Old 03-04-2021, 08:30 PM #1
Renol Renol is offline
Renol is on a distinguished road
Issues with jba UCA bushings?
Been getting a lot of popping noises from the front end lately particularly when coming to a stop. Had it in for sway bar links and the pops got softer but came back. Shop had me do stops to get the noise while they watched and said the control arms are flexing forward then back and it appeared the noise was coming from the UCA bushings.
Has anyone encountered similar circumstances on their own arms or heard of issues with jba? Wondering if its a fluke or problem.
Renol is offline   Reply With QuoteReply With Quote
Old 03-04-2021, 10:12 PM #2
Silver Stallion's Avatar
Silver Stallion Silver Stallion is offline
Silver Stallion is on a distinguished road
I've had the same popping sound recently when turning full lock to the left when pulling into a parking spot. I was wondering if it could be the JBA arms as well. I've had them on for about 8 months now with no issues, it just started this week. Interested to see what others experiences are. But it could be a lot of different things like older steering components ext. I have not investigated it yet to see the cause.
2004 SR5 V8, 275/70/16 KO2's, Eibach Pro Lift, JBA UCA, SuperPro LCA, DT Headers.
Silver Stallion is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 01:03 PM #3
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
I bought a used set of JBA arms and will need to replace the bushings soon. Do they take stock bushings? I'll be following this post just in case I run across this issue in the future.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 03-06-2021, 03:16 PM #4
JBA sells replacement bushings on their site. I'll be contacting them about their 1yr warranty on balljoints and bushings and report back. I'm right at about 8mo of use on them as well.
Old 03-07-2021, 10:16 AM #5
SA-Overland SA-Overland is offline
SA-Overland is on a distinguished road
Can you post a picture of your UCAs? 8 months is typically really not normal for a bushing fail unless there are other problems.
Did you install the additional washers on the inside of the bushings?
SA-Overland is offline   Reply With QuoteReply With Quote
Old 03-07-2021, 02:02 PM #6
I'll post up pics a little later today when I can resize them for posting on a computer. But the mechanic who installed them went off the instructions provided with the arms. I too find it hard to believe and might bring it to another shop for a second opinion.
Old 03-08-2021, 05:40 AM #7
joshik joshik is offline
joshik will become famous soon enough
Any video of the sound you are hearing. I get this metal clink sound when hitting a bump. It seemed to lessen after I did the lca bushings and itre and otre... But I still get the clink. I have jbas.... Wonder if it's the same thing u are experiencing.
2003 4Runner Limited 4wd V8. JBA UCA, Dobinsons MRA Front Coilovers, Dobinsons MRA Long Travel rear. Cooper AT3 XLT 285/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
joshik is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 08:18 PM #8
I've attached photos. First 2 are driver's side, next two are passenger side. If anyone sees anything wrong please let me know. I'll try and get video later.
As for the sound, its like a metallic clank and often a pop. Beyond that I can't really describe it. I tried getting video from inside the car but the ambient sound was so bad it washed out the noises I was trying to get.
Also, I'm HIGHLY HIGHLY suspicious of the lower arms. I've had issues with them before because the shop that installed them did not properly torque the camber bolts which came loose causing the arm to shift and make LOUD pops. They tightened the bolts and the loud pops went away but the quiet ones remained and were very inconsistent from that point on.
Issues with jba UCA bushings?-uca1-jpg  Issues with jba UCA bushings?-uca2-jpg  Issues with jba UCA bushings?-uca3-jpg  Issues with jba UCA bushings?-uca4-jpg
arms , back , coming , issues , noise
5th gen LCA bushings. Anyone had issues? cleveland48 5th gen T4Rs 47 10-05-2020 10:06 AM
'98 4Runner Steering Issues: New Rack or ITRE's and Rack Bushings? TheFriZ 3rd gen T4Rs 23 04-25-2019 12:35 AM
95 4x4 upper & lower control arm bushings replacement HELP!!! and rear bushings??? mark808 Classic T4Rs 18 07-08-2013 01:11 AM
Lift Install Issues... endlinks, bushings, corrosion trailrazer 4th Gen T4Rs 3 06-20-2012 10:54 AM
Upper control arm bushings (do poly bushings exist?) jamess 3rd gen T4Rs 20 02-21-2011 04:07 PM
