Old 07-24-2007, 07:54 PM #1
VolFF's Avatar
VolFF VolFF is offline
VolFF is an unknown quantity at this point
VolFF's Avatar
Steep Grades
I am leaving soon for a trip to Mount Washington NH, and have plans to drive up the Mount Washington Auto Road with my 2006 4Runner V6 4x4. The road is 12 to 22 percent grade fo over 7 miles. They recommend going up and down the road in 1st gear. Would the 4Runner be happier in low range, letting the tranny do what it wants to do to climb? Am I just over thinking this and should just go up in 1st gear?
2006 4Runner
VolFF is offline   Reply With QuoteReply With Quote
Old 07-25-2007, 07:37 AM #2
boston_kevin's Avatar
boston_kevin boston_kevin is offline
boston_kevin is on a distinguished road
Yes. Shift down and let the tranny control your speed, especially with steep grades (like the auto road on Mt Washington). Stay out of overdrive as you are climbing because the tranny will hunt for gears based on the RPM, them downshift to get back up to speed. 1st gear may be a little too slow, especially with the 5 spd. I wouldn't go any higher than 3rd, and downhill, probably keep it in 2nd or 1st to maintain control and minimize braking.
boston_kevin is offline   Reply With QuoteReply With Quote
Old 07-25-2007, 10:36 AM #3
jimsi jimsi is offline
jimsi is an unknown quantity at this point
I agree with downshifting. You didn't mention auto or manual tranny. If it's auto then selecting 4 will disengage the overdrive and the 3-2-1 will work as selected...so dependent on your speed I would take it out of D and select the appropriate gear.
If you are thinking of using 4Lo on the 4x4 selector you probably would not use this to go up a hill. It's for low speed 'crawling' or pulling something out (i.e boat trailer on a wet\slippery ramp)
Black 06 V8 Sport-Canadian Spec
Added:cargo nets, cargo cover, cabin filter mod,compass mirror, headrest monitors & dvd player,
jimsi is offline   Reply With QuoteReply With Quote
Old 07-25-2007, 10:43 AM #4
JP4RNR JP4RNR is offline
JP4RNR is on a distinguished road
I beleive there is no manual transmission option for the 4th Gen 4Runner
JP4RNR is offline   Reply With QuoteReply With Quote
Old 07-25-2007, 10:45 AM #5
Baba Booey Baba Booey is offline
Baba Booey is on a distinguished road
I've always been under the impression that 4-Lo is much easier on the tranny when driving at slow speeds - even if it isn't absolutely necessary for the given situation.
Isn't it better to be in 4-LO when wheeling at very slow speeds even if 4-Hi is all that is needed traction-wise? I thought 4-Lo allows the tranny to operate at cooler temeperatures.
If this is true, then using 4-Lo while ascending/descending Mt. Washington may be a good idea.
2006 SR5 V6 4WD
2015 SR5/P 4WD
Baba Booey is offline   Reply With QuoteReply With Quote
Old 07-25-2007, 11:09 AM #6
4Lo is for very low speeds (i.e. less than 15 mph). The V6 in either 2WD or 4Hi should be fine if you downshift to 2nd or first to maintain speeds downhill. Uphill 2nd or 3rd should be fine.
Old 07-26-2007, 08:26 AM #7
Koz's Avatar
Koz Koz is offline
Koz is on a distinguished road
Koz Koz is offline
Koz's Avatar
You don't need low, just use the lowest gear that will maintain a safe speed.
Koz
Koz is offline   Reply With QuoteReply With Quote
Old 07-28-2007, 11:14 PM #8
VolFF's Avatar
VolFF's Avatar
Thumbs up Thanks Guys!
thanks to all who responded!
My 4Runner (2006, V6, auto, 4x4) made easy work of that climb and the downhill wasn't bad either. I ended up using 1st or 2nd gear depending on the speed that I needed to maintain to round corners etc, keeping the motor at 2-3,000 rpm. They suggest no A/C because overheating is so common - 'forget that' my wife and kids wouldn't have that. A/C blasting temp gauge never moved!
The way down, started using 1st and used the tranny to slow the truck, with the brakes, then found it was holding too slow, and 2nd not slow enough. after getting past the hairpin turns, with no guard rails and shear clifs, I started to just use the brakes. a brake job is far cheeper than a tranny job, and the brakes were doing fine with no noticable fade. half the way down stopped in a turnout (scenic overlook) where there were 2 cars with the hoods up due to overheating. This was well after I started primarily using the brakes on the way down, and no smell was notcible (until I stuck my face in the wheel and then just barely). Got to love the 4 wheel disk brakes with massive components!
this thing is an amazing truck! I cant imagine how the V8 would have handled it.
2006 4Runner
any big differences between 00-02 limited grades 4x4Runner09 3rd gen T4Rs 14 01-23-2022 06:32 PM
Prado steep hill climb ToyTech99 Lexus GX470/460 23 04-22-2011 12:39 AM
Descending STEEP Gravel Roads...4WD? 4Ever 3rd gen T4Rs 4 04-27-2010 08:51 PM
Steep hill climb (LR3 video) Even Steven Off Topic 18 12-28-2007 02:04 PM
IIHS Gives Crash-Test Grades to Midsize SUVs Thai 4th Gen T4Rs 10 10-15-2007 10:15 PM
