Old 03-05-2021, 03:43 PM #16
LinuxHack3r's Avatar
LinuxHack3r LinuxHack3r is offline
LinuxHack3r will become famous soon enough
I'm thinking on this kit. I figure coated calipers should help prevent corrosion which should help prevent seizing. Is that logical?
I think I want to steer clear of slotted/drilled rotors. They theoretically seem great in certain circumstances, but I've read that if they get mud/dirt/etc in them it can wreak havoc.
I picked the pads I did because that's what is in their Z23 Kit. Rotors picked mainly on above recommendation.
Thoughts? Changes?
My Build Thread
2007 Toyota 4Runner SR5 V6
LinuxHack3r is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 11:02 AM #17
I think I'd like to flush all the brake fluid as well. I see DOT 3 or 4 is recommended. I've seen various hints on this forum about supposed "non-Toyota" fluid ruining a seal in the master cylinder, any truth to that?
If not, what fluid should I go with?
I see RockAuto has this.
That is what populates when I select my vehicle. I believe I've seen two quarts, so purchasing three for bleeding may be wise? I'd really like to get this order in today.
I think I'm settled on the PowerStop Coated Calipers, Centrix Rotors, but between the Akebono or PowerStop pads, which should I go for?
My Build Thread
Old 03-08-2021, 02:37 PM #18
This is the aforementioned thread.
My Build Thread
Old 03-08-2021, 05:25 PM #19
Drcoffee's Avatar
Drcoffee Drcoffee is online now
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Some aftermarket calipers have stainless steel pistons. That would be a big step forward. But also, flush the brake fluid every 1-2 years.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is online now   Reply With QuoteReply With Quote
Old 03-08-2021, 05:44 PM #20
triethylborane triethylborane is offline
triethylborane will become famous soon enough
That Bosch fluid will be fine, though you could go to the parts store and use any DOT 3 or 4 off the shelf. Ive used valvoline full synthetic and ATE. Too bad ATE super blue cannot be imported, that stuff was great for bleeding. I think I went near 3qt, though YMMV.
Pads . . . either are fine though Ive found akebono to be a bit dirty on other makes.
triethylborane is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 02:22 PM #21
riverwolf riverwolf is offline
riverwolf is on a distinguished road
If you don't like seeing brake dust on your wheels, stick with a ceramic composite pad like the ProActs. I have them with the Centric rotors and you can't tell the factory alloys have any brake dust unless you run a finger through it. Same coefficient of friction as OEM without the mess, even though factory was also supposed to be ceramic, I think, but it's dusting was much worse.
I'm such a fan that I swapped my E46 convertible over to Akebono ceramics ASAP after I'd taken care of the neglected and way overdue maintenance items. Some will disagree, but I couldn't tell a difference in stopping power with the OEM pads (maybe the Akebono's need a little heat in them first). OTOH, the OEM BMW pads practically coated the wheels before you could hit the end of the driveway after washing. :-)
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
riverwolf is offline   Reply With QuoteReply With Quote
hundreds , pads , people , rotors , time
Almost time for new brake pads and rotors octanejunkie 3rd gen T4Rs 53 07-11-2018 06:15 PM
Is it time for brake service? PCF4runner 3rd gen T4Rs 3 02-12-2016 11:40 PM
First time brake job...found a surprise at the end StreetCreeper 3rd gen T4Rs 24 11-13-2014 04:39 PM
Brake Job Time, Who's Your OEM Guru ? HELP! The Moe 4th Gen T4Rs 8 07-18-2012 05:48 AM
It's time for a Brake Upgrade. Need Opinions CoMarc 3rd gen T4Rs 3 06-01-2010 10:06 PM
