03-2021, 01:38 PM #12
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Buy the right size tire. Throw it on the roof rack until you can afford a way to carry it on the back. Or get a 32" spare which would fit under the truck and be closer to the correct size.
I offroad in the CA desert and I had my first flat in 10 years from the volcanic rock. Tore a hole in the sidewall of my Yokohama Geolander E rated sidewall.
My friend behind me got home and noticed similar gashes in his sidewalls but his didn't puncture.
Get a cheap all terrain 32" and run it. If you are near Los Angeles I can give you one real cheap.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 12:18 AM #13
BlairB's Avatar
BlairB BlairB is offline
Real Name: Blair
BlairB will become famous soon enough
BlairB's Avatar
Real Name: Blair
What tires are you running that have an inch thick sidewall??
2008 4Runner Sport Edition 4WD V6- Long Travel, Camping Rig Build Thread
2023 Lexus LX600 F Sport- Daily Driver
2023 Highlander Hybrid Limited- Wife Daily Driver
BlairB is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 02:07 PM #14
There goes half of my trunk space lol.
I might take that option at a later date, but it'll be a while until I can put the money into a matching spare rim + tire. Other more important expenses ATM.
2005 Sport V8 4x4
Old 03-05-2021, 02:09 PM #15
I'm in NorCal, but if I plan a visit to socal in the future I'll def give you a PM!
2005 Sport V8 4x4
mud , oem , spare , tire , tires
V8 Sport stock rim with larger tire JeratBP 4th Gen T4Rs 6 08-02-2017 03:42 PM
Stock Spare with larger Tires?? SnowLizard 3rd gen T4Rs 20 05-27-2016 01:41 PM
Atlanta: 2015 Limited 20" Spare Wheel / Tire and Set of OEM 245/60-20 Tires NEW TRSAndrew For Sale: Suspension/Wheels/Tires 7 01-03-2016 01:39 AM
FS:FL - Full size spare 17" sport wheel/tire $50 wkeryder4 For Sale: Suspension/Wheels/Tires 1 08-29-2015 09:46 PM
Larger spare tire cover goatfarmer Classic T4Rs 4 05-05-2012 10:15 PM
