Old 03-05-2021, 12:09 PM #1
4by4runr's Avatar
4by4runr 4by4runr is offline
4by4runr is on a distinguished road
4by4runr's Avatar
Are bils 5100 my best option for cheapish 2/1 lift?
I have a spacer leveler right now but I think I want another inch, which requires the rear. I’m in Denver and live in an apartment now so doing this myself isn’t really an option. What setup would you recommend?
Thanks!
2004 V8 4x4 sport in Galactic Grey • Xreas delete • 248k • BFG KO2 265/70/17 • Custom Arizona sun two tone paint • 2" leveling kit
4by4runr is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 01:33 PM #2
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
I believe the Eibach Pro truck kit is also 2/1. The full kit with shocks and springs is less than $700
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 02:09 PM #3
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Generally - yes, tried and true for lift and general use. If you do more off roading or no offroading you can get a more specific lift for your purposes.
Old 03-05-2021, 02:45 PM #4
4by4runr's Avatar
4by4runr's Avatar
I do light off roading but no crawling/wheeling. Just whatever the mtn pass roads have.
Old 03-06-2021, 10:46 PM #5
Renol Renol is offline
Renol is on a distinguished road
Bilstein 5100s are a good choice. I'm happy with the ride on mine and do mild offroading now and then. I would caution you however to research the rears before you buy. My rear bilstein 5100 was part# 33-187174 and had a minor problem with fitment. Stock the mounting post goes through a bushing, tac welded washer, welded frame bracket, bushing, washer, and nut. When using the bushings provided I found out that if the washer on the underside stays on you will not have enough room to get the nut threaded. One side the washer came off and after much aggravation and effort I managed to compress the washer/bushing just enough to get the nut started and secured. On the other side the washer stayed on and I had to swap out one new bushing for an old one just so I could get the thing to fit.
Long story short look for a different part number that fits but is longer or try to find overall length specs and compare so you have plenty of room to mount everything.
Renol is offline   Reply With QuoteReply With Quote
Old 03-07-2021, 02:11 AM #6
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
The Daystar spacer lift kit (2.5”/1.5”) is cheap.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 03-07-2021, 10:10 AM #7
SA-Overland SA-Overland is offline
SA-Overland is on a distinguished road
5100 are a good low budget option but those 6112 with the larger bore... those are super nice! Incredible difference in handling on road and off.
Best bet would be to find somebody that is selling their used set of Bilstein 6112 !!!!
*Shameless plug*
I have a set that i'm not using anymore. PM me if you want a good deal.
SA-Overland is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 02:56 PM #8
Adeadwallnut Adeadwallnut is offline
Adeadwallnut is on a distinguished road
The 5100 are a good option for a relatively easy straight swap with the OEM components. They significantly improved the road manner of my 03. When I looked there was not a ton of options that offered more bang for your buck. You could potentially go with a spacer lift if you really want to save a few $$$.
Adeadwallnut is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 01:24 AM #9
JBend JBend is offline
JBend will become famous soon enough
I have the eibach pro lift kit on mine now and am happy with it. If you want to wait a few months, may/June I'll be upgrading and putting my eibachs up for sale.
JBend is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 01:42 PM #10
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
I've got the same lift. What are you upgrading to and why? I've really liked my Eibachs, just curious what your next step is.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
apartment , isn’t , live , option , what’s
Best lift option? 98 Sr5 3rd gen T4Rs 22 11-27-2018 10:19 PM
Anyone looking for a good accessory mounting option? Canon_Bob 5th gen T4Rs 6 03-05-2015 10:54 PM
Best 2wd lift option for 4th Gen??? corpsmanup2012 4th Gen T4Rs 18 02-03-2014 11:10 PM
a different lift option?? Duhockey 3rd gen T4Rs 16 03-08-2010 12:20 AM
